Ditch Witch C99
/ Ditch Witch C99 #181
I am needing to get an air filter element for the Ditch Witch C99. The one I have is the round dry element filter and it is totally shot. Cant seem to find any place that sells them. I would appreciate any information.
Were you able to find a replacement air filter? I was striking out today
/ Ditch Witch C99 #182
Joining the club here. Just pulled the old C99 out of the back 40 to see if I can get it running. Starting with gas, spark plug, air filter, and pull rope and we will go from there
/ Ditch Witch C99 #183
You might try calling Ditch Witch about the air filter. Their motto is, "Every part for every machine ever"
I think I sent the manuals a bit ago. Hopefully you can find a part number in there that you can cross reference. In the past I have had to take a filter to a parts store and have them look through all the boxes. These days I wonder if you could find a filter maker's web site that lists the dimensions of all their filters and come up with one.
Let us know how it all turns out.
/ Ditch Witch C99 #184
Got the spark plug swapped out and some gas in it but couldn’t get it to turn over. Spark plug cable seems to have iffy continuity and I don’t see a spark at the plug so I will try to replace the connector to see if that does it.
/ Ditch Witch C99 #185
A big thanks to Dave for the information!
This past weekend I changed the tires on my C99 and cleaned up the gear selector. It wasn't selected the forward gear, and I found a broken spring along with being jammed full of dirt. Here is a summary.
After a good power washing:
After removing the locking collars and a few snap rings, the gear box slides off the shaft. If I were to do this again, I wouldn't have taken the whole axle off, I would have removed the drive chain, jacked up the trencher on the drive side, removed the wheel, then remove the gear box. It would have saved a lot of time.
Here a found the broken flat spring
someone decided to weld up this box. I didn't weld it back when I put it together, so I hope it holds with just the two bolts.
Here you can see the dirt jamming the gear selector. The power washing didn't get rid of this dirt.
I welded the spring back together. I didn't think it would work, but I gave it a try.
Here is the selector back together.
Here is a video of the selector. Notice how these tabs will engage when the selector is all the way to one side and in the middle neither tab will engage.
And just because I liked how these wheels turned out:
I hope this helps some c99 owners out there!
Nice job, I have a c4 that uses the same gearbox nice to have an idea of how it is supposed to be.
/ Ditch Witch C99 #187
Hey Barry, great job on the pics and great job in general! I think the gear boxes are all welded from the factory. Surprising to me but maybe DW figures they will never break. Did Dave send you the manuals yet? If not, I can get them off to you.
Happy trenching and wrenching,
Gary
/ Ditch Witch C99 #188
I could sure use the manual set if someone could send it along, mcconnll6@gmail.com Just bought a c-9 for 500 and after fixing a VERY leaky gas tank (still have to reline it) it fires up with a good hard pull, has a ton of compression. but the drive reduction lever is bent a bit and I'm not sure things are right down there. You have to move the trencher a bit till it rotates that "hub" with the lever around and you can move the lever to engage it. It would seem that reduction unit should be static (bolted or welded to the frame) so you can put it into forward or reverse pretty quick and easy. Seems odd that you have to push the trencher around 3 or 4 feet to get that lever to be exposed so you can click it in or out
/ Ditch Witch C99 #189
Manuals are on their way. If I am understanding (and remembering mine correctly) If you engage the drive belt, the reduction unit will rotate around. You can then engage the lever. Keep us posted and maybe put up some pics. Do you reline the entire tank? Or replace the fuel line? How would you reline the tank? In any case, be sure to use non alcohol gas in this unit.
-Gary
/ Ditch Witch C99 #190
-Gary
I got the manuals, Thank You. Lining the tank is done by washing it out with Purple Power degreaser and scalding hot water, then I put Phosphoric Acid (which is concrete etch/cleaner from Home Depot, paint aisles, about 17 for a 1/2 gallon) This will eat rust and etch surfaces to prep for the liner (used this trick on MANY a rusted truck frame prior to painting). Rinse and dry the tank thoroughly. I then used KBS tank liner (amazon, 15 for 8oz which is enough for 2 or 3 tanks) both the acid and liner you slosh around and keep turning the tank to another side every 2 or 3 minutes for an hour. After the hour I dumped the excess liner material and let it set for 4 days to harden/dry thoroughly. 8oz could do up to like a 20 gal tank in a shot, all about letting the liner slowly crawl across the tank surface. The excess material can also be used on the exterior of the tank if you like. I'll post pics of the tank now. I also replaced the glass filter bowl as mine broke when I tried to open it to clean it up (ebay, 15), got 1/8npt to 1/4 hose 90s (5 for 6 on amazon) and Fleet Farm for 2' of 1/4 fuel line for .98/ft. Entire fuel feed is "new". First attempt got no where and trouble shot the ignition to find ether in the hole would fire for a second so fuel delivery was bad, opened the bowl drain and got nothing. Kissed the gas tank for a BJ and it started flowing. Closed up the bowl drain after letting it flow a cup or so and it fired right up. It was hunting and then died when I idled it down so might be best to take the carb apart and clean it out right. Former owner just had it full onion full time so I know he was an idiot, the travel gear would launch it into next week at full throttle.
/ Ditch Witch C99 #191
Nice report! I had never heard of etching / relining a fuel tank. Great tips. Learning as we go here...
/ Ditch Witch C99 #193
Sure. I will send them along. Please keep us updated on your project.
/ Ditch Witch C99 #194
Not sure this is still a Live topic ,, but just in case it is live . Does anyone have # for a carb kit for the carb on a Wisconsin on a C99 .
I wouldn't mind a copy of that manual & parts list if any are still available . My history , I bought my first C99 @35-40 years back after it had spent some 15-20 maybe hard years at a rental yard . Yea , they frame was bent , the front part was frozen but we worked through it . I bought another one from a rental yard in Santa Clara CA that had put like 10-15 of them on their side lot & forgot about them . I was taking back a skid steer one day when I noticed what looked like a pair of C-99 handle bars stickin out . I went over & pulled some of the branches away & saw 3 C-99 underneath with several more behind them , so as we were finishing up my paperwork I asked what the deal was with them . Guy said take as many as ya want for 200 a piece . Didn't take much for me to respond " I'm yer Huckelberry " & told them to pull out some of them so I could check them out & I would be back the next day . When I went back the manager told me I should charge 500 but I did tell ya 200 , It was a lot more work gettin them out than I though it would be . Turn's out that the plant engulfing the C-99 starter towards the front of the building & had grown through each & every unit that was back there . He said it took 2 of my guys the better part of the day to dig out 5 of them . SO I did some lookin & picked the best of the 5 & had them put it in my truck . Took some parts here & there over the years to keep the first one going . Against my better judgement I loaned it to the hubby of a gal that worked for my wife . Yep it came back with no transmission , so I took the one off the spare & fixed it . Last week she tells the neighbor he could borrow it , so then I had to make it run aftr sittin for the last 5 years . Dodged a bullet cause when I pulled the carb apart th rubber tip on the needle fell off in my hand . Dodged a bullet this time .
thanks
sorry for the long story , but sometimes when I get going I can't help it
thanks
animal1@psln.com if those manuals are still out there , thanks
animal12
/ Ditch Witch C99 #195
/ Ditch Witch C99 #196
Quite the adventure story. I just sent the manuals including the ones for the engine. I have to imagine that the carb part you are looking for should be available somewhere.
Best wishes and keep us posted,
Gary
/ Ditch Witch C99 #198
I have found that 1) I can trench more with rentals than I can possibly install in one shot, and 2) trenches do not age well.
The upshot is re-digging all those trenches out by hand with a contractor's shovel, or cobbling up something that allows the CUT to help with the chore. Neither have turned out well for me. Rain also disperses or compacts your backfill.
So, I bought a trencher off of Craig's List. Been stalking them for some time, but the $$ or condition put me off. Until now....
This "antique" Ditch Witch C-99 is an awesome little digger. It was $950 and I will call that good. The rope start kicks it on first pull every time (so far). It was well cared for and home-serviced.
Shifting forward and reverse is a little tricky. I can share one painful way not to do it, but it works pretty well once you get the hang of it. I can run an easy 2' deep when and wherever I want, and it's at least a little more maneuverable in some of the tighter places.
You trench in the reverse creeper gear, and once it's all going you can sit down and watch. It will just pull a straight line unless you hit something you should have known was there. Or an undocumented rock.
If anyone else has one, I have scanned the owner's manual and have the parts book as well. It's been out of production since at least '99.
I have finally got my pipes from the well to the house (and under the driveway, courtesy of a rental UnderWonder) and am finally making some real progress.
I just acquired a c99 and would love to have the manuals if you could send a PDF to me. I found a manual for the AENLD engine online for $20 but it's not a very good quality copy
/ Ditch Witch C99 #199
I would be happy to. Send me a pm with your email address and I will get them off to you.
2018 BOBCAT E50 EXCAVATOR (A64279)
2018 BOBCAT E50...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
Caterpillar M318 Excavator Service Manuals vol. 1 and vol. 2 (A63117)
Caterpillar M318...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
ATTENTION PLEASE READ (A64119)
ATTENTION PLEASE...
