careyo63
Elite Member
- Joined
- Jan 6, 2012
- Messages
- 2,785
- Tractor
- 77 Yanmar YM2000 63 Ford 2000
Take that chain off so you Can You can even try to turn the Eng. Sounds like that might pushing it the way this thread is going.
Likely clockwise. YM240 a slightly larger Yanmar from the same era, is clockwise rotation as seen from the front.I believe that the running rotation of the engine is clockwise if you stand in front of the tractor and look at the front of the engine. Someone with a YM135/155/165 please check on that.....
rScotty
good start, a new master link is very inexpensive.It wouldn't budge. Will soak it overnight
I suspect heat and lubricant are your buddies on this one. If you have reasonable access to the key link side, I would try a long punch.I tried a long screwdriver and put it on the back link and tried tapping it out, no such luck
And again, we are back to splitting the tractor since page 8 of this thread.Ok, this is what I got. I decided to get the tractor off the trailer and try dragging it a bit. Hooked the side by side up to it on concrete. With it completely in neutral and easing it forward, it rolled with a couple catchy spots then I we stopped. Now, I put it into 6th gear and depressed clutch and told my daughter to put some tension on and go for it. Tires stopped spinning and side by side was dragging the non free wheeling tractor. Popped to back out of gear and daughter began pulling again then I depressed clutch and dumped it into 6th (could hear gears grind prior to going into gear) then the rear tires locked up again. So, with this, thoughts? Clutch froze?
Good data.Ok, this is what I got. I decided to get the tractor off the trailer and try dragging it a bit. Hooked the side by side up to it on concrete. With it completely in neutral and easing it forward, it rolled with a couple catchy spots then I we stopped. Now, I put it into 6th gear and depressed clutch and told my daughter to put some tension on and go for it. Tires stopped spinning and side by side was dragging the non free wheeling tractor. Popped to back out of gear and daughter began pulling again then I depressed clutch and dumped it into 6th (could hear gears grind prior to going into gear) then the rear tires locked up again. So, with this, thoughts? Clutch froze?
The hydraulic system will not be under pressure without the engine driving the pump and a valve restricting it's flow.I thought about pulling the hydraulic pump, but didn't know if messing with something under pressure would be smart of me
Wouldn't be real hard for anyone that has right jacks , jigs and space.Ok, I will give that a try sometime today......then, I'm going to study over the mid section of this tractor and ponder long and hard on whether I want to give a split a try
