Bridge Ideas for multiple creek crossings
   / Bridge Ideas for multiple creek crossings #31
Around here people use 3 ton or school bus frames for pivot bridges. Two of them set side by side would be adequate for vehicle use if covered with 3 by xx wood that is bolted down. I would make sure the frames are centered with the vehicle tracks.
I would also just make one bridge that is suitable for vehicles/tractors and the others can be lighter for quad/pedestrian use only.
A concrete footing poured either in place or transported during the dry season would make sure the bridges lasted a long time.
Just my thoughts.
   / Bridge Ideas for multiple creek crossings #32
There have been some great ideas posted here, for 20 and 40 foot spans. But I think everyone is forgetting that the OP's crossings are just 3 to 7 feet. I could've had the culvert pipes delivered, installed and buried, in half the time this thread has played out! :ROFLMAO:
Go concrete, if money is no object. Otherwise, get yourself some corrugated culvert pipes of diameter equal to the crossing width, excavate, drop them in, pour some gravel to top of pipe to lock them in, and then top all that with dirt and grass to keep the gravel in place. If you really want to go the extra mile, stack bagged concrete around each end, as headwalls, they actually look like stacked rock after the bags deteriorate and wash away. You could have several done in one day, esp. if you know anyone handy with a mini-excavator.
   / Bridge Ideas for multiple creek crossings #33
I replaced a failed logging bridge at the outlet of a swamp with a culvert. It was doable but not that easy.
Pull out old bridge and dig a culvert trough in the muck.
Set Culvert
Cover and cushion with 3/4" gravel.
Bring gravel one bucket at a time 1/4 mile down skidder road from closest landing.
Beef up culvert covering and trail with 3-1/2" road base.
gg
   / Bridge Ideas for multiple creek crossings #34
A factor two, squared (2x2) was four, last time i calculated a bridge
I said cubed, not squared, so 2x2x2, which is 8. It is not intuitive. Twice as tall is 8 times stiffer. Not twice as stiff.
Eric
   / Bridge Ideas for multiple creek crossings #35
Eric
Then you said it wrong: lets do the math:
Bend resistance is 1/12 times breadth times width cubed, divided by the exterior fiber distance. In case of square beams, exterior fiber distance is half height.
2 by 4 is 1/12 x2x4x4x4 divided by two is 5.33
2 by 8 is 1/12 x2x8x8x8 divided by four is 21.3
21.33 divided by 5.33 is four, not eight.
You are confusing the moment of inertia (cubed) with the bend resistance (squared because bend resistance is moment of inertia divided by the most exterior fiber distance. 👌
   / Bridge Ideas for multiple creek crossings #36
Hold on while I get a bag of popcorn to watch this drama...
   / Bridge Ideas for multiple creek crossings #37
4 of the 5 crossings are just 18" deep, 1 is about 3' deep. I would prefer a bridge to a low water rock crossing so I can cross at anytime. Also with all of these crossings being in timber areas pine straw, oak leaves and branches will clog the culverts like they do at all of the road crossings
With a bridge this low it will be impossible to clean under it. Atleast with an 18' culvert you can fabricate something to drag through it. an 18" clearance under the bridge is a recipe for trouble. Every example shown of bridges posted so far has 3 feet or more clearance to bottom of stream.
@Gordon Gould photo shows what happens with low clearance bridges and their lack of viability.
Putting a trash guard or beaver cone will reduce some of the clogging issues, as does digging a settling hole in front of the culvert inlet. I have a 8" culvert 100' long that gets full of leaves and sticks and putting a settling hole in front mostly cured the clogging issue.
I can get oak boards for the decking done for just the cost of having them cut up as we loose oak trees every year.
The issue I have with culverts is we do a lot of controlled burns here so that would make me install galvanized culverts,
If plastic pipe is a problem with controlled burns how is wood decking going to work? On the levees I did we would bury make sure the pipe was completely covered on the top with dirt to reduce the embers landing on them. Then before the controlled burn we would disc around them so the fire could not reach them. A wood decked bridge would be very susceptible to catching on fire during or shortly after a controlled burn even with a firebreak around it as embers would land between the decking and beams potentially starting a fire long after the burn was done.
I know it seems as if I am pushing a culvert and ignoring the bridge option but I do not see how it is viable for this situation. @WinterDeere sums it up well.
@Renze That sounds like an impressive bridge. Any photos of it?
   / Bridge Ideas for multiple creek crossings #38
Bridges want to fail. It's just a matter of when that happens. The more wood that you use in your bridge, the sooner something will fail. If you are dead set on building a bridge, the next question you need to ask is how long do you plan on using it? Are you young and expect to use this bridge 50 years from now? Are you retired with a decade or so of time left that you'll be needing it?
From what you have said in your original post, it does not sound like you have a lot of experience in framing. Your choices of materials listed to build the bridge are not what I would use. Even more important then what you use to build the bridge is what you use to support it. That needs to be the first question.
Culverts are simple, affordable, and if sized big enough, will last for a century. If they fail, it's easy enough to fix it and use it again.
Even easier is to just dump a lot of large rock in the bottom of the crossing.
A long time ago a man I knew had one large creek to cross when building his house. He found scrap semi-oil tanker trailer. Had it towed to his place, removed the tank from the frame and cut-off the ends, then had a man that build ponds/lakes prepare the creek-site and put the tank in place. Then he flattened the tank to fit with the track-hoe bucket.
Once the back-fill was completed, it became part of the crushed stone driveway.
   / Bridge Ideas for multiple creek crossings #40
Sorry, was at my mate this afternoon in the shop, but didnt think of making a photo.
I would also like to see a photo of your work. Satellite view was hard to see the details.
2013 GREAT DANE 53FT REEFER TRAILER (A59905)
2013 GREAT DANE...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2024 PRO FABRICATION RTM-5.2K-Y REEL TRAILER (A59905)
2024 PRO...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
1994 Chevy 2500 Pick Up (A59814)
1994 Chevy 2500...
