Battery Info
/ Battery Info #181
It's amazing that the vacuum tubes are still working!
/ Battery Info #183
We sometimes had to pull a tractor with the pickup solo to start it, and then quickly run back to the tractor to stop it before it hit the truck.
/ Battery Info #184
I have had extremely good luck with batteries over the years. I have had many cars that I bought new and never had to buy a battery for. Our Ford Fusion broke that streak, however. It has that start/stop feature. Researchers say that that makes the car do an average of 5,000 starts per year, instead of the 500 starts per year on most cars. It only lasted a little over 3 years, and it IS an AGM battery, almost $400 worth.
/ Battery Info #185
Recently bought a used Durango with that stop/start nonsense.
Disconnected the puny and expensive battery for that system, then pulled a fuse. No more pushing a button every time to prevent the stop/start crap.
/ Battery Info #186
Some battery chargers have a desulfation mode. Here is an interesting article about it.
Manufacturers of battery desulfators claim that through controlled bursts of high voltage, their products can reverse even the most severe cases of sulfating, restoring battery performance to like-new condition.
To test their claims, we rounded up two popular battery desulfatorsVDC Electronics’ Battery Minder and the Xtreme Charge by Pulsetechand two seemingly dead test subject batteries: A run-of-the-mill Autolite 84, and a lightweight dry-cell Buddy Club Racing Spec Battery.
https://www.motortrend.com/how-to/impp-1105-battery-desulfators-fact-fiction/
/ Battery Info #187
I deleted that on my f150
/ Battery Info #188
I wouldn't consider 14.8 volts a "burst of high voltage".
Not when I frequently see higher voltages in stock vehicles when they're just charging from the alternator.
/ Battery Info #189
I think it's more the (pulse) charge, rinse, repeat,,,,
/ Battery Info #190
My '19 Acadia has/had that start/stop, no separate battery, just the regular one. No defeat button in mine, but was able to find a gadget that goes in line with one of the battery cables that permanently defeats it. Apparently it tricks the car into thinking the battery is weak.
/ Battery Info
I just tried to start my tractor and the battery is dead. I ran it for over four hours a few days ago, and really expected it to fire up.
Volt meter read ten point six five volts on the terminals. I didn’t disconnect anything.
For some reason when I use numbers, it changes to something weird
/ Battery Info #192
This is a new battery? 10.6 typically means a cell has died inside. but based on your comments of needing to charge it out of the gate, I have some concerns there might be a parasitic load dropping it. do you have a dc clamp on meter, or a meter with a amp rating?
your going to have to determine if the battery is bad or if you have some kind of draw on the unit. this is easy with a sg meter or you can measure with the individual cells, but I am bit reluctant to tell people how to do that
/ Battery Info #193
My suggestion is to charge it up right away and keep it charged until you use the tractor. Disconnect the battery after you use the tractor and then see if you can wait a few days before trying to start it. If it's dead again, you will know the battery is the problem. Do you have another car or truck you can try swapping batteries with? I'm having similar problems with my old truck. It can go more than a month or even two ,with no problem. Other times it might be dead after four or five days. Being lazy, I just put it on a maintainer when parked. One day I will look for a parasitic draw but assume it's intermittent. I'm only using it to carry my snowmobile about once a week.
/ Battery Info #194
I use a battery disconnect on the dozer and that battery can go 6-9 months and still start…
If I was in the neighborhood I’d come over with my battery tester…
No one wants to think a new battery is bad but it happened to me once…
Parasitic draw has happened many times… car lot they would put me in the trunk to check if the trunk light stayed on and yes it did a few times on various cars.
It could be the battery is ok but what kind of reading are you getting on the battery dash gauge when running?
/ Battery Info #195
The battery from my truck must have had a dead cell (10.6v) too and charging it had the numbers all over the place. I had a spare red top optima that has been in the truck for a few years now while I wait to get a replacement. Unhook the battery and charge it to 12.8v + then let it sit for a couple days. It should hold voltage....if not, take it back.
/ Battery Info #196
Four hours is not long enough to fully charge a completely discharged battery.
But it's hard on the alternator to try doing it that way.
/ Battery Info #197
that completely depends on the charge current.
/ Battery Info #198
it can be a bad battery or it can be a drain from the tractor itself draining it.
/ Battery Info #199
Yes, but I've found that a battery is noticeably happier after several hundred miles of driving - and that's starting with a battery that's already at 12.5 V or better, and a 220 A alternator.
With a typical maintainer (1.5 to 5 A) it seems to take about two weeks to get the same result.
And speaking of maintainers, it might have been in this thread that someone recommended a very affordable Noco Genius. Well, I bought one. Two days ago it was connected to a used but charged and good battery, basically just to have it do something.
It reached the fully charged state the next day, but this morning it had the "bad battery" icon lit, and the formerly good battery was now at just over 11 volts. Started over, it shows it's charging, and the voltage is up as it should be. Maybe it was a fluke, but I'll never trust that one again.
11in. Tooth Excavator Bucket (A64194)
11in. Tooth...
2007 Mazda 3 Hatchback (A61574)
2007 Mazda 3...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
Doyle Conveyer with Honda Engine (A63688)
Doyle Conveyer...
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63689)
1986 Ford LN8000...
