Bridge Ideas for multiple creek crossings
   / Bridge Ideas for multiple creek crossings #1
Mallard1
Arkansas
John Deere 4320
I have at least 5 creek crossings I would like to put in bridges to make it easy to cross sides, in the summer they are completely dry but in winter it is muddy when trying to cross with side by side and only one of the crossings can I get a truck across during the summer.
requirements for the bridge will be to allow tractors, 3/4 ton truck etc not to exceed 10k lbs. most of the traffic will be UTV traffic. tractor, truck traffic will be as needed probably not more than once a month.
the crossings range from 3' to probably 7' across. I plan to make the bridges 10' wide and vary the length depending on the crossing length.
I have considered a couple different designs but wanted input from others that have already done this.
Idea 1 - telephone polls spanning the crossing with 2x6 decking screwed down
Idea 2 - used cross ties spanning the crossing with 2x6 decking screwed down
Idea 3 - build cattle guard out of 2-7/8 oil field pipe
Idea 4 - 4x6 or 6x6 boards spanning the crossing with 2x6 decking screwed down.
thanks for any help!
   / Bridge Ideas for multiple creek crossings #2
I have not done it but the previous property owner did.
The bridge was constructed in 1984 and is approx. 20 ft long constructed from creasoted power poles and 2x6s. The previous owner drove his 1/2 ton pickup over the bridge.
Unfortunately, they did NOT use treated 2x6s. The 2x6s have mostly rotted away but the creasoted power poles are still there and appear to be in good condition.
The previous owner had access to power poles thru their employer (power company), likely at a discount which may have influenced the choice of materials.
   / Bridge Ideas for multiple creek crossings #3
Fords, or scrap flatbed semi-trailers. Might get two or three short bridges from a long trailer.
Bruce
   / Bridge Ideas for multiple creek crossings #4
Traditional method was to use white oak tree trunks plus white oak saw milled planks. You might look for a sawmill in your area and ask if they can saw some bridge planks for you.
I thought people usually went with three large trunks across the creek, but looking at the remains of a former creek bridge recently, I counted the remains of five trunks.
   / Bridge Ideas for multiple creek crossings #5
Whatever route you take, you need to think carefully about the footings at the end of the bridges. You don't mention this but without a good footing like a deep poured concrete pier, it will move on you.
For dimensional treated lumber, 4x4 or 6x6 isn't the best choice. Depth gives you strength. Build it up with 2x8 or 2x10. You can find beam capacity charts for lumber on line.
   / Bridge Ideas for multiple creek crossings #6
Beam stiffness changes by the cube of the change. So a beam twice as tall is 8 times stiffer.
Eric
   / Bridge Ideas for multiple creek crossings #7
Bridges are high maintenance and require very stout footings on each end. The bridge deck is only a part of the cost of the bridge, the footings on each end are were the money is at.
If your creeks are deep (5'+) I would perhaps consider a bridge. However what your stating a culvert would be a better choice. There is a reason that if the crossing is less than 20' highway departments use culverts over bridges, cost to install and cost to maintain are both lower. I have used railroad tank cars as a large culvert when needed, should last 50+ years.
I would also go 12' wide. A trailer can be 8.5' wide, with only 10' overall width your going to have 9" on each side. 9" is darned scary to take a trailer over.
Post some more details along with photos and measurements of each crossing and the folks here will be glad to give their 2 cents.
   / Bridge Ideas for multiple creek crossings #8
Plan ideal-1 would work IF you will string more poles across. Do not use two and call it a day like this guy did.
I would do 4, here is 3.
Masonry is ideal at each end.
The best bridges are semi-trailer frames. Cost is sky high.
Or find on CraigsList old mobile homes that need to be removed. Then use the bottom frame.
   / Bridge Ideas for multiple creek crossings #9
   / Bridge Ideas for multiple creek crossings #10
   / Bridge Ideas for multiple creek crossings #11
Sportsman beat me to it, but I'd be using large culvert pipe for all or most of your 3 - 5 ft. crossings. Easy, quick, strong, and long-lasting... almost everything any bridge is not.
If you use concrete culvert pipe, it's commonly available up to 108" (9 feet) diameter. I think plastic corrugated usually stops around 72" (6 feet) diameter.
<-- has bridges in need of replacement
   / Bridge Ideas for multiple creek crossings #12
The true bridge planks I remember were not 2x (actual 1.5 inch) pt from the box store but something more like actually 3 inch or more thick oak. They were spiked to the tree trunks used as beams with some very large nails.
WinterDeere is likely right that culverts would be less expensive and longer lasting than trying to span a short distance with a bridge.
   / Bridge Ideas for multiple creek crossings #14
Have you seen the simple design used for skidder bridges. These are for 30,000 lb loads so can be scaled down for your use. They are 4' panels for mobility. I plan on making one using this concept 8' wide using 6x6's spaced with 2x4's.
   / Bridge Ideas for multiple creek crossings #15
Hey I recognize that footing! :) Such a fun project.
I pretty much just used what I had around, spare CMU blocks, 3 course high on each side. Has held up very well so far.
I only had 3 telephone poles, really wish I had 4 or 5 underneath my decking. But thankfully my decking is double-layered, old-school treated 2x6s that should last a nice long time.
   / Bridge Ideas for multiple creek crossings #16
Bridges want to fail. It's just a matter of when that happens. The more wood that you use in your bridge, the sooner something will fail. If you are dead set on building a bridge, the next question you need to ask is how long do you plan on using it? Are you young and expect to use this bridge 50 years from now? Are you retired with a decade or so of time left that you'll be needing it?
From what you have said in your original post, it does not sound like you have a lot of experience in framing. Your choices of materials listed to build the bridge are not what I would use. Even more important then what you use to build the bridge is what you use to support it. That needs to be the first question.
Culverts are simple, affordable, and if sized big enough, will last for a century. If they fail, it's easy enough to fix it and use it again.
Even easier is to just dump a lot of large rock in the bottom of the crossing.
   / Bridge Ideas for multiple creek crossings #17
What is the weight and how does it get moved?
Thanks for all of the quick replies and good advice. rather than quote everyone I will do my best to answer the questions all at once.
The choice of materials was mostly based on what I have on hand right now, I have an endless supply of free 2-7/8 pipe, I can get oak boards for the decking done for just the cost of having them cut up as we loose oak trees every year.
4 of the 5 crossings are just 18" deep, 1 is about 3' deep. I would prefer a bridge to a low water rock crossing so I can cross at anytime.
The issue I have with culverts is we do a lot of controlled burns here so that would make me install galvanized culverts, also with all of these crossings being in timber areas pine straw, oak leaves and branches will clog the culverts like they do at all of the road crossings. after every hard rain I have to clean all of them out and with a bridge most of that will flow underneath.
at another property we have we have several bridges that are 4 telephone poles, two per side and then decked with shaker screen from a rock quarry and they have been holding up for 20+ years, however this is just for UTV traffic not truck or tractor traffic.
most of these crossings will look very similar to the youtube video posted by bmaverick except lots of trees all around.
I will try and get a few pictures this weekend of what I am looking at.
the stream is not very fast even during a hard rain, there is about 10' of elevation change over the course of 500 yds straight line distance but the creek winds the whole way so it moves slowly.
   / Bridge Ideas for multiple creek crossings #20
I was on a farm that bridged irrigation ditches with concrete slabs about 8 feet square, 4-6 inches thick. No idea what was inside the slab. Ditches were 4-5 feet wide.
Bruce
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
Alamo SHD96 Flail Mower
Alamo SHD96 Flail...
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
