Battery Info
/ Battery Info #261
Whoa! Whoda thunk the Harbor Freight ones aren't the best technology possible?!?
Well, I strongly suspected that they aren't good maintainers, but didn't expect them to be simple power supplies.
I've been glancing into this thread and I've sorta lost track of the plot. Which HF maintainer model is it, that just dumps an 18 volt surge instead of high frequency?
My experience a decade ago was that HF's cheapest 'maintainer' eventually boils the water out of the battery, it apparently never shuts off. I replace that with a Battery Minder and no problem since.
/ Battery Info #262
read back. the noco genius one is dropping close to 19V in a BAD battery, this i believe is to be expected.
HF units do have consistency issues. there voltages range from 12.2 to 14.8 depending on batches. I tweak them with resistors to get 13.2, at 5 bucks it is what it is.
/ Battery Info #263
these noco's and everything else all they are doing is using a computer to PWM a higher voltage to "hopefully" break up the sulfication on the plates.
I've always thought that Canadus, BatteryMINDer and PulseTech use high frequency pulses instead of pulsing the voltage. At least that's what they claim.
This is my first (and likely last) NOCO maintainer, which could explain why I've never seen voltage fluctuations like this before.
/ Battery Info #264
yea a pulse of voltage what do you think the pulse consists of? high frequency and voltage go hand in hand, frequency simply means how many times per second/minute it hits it with higher voltage.
you seem to be blaming the noco, sounds more like the noco is finding bad batteries.
i have a lithium battery I will test this against later tonight.
/ Battery Info #266
Okay, maybe that one battery was bad, and no other maintainers or load tests had noticed that.
Or, it got sucked down by a cheap NOCO that then declared it bad. Time will tell as I'll do my best to resurrect it. Wish it was a single battery, not one of a pair.
Will try that NOCO on other batteries in the scrap pile, but not on a good one.
/ Battery Info #267
With dozens of vehicle batteries I'm always interested in advances in charging technology...
Many names in the industry making claims that most can only buy on faith.
I've brought back 6 volt batteries the distributor deemed bad and out of warranty by placing on my 30 amp sixty year old charger set on 12 volts as a nothing to lose chance and sometimes it will start cooking in 20 to 30 minutes and I the finish at the 6 volt charging rate.
/ Battery Info #269
Got curious enough about the high frequency desulfation I'm used to, versus pulsing voltage, to search a bit and found the following.
"BatteryMINDer® Model 1510 features a SmarTECHnology™ plug 'n run 1.5 Amp battery charger/maintainer with full-time automatic high frequency pulse desulfator (not high voltage)that can help extend a battery's life up to 4 times its normal life. Ideal for charging, maintaining or recovering 12V flooded, sealed, maintenance-free, starter, deep-cycle, Optima brand sealed AGM, and marine batteries."
Please note that they specifically point out that it's not high voltage, but high frequency.
/ Battery Info #270
That's the one that works well for me.
/ Battery Info #271
the guy at NAPA said that batteries only last 3 years on modern cars because of all the electronics on them that never turn off. Her battery was 3 1/2 years old. It looks like my battery is just over 3 years old.
Does this make sense to everyone?
He's the expert, listen to him!
Actually don't, lol
So that would make sense if the car is rarely used. Parasitic draw that takes the battery down to 90-95% between the car being run (and the battery topped up) is nothing.
My truck has a stereo that's "always on", and often there's a USB charger plugged in that's got a little red LED saying hello, but I still typically get 7 years out of my batteries - and this truck sits for weeks at a time.
My 2017 tractor has light bars that have an LED on the switch that's always on and the tractor's original battery still seems fine. Of course, an LED barley takes any power, but for an OEM battery coming up on 8 years old...
There's crappy batteries here and there; don't get the cheapest. Also don't get the most expensive; I aim for the middle.
/ Battery Info #272
Eddie, I used a borrowed gauge like this to find a parasitic draw on a car battery. It was drawing down 0.26 amps per hour. I then installed a trickle charger, and the problem disappeared. Seems the on-board computers were drawing current. The car could not sit for 5 days without an almost new battery going below its ability to start the car. I put the gauge between the battery terminal and the positive cable. Immediately saw the problem. Does the Massey have any on board computers?
/ Battery Info #273
I've got a couple of those. The model 1500/1510 are a step up from the old BatteryMINDer 12117 that is sold by Northern Tool (BatteryMINDer has discontinued selling that model anywhere else). My 12117 is over 20 years old and still working fine.
Also have a couple of their 1215C (which is similar electronically to the 1510, but in a more weatherproof case), a 2012-AGM model, a couple of higher-end models which have since been discontinued (12248 and 128CEC1 - both with multiple charging profiles and selectable charging amps), and a specialized aviation-specific 24V charger.
All of these have worked well. I've also been happy with their support. I had a minor problem with the display on one several years ago. Despite the fact that I told them the problem might have been caused by a power surge (lightning strike nearby popped several circuit breakers), they offered to repair it under warranty. Rather than send it in, I just had them send me a replacement display board and installed it myself.
/ Battery Info #274
Wow. 260 milliamps seems like a really high parasitic draw. Older cars were typically less than 50 mA. Modern vehicles generally run between 50-85 mA. I'd be checking for a light that's not shutting off or a stuck relay somewhere.
/ Battery Info #275
I called Battery Minder about 6 and 8 volt chargers and learned no offerings…
Having 13 six volt batteries and 1 eight volt I wanted to try the tech on seldom used vehicles.
I did put 2 6v in series and used my 12 volt minder and it charged.
/ Battery Info #276
Checked the formerly good battery - a measly 10.9 volts.
Hooked up the latest PulseTech purchase and immediately noticed a faint high pitched noise. Checked the voltage and it was slowly climbing in the 13.2 range. No wild voltage swings, just indications of high frequency at work.
Can this one fix what the NOCO damaged? I sure hope so, but still won't use these two as a pair anytime in the future.
/ Battery Info #277
Not sure the chargers do desulfation when in Lithium mode.
I am not really testing desulfation, just the voltage range its shooting out, I expect to see almost nothing on my bigger battery had time to think about it.
That said I will run the charger in lead acid mode. it won't really change much.
/ Battery Info #279
Can this one fix what the NOCO damaged? I sure hope so, but still won't use these two as a pair anytime in the future.View attachment 2105542
so i will say it last time, do what you want. what exactly do you think this high frequency pulse consists of?
high pitch whine actually indicates crappy inductor coil potting, but I'm done, Noco is the number one selling charger on the market, I never even heard of pulsertech before this.
if it works for you great. I'm out.
Fyi voltage almost means nothing. if you had a 10.9v battery (its shot already) and a 4 amp charger already brought it up to 13.2 and it not taking 10 hours, the battery is sulfated and has no capacity. I would love to see the SG and, go take the ah capacity and do the math, its not going to lie.
the noco would have to literally catch on fire to drop its capacity that much. sounds more like a shorted cell.
this now the 3rd battery you posted about having issues. Sorry but it seems your battery situation is in rougher shape than you think. I actually hate lead acid batteries. its why I switch everything I can to lithium
i got less then 10 cycles on a boat trolling motor battery that sat on a float charger its entire life.
/ Battery Info #280
It was horrible, I looked and looked, then told a buddy who worked at a car dealer which sold the same brand and he said that was about right. He said they were always installing batteries into new cars sitting on lot. They would just rotate batteries from charging stands to new vehicles. Another friend who worked at another dealer told me of the massive amounts of new batteries covered under warranty due to the fact if the battery fell below around 11.8 volts, then some of the sensors wouldn't work, and the vehicle wouldn't start. Additional problem was that some new vehicles have engine parameters set at factory, and if they lose battery charge then the dealer has to install new battery, then hook up vehicle to dealer computer to reset engine parameters.
1997 TSE UTILITY WIRE REEL TENSIONER (A62613)
1997 TSE UTILITY...
2013 Caterpillar TL9430 (A64126)
2013 Caterpillar...
2011 GALYEAN 130BBL (A65643)
2011 GALYEAN...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2007 CM TRAILER 18' T/A ENCLOSED TRAILER (A65643)
2007 CM TRAILER...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
