Planning to buy soon
/ Planning to buy soon #21
I bought a 3320 jd used in 2016 has been a good tractor
/ Planning to buy soon #22
a dealer here sells tym , neighbor had one it was junk , no parts, service dealer is a joke they wont even answer the phone , now there selling hyundi construction equipment one day i assume it will be closed bunch of clowns that work there
Thanks for the feedback.
/ Planning to buy soon #24
Buy from a local dealer that has been in business(with what-ever brand) for at least ten years.
We have three Kubota's in the family with good results.Minor farming use/logging/snow removal ect.About 100 hrs.per year on each.
Also buy one size larger than you "think" you need;save trading down the road.
Four wheel drive,FEL at the minimum;cab if using in the winter.
Had a cabbed tractor for 15+years and haven't broke anything on it yet.
/ Planning to buy soon #25
I bought an LS MT242 (premium, not E), I wasn't skimping just to scrounge. Originally I planned on a Kioti in starting in 2022 but both my closest dealers were let downs. I was raised on JD but prices, quality, capability, and service just didn't seem as affordable for like products. My money went further with a non-JD tractor.
I'm enjoying my LS tractor so far, not had it long but for what I'm using it for, it is a good platform to work from for a while. Best of all, the dealer is stand up. From my research the loudest voices was often echoing about dealer support when picking a tractor. I heeded that advice and I think I got a solid tractor. 0% for 120mths. 2yrbumper to bumper/6yr powertrain warranty.
/ Planning to buy soon #26
Mine has been rock solid and I’ve put it through its paces. My 2 neighbors up north have them as well and have had great luck with the brand. My dealer has been awesome so far as well. Sounds like your local dealer was the issue .
/ Planning to buy soon #28
Whatever brand you buy, it sounds like your needs will be best met by a smaller utility tractor with a category 2 hitch, and front end loader, 60+ horsepower. Kubota MX or M series or other brand equivalent. Be sure to get 3 rear remotes when you buy the machine, and also a third function since it sounds like a grapple is in your future. I didn’t and ended up paying twice as much to install these a few years after purchase. And you should consider how much of your work will be in the woods. Cabs can be a problem in dense forest stands and broken glass isn’t cheap. On the other hand, they are great for open field work and mowing. Take your time, visit various dealers with different brands, sit on and test drive them. And compare apples to apples among brands. Horsepower can be a misleading comparison. You need to compare similar hp along with similar machine weight/frame size to be a valid comparison. Also investigate the dealer; do they have an actual full service shop and parts department or are they selling tractors behind the feed store? These things are important over time and worth a price premium for the brand.
/ Planning to buy soon #29
If not Kubota or JD, the Yanmar YT359 with the iHMT is one of the nicest machines out there. 10 year power train warranty too.
+1 on the Yanmar only I would get this over a Kubota or JD.
/ Planning to buy soon #30
Big drawback to the Yanmar yt359 is how lightweight it’s built for a 59 hp tractor. Cab tractor only weighs about 3400lbs , loader and bucket only adds about 1100. Total bare tractor and loader about 4500. My Open station CIH dx35 , only 35 hp weighs that much.
Contrast that with a JD 5055E bare tractor 7000lbs , loader with bucket adds 2000lbs plus . Total about 9000lbs . Twice the weight! Which puts in in a way more capable category for about same money.
Below are the specs, note the yt359 is listed with Full Fluid filled tires so you have to deduct about 1000lbs.
/ Planning to buy soon #31
Wife Aunt bought a Kubota 40hp. Used it on the ranch for 14 yrs. Took it into a dealer for service. He said folks paying top dollar for this tractor right now, covid and all. She sold it to him for what she paid for it and went home with a new Kubota. You can't say that about many tractors.
Personally I like Kubota. Good to know there is a dealership I can walk into for parts nearby but I want a tractor that never needs repairs. 2 kubota dealers within 15 miles. Both been there 25 + yrs.
/ Planning to buy soon #32
I do NOT want to buy a tractor that is too small or one that is too large to get into the woods when needed.
I was the same way.
Bought my 2 year old Kubota B7610, put a backhoe on it. Goes through the woods easy, but doesn't carry enough. After a few years, and obtaining a house w/ 73 acres, bought my Kubota M4700. My woods are mostly ~40 year+ old stands of deciduous. The B7610 fits through rather easily, the M4700 fits thru after I convince some trees to lay down.
Don't use them much now, but total cost (including parts and repairs) has been ~$30K. I've had to buy a couple of front tires for both, got 2 hydraulic cylinders repaired, replaced about 5 hydraulic lines. All repairs pretty simple, especially with the great support on TBN.
/ Planning to buy soon #33
I see what you’re sayin but I’d be surprised if that were true. The Kubota L3560 is 3500lbs bare tractor and the YT359 is longer, wider, has a larger displacement engine, and larger tires. Yanmar provides loaded tires free of charge on new tractors. Would like to run one across the scales to verify.
/ Planning to buy soon #34
I’d be curious to run one across scales too. I recently purchased a YT359c and I was assuming the 4500lbs didn’t include the loader or filled tires. I’ve been looking at new trailers to deal with the weight. If the 4500 lbs include loaded tires and FEL, adding my mower puts the total at 5700 lbs. If it doesn’t include loaded tires and FEL, it’ll be closer to 8k. Makes a huge difference in my trailer selection as I’d like to go gooseneck and my truck is only rated at 11k towing.
/ Planning to buy soon #35
The info I got was right from Yanmar’s own Brochure, usually tractor manufacturers don’t short change themselves when it comes to specs. Find the pdf of they’re brochure on line and have a look . It also includes all loader specs.
Oddly tractor data doesn’t give a weight for the yt359.
The rear axle and also transmission is a area where quite a bit of weight can be gained or lost. I’ve never seen the 359 up close to look.
The tire the brochure specs as fully loaded is the R4 industrial. Also don’t know if there ballasting just the rears or all 4. I assume just rears.
I’m a big fan of Yanmar, great history of high quality and engineering.
/ Planning to buy soon #36
If I was going to buy a new tractor today, the YanmarYT359 would be at the top of the list, because of Yanmar quality and the IMHT transmission (best in class). NS series Kiotis would also be on the top of the list (most bang for the buck). I think your dealer recommendation is a good one. Here is how I assess tractor brands.
/ Planning to buy soon #37
I like my LS, but with current supply chain issues, might pass on that for the immediate future. Advantage is if it crosses to a NH model, most of the parts can be had cheaper by adding MT to front of the part number. (you might need to do the work yourself as you would probably fall to bottom of the list at any non-LS dealer for work)
what does LT, NH, MT stand for?
/ Planning to buy soon #38
Same size place; I bought a Yanmar YM347A.
I went to local dealer who sells Kioti and Yanmar. Deal was much better and tractor was overall larger than comparable K. I love this tractor. Higher ground clearance, larger frame, larger wheels, Cat I and Cat II hookup, greater lifting capabilities, and comes with one rear remote. I had an additional rear factory remote added, as well as a factory front diverter for grapple work. Also, it has a 4 cylinder regularly aspirated (non-turbo) engine.
Very pleased.
/ Planning to buy soon #39
Yes, but both of your examples are compact tractors, not utility tractors.
/ Planning to buy soon #40
Lots of good input here. My 30hp MAHINDRA does all the light work, my 60hp KUBOTA MX does the heavier work. Both have been problem free tractors. Both bought from dealers nearby. Parts support is better with Kubota. Those are my inputs for choosing - dealer support & parts availability for YOUR location.
New/Unused AGT YSRT14 Mini Skid Steer (A65583)
New/Unused AGT...
(8) Massey Ferguson Tractor Suitcase Weights (A65640)
(8) Massey...
HEIN-WERNER 1TON TRANSMISSION JACK (A65643)
HEIN-WERNER 1TON...
2015 Bobcat T590 (A64126)
2015 Bobcat T590...
New/Unused Wolverine 72in Quick Attach Smooth Bucket (A65583)
New/Unused...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
