Battery powered chainsaw
/ Battery powered chainsaw #1,061
346 is just a farm and ranch saw
They were XP saws. I later realized I should have replaced the crank. That is still the best saw I've owned. (Best I ran was a Partner 5000, 40 hours/week doing power line maintenance.)
/ Battery powered chainsaw #1,062
We own around 8 saws here and the last were two battery powered ones. Keeping them and use them lots.
/ Battery powered chainsaw #1,063
I am getting ready to purchase an Echo DSC-5000. Already have some batteries. I like the idea of using the safety features of the saw for my son to learn how to use a saw. Before I purchase, can manufacturer bars chains be used on them? Example... do I have to buy a specific bar and chain designed for the echo saw or can I put a replacement Oregon bar or chain on it?
/ Battery powered chainsaw #1,064
All chains are interchangeable by size. I think that bars are the same.
/ Battery powered chainsaw #1,065
/ Battery powered chainsaw #1,066
My Stihl pole saw came with a special chain size only sold by them. I replaced the drive and bar so as to use regular chains. Was happy after that.
/ Battery powered chainsaw #1,067
Contrary to JYOUTZ's comment, i believe the electric world is different. Ive cleaned out junk from my friends Stihl battery job. I believe the holes were closer together. Same with my plug-in cheapy WORX.
hopefully some Tie Breaker will chime in.
/ Battery powered chainsaw #1,068
I certainly wouldn’t argue. My experience is with gas powered saws.
/ Battery powered chainsaw #1,070
This is what I want to avoid. I'd like to have more options.
/ Battery powered chainsaw #1,071
2 years ago, I purchased a DeWalt 20V saw with a 12" bar. It was a little short for what I needed so I replaced it with an Oregon 14" bar and Oregon chain. It worked perfectly.
Last year, I bought another DeWalt 20V saw, this time an 18" model. I do a lot of cutting on the ground and got sick of re-sharpening chains so I bought an Oregon compatible 3/8 pitch, .050 gauge carbide chain. It also worked perfectly.
I can't speak for other brands, but DeWalt cordless saws use standard Oregon bars & chains.
BTW, That same carbide chain I bought also fits Echo CS3400 and CS3450 saws but I'm not sure about the DSC-5000.
/ Battery powered chainsaw #1,072
Mine isn't a pole saw but my HF Atlas chainsaw takes an off the shelve chain.
/ Battery powered chainsaw #1,073
You need to buy a bar specifically made to fit your chainsaw. Some chainsaws share mount designs with others, so bars are interchangeable, but many are not.
Oregon makes different bars specifically to fit a wide variety of chainsaws, both battery and gas powered.
Bailey's has a good bar finder that covers the Echo DSC 5000. Even if you do not end up buying through Bailey's it will at least give you a manufacturer part number to look for. The have a similar chain finder as well.
/ Battery powered chainsaw #1,074
I used my 80V Greenworks last two days a lot. Three heaping truckloads of white pine branches and two more yet. I bought a Greenworks 80V weekeater from Walmart because it included battery & charger, less expensive than just a battery. So I have a spare for saw & charge one as I use one.
/ Battery powered chainsaw #1,075
EGo uses an Oregon bar and chain.
/ Battery powered chainsaw #1,076
When I was shopping for my electric saw, part of what tipped the decision to DeWalt was the fact that they had contracted with Oregon to make the bars and chains.
/ Battery powered chainsaw #1,077
I just got one to keep on the tractor to cut limbs and other small items when I am bushhogging. A Milwaukee...
David from jax
/ Battery powered chainsaw #1,078
Not so much an issue of brand, but pattern. Is EGo using a mounting pattern common enough to not have you locked into one manufacturer, who could arbitrarily choose to pull the plug on that model?
I suspect Oregon, Tsmura, and Carlton are probably making bars for half the other brand stamps you'll see on the market, but each manufacturer can specify a different mounting pattern.
/ Battery powered chainsaw #1,079
The good thing is right up front you know you can get a bar from other than the saw manufacturer; if a decent number of saws are sold then Oregon is likely to keep selling bars.
My Echo battery saw uses a bar that looks just like every other saw I've used in the last 40 years, >though a bit shorter< so I'm not concerned about availability for that
/ Battery powered chainsaw #1,080
My echo M18 pole saw is Oregon bar and standard chain.
It is a single hole for the bar nut, so not sure what other bars would fit.
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
2025 28in Forks and Frame Mini Excavator Attachment (A66734)
2025 28in Forks...
x (A68191)
x (A68191)
2014 FORD F-150 (A67714)
2014 FORD F-150...
2019 INTERNATIONAL HX615 SBA 6X4 DUMP TRUCK (A65057)
2019 INTERNATIONAL...
2014 CHEVROLET CAPRICE CAR (A66091)
2014 CHEVROLET...
