Stuck yanmar 165D
/ Stuck yanmar 165D #101
Take that chain off so you Can You can even try to turn the Eng. Sounds like that might pushing it the way this thread is going. :rolleyes:
/ Stuck yanmar 165D #102
I believe that the running rotation of the engine is clockwise if you stand in front of the tractor and look at the front of the engine. Someone with a YM135/155/165 please check on that.....
rScotty
Likely clockwise. YM240 a slightly larger Yanmar from the same era, is clockwise rotation as seen from the front.
I painted a down-arrow on its generator pulley shield that sticks out slightly from the left side of its hood.
/ Stuck yanmar 165D
Yeah, I'm going to try rotating with that cuppler off tomorrow
/ Stuck yanmar 165D
Ok, what is the trick to removing chain coupler? I found the master link and separated that, now what?
/ Stuck yanmar 165D #105
With the clip and that side, side plate removed, with luck you will have room to slid the rest of the master link out the other way as it goes past center the inner plates will come out.
Here is a pic of a disassembled one;
/ Stuck yanmar 165D
It wouldn't budge. Will soak it overnight
/ Stuck yanmar 165D #107
good start, a new master link is very inexpensive.
A little pry bar or hammer and punch may be needed.
If all else fails cut it out and replace it.
/ Stuck yanmar 165D
I tried a long screwdriver and put it on the back link and tried tapping it out, no such luck
/ Stuck yanmar 165D #109
I suspect heat and lubricant are your buddies on this one. If you have reasonable access to the key link side, I would try a long punch.
All the best,
Peter
/ Stuck yanmar 165D
I may end up draining radiator and taking it off for easier access
/ Stuck yanmar 165D
Ok, this is what I got. I decided to get the tractor off the trailer and try dragging it a bit. Hooked the side by side up to it on concrete. With it completely in neutral and easing it forward, it rolled with a couple catchy spots then I we stopped. Now, I put it into 6th gear and depressed clutch and told my daughter to put some tension on and go for it. Tires stopped spinning and side by side was dragging the non free wheeling tractor. Popped to back out of gear and daughter began pulling again then I depressed clutch and dumped it into 6th (could hear gears grind prior to going into gear) then the rear tires locked up again. So, with this, thoughts? Clutch froze?
/ Stuck yanmar 165D #112
And again, we are back to splitting the tractor since page 8 of this thread. :unsure:
/ Stuck yanmar 165D
It wasn't a fair try the first time I tried it on gravel, so I wanted to do it on concrete first. I wasn't able to really do this back on page 8
/ Stuck yanmar 165D #114
Good data.
Clutch, or flywheel would be my guess, and yes that brings back the idea of splitting the tractor to get to them.
All the best,
Peter
/ Stuck yanmar 165D #115
Try turning that pump shaft yet? Read back real quick and don't see that mentioned. If not just unbolt the Hyd. pump itself and it should only be a couple and pull back off the shaft. Then your know your splitting it. Should be super easy and only minutes to check it.
Easier than the Radiator to do it if I recall looking at the Pic.. Not stuck may as well order some new rings with that head gasket and clutch parts. Then that motor will last another 40+Yrs. Make it worth the while. The nasty Bell houseing was the first real sign of the problem.
/ Stuck yanmar 165D
I thought about pulling the hydraulic pump, but didn't know if messing with something under pressure would be smart of me
/ Stuck yanmar 165D #117
I figured that but your see how easy it would be compared to the Radiator. That chain must not have much wear to it. With the link/clip no wanting to come out. Good thing again! That pump will slide off that shaft. From out of the Eng. Pulley Coupler or the pump itself. Then the good thing is you covered pretty much all possibilities! Super Nasty Bell housing LOL.. True though!
/ Stuck yanmar 165D #118
The hydraulic system will not be under pressure without the engine driving the pump and a valve restricting it's flow.
/ Stuck yanmar 165D
Ok, I will give that a try sometime today......then, I'm going to study over the mid section of this tractor and ponder long and hard on whether I want to give a split a try
/ Stuck yanmar 165D #120
Wouldn't be real hard for anyone that has right jacks , jigs and space.
You'll have to hold the tractor in 2 parts while pulling apart which could get tricky.
2025 Kubota L4060D 42HP 4WD Utility Loader Tractor (A64553)
2025 Kubota L4060D...
2015 Ford F-150 Pickup Truck (A64556)
2015 Ford F-150...
2016 CATERPILLAR D6K2 LGP CRAWLER DOZER (A65053)
2016 CATERPILLAR...
2012 Ram 1500 Crew Cab Pickup Truck (A64556)
2012 Ram 1500 Crew...
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
2005 20 Ft. Grady-White Boat with 25 Ft. Float-On T/A Boat Trailer (A64557)
2005 20 Ft...
