Stuck yanmar 165D
/ Stuck yanmar 165D
He will start it as soon as all my parts from Hoye come in and he puts it back together
/ Stuck yanmar 165D #142
When new, the Yanmar YM165d came standard with ag tread. The turf tire option was about a thousand dollar adder. You can't swap between turf and ag tires withot also swapping the wheels.
Are we certain that the front (or rear) ring & pinion ratio is the same, between Yanmars with turf tires or ag tires? Or maybe a there's a different ratio inside the transmission depending on tires?
I thought I saw somewhere that ag vs turf needed to be specified to get the right replacement parts.
And I'm pretty sure there is a difference in ratios listed in the parts books, among Japan / US / Britain / Europe markets, depending on the local tire specs.
Anybody know if this is relevant for this US YM165D?
/ Stuck yanmar 165D #143
Scotty I thought it was you who posted long ago that their little Yanmar stays in 4wd continually because it is operated only on loose ground. No, somebody else?
My YM186D 4wd shifter is real stiff, apparently from seldom being shifted. An urban landscape contractor was the first owner so the tractor must have seen a lot of pavement in its first 30 years, as well as being operated by inexperienced labor. No evidence of damage.
I only shift to 2wd if I get out on the unpaved lane, to exercise the shifter and keep it usable. The orchard here is all disced, rough to drive on, so I assume the ground is loose enough to slip and avoid damage.
/ Stuck yanmar 165D #144
This is 5103 Fm. Rear AG 13.6-28 And they work really well also. Turf tires in Ga. are rare. High dollar place 38 acres! :cool:
/ Stuck yanmar 165D
Both tires in the links I sent are same specs except .5" difference in diameter of my turf front. Since I won't have it in 4x4 all the time and only when needed, I figured it wouldn't hurt.
/ Stuck yanmar 165D #146
No 4wd. on any of my tractors in Ga.. The Ford has AG. rear also. Anti freeze for weight and they don't bother my yard. My profile pic. is the front yard. Loader on it. Cold weather WV. Mtns. where I'm from Org. I would have it for the Mtn's and snow season no doubt!
/ Stuck yanmar 165D
Anyone know where a flywheel ring gear for this 165D would be?
/ Stuck yanmar 165D #148
Not me. I only use 4wd for short distances as necessary.
A stiff 4wd shifter when trying to shift OUT of 4wd almost always means that there is "wind up" somewhere in the 4wd mechanism because the tires couldn't slip. An easy diagnosis is to use the loader to lift the front wheels. If it suddenly is easy to shift out of 4wd, it was because there was windup and now the tires can suddenly unwind. Often only a fraction of an inch. ..hopefully the torsional windup is only in the front driveshaft, not the tranny.
Probably the dirt let them slip just enough.
rScotty
/ Stuck yanmar 165D #149
And whale fat grease!!
/ Stuck yanmar 165D
/ Stuck yanmar 165D #151
Musta been someotherbody.
I'm familiar with windup, driveline tension, after owning a couple of old 50's Willys Wagons and then 70's Wagoneers. The way to unwind them, was to back up in a zig zag pattern while pulling lightly on the 4x4 shifter. That also works for the Yanmar.
But this one's shifter is stiff even after lifting the front with the loader. I've seen posts about breaking the internal parts of the 4x4 shifter and think about that every time I have to shift it.
/ Stuck yanmar 165D
Thanks....lifesaver!!
/ Stuck yanmar 165D #157
Might be bent shifter. Do some experiments,,,is it is also hard to put into 4wd?
BTW, our old Willys had a small block Chevy & OD. Girlfriend is driver. My horse Dewey is in the trailer - Dewey was a huge 16 hand Appy who was always willing to squeeze into that tiny trailer & go for a ride. Wish I still had them all.
rScotty
/ Stuck yanmar 165D
Does anyone know the differences in liner specs of 2TR13A vs 2TR15A other than 75mm vs 80mm bore? Are they both dimensionally the same otherwise?
/ Stuck yanmar 165D #159
#RS-400 724066-25501 / 705400-22503 1300 / 155 / 165
#RS-450 721450-22500 1401 / 169 / 180
/ Stuck yanmar 165D
I know the part numbers, I'm just curious if a 15 sleeve will fit in a 13? If they are dimensionally the same other than 75 vs 80 mm bore? I wonder how a square block (2.9" bore with 2.9" stroke) 2TR13A would work with the bigger piston making it oversquare. However, I would prefer an undersquare (torque)
