mowers
/ mowers #41
good point...my automotive instructor in my youth said, "1st, look under the hood in the dark for ign problems", often overlooked
/ mowers #42
Ive loved my commercial Hustler for the past 5 years 👍
I have a 2005 Hustler Super Z that I bought new and it is still going strong, I cut about 4 acres weekly and usually double cut the lawn. Takes about 3 hours to double cut everything. Hustler gets my vote for quality of cut and reliability...
/ mowers #43
Exmark
Deere
Hustler
Observe what the pros in your area are running, you’ll never go wrong copying them.
/ mowers #44
I think Exmark is the most popular-probably for good reason. Skag is another top commercial mower. I cut a hundred lawns a week for years. I am well pleased with the Hustler brand and would buy again if the need arises...
/ mowers #45
2010 Gravely Pro Turn HD 160. Still going strong. I think Gravely make a great mower. If I were to buy new though, I would strongly consider the Ferris with suspension. My back is not in the best shape and I would like to take some of the jolts off it.
/ mowers #46
Where's the OP, with the info requested??? 43 reply posts, and only a "thanks" - so far... :mad:
/ mowers
bought a toro , titan thanks , thanks thank you for your valuable time
mowed last nite , first time no bumps or bruises on the mower hope it stays that way , that kawasaki has some power , now my Jd lx 280 is going down the road
/ mowers #49
If the quality of cut is so good, why do you have to double cut? Not trying to be a wise a$$, just curious
/ mowers #50
So quick scan did not reveal details of what little I have learned so here it goes.
I bought a Gravely 48", wish I didn't overthink it and got the 52".
Why a Gravely? Because my local tractor dealer in Shiner and treats me well.
Having said all that here is what I learned. The first time it slung a belt, wow what a deal.
Once in the barn, saw how accessible the two belts really are.
A rope with a good handle to remove tension spring and reinstall belt and done!
Now, over time have tried to help a guy with same issue on a scag. The undercarriage on many others are so packed that field re-installs can be really difficult!
So will you be taking it in for service or are you a DIY guy?
Look at you own weight, slops on property and then look at the lb-ft of the Hydros on the mowers.
The ZT2800 would not have the torque to haul me back up a slopes we have on our property.
Mine has the ZT3200 and I service them, easy peasy to do.
Hope this tidbit helps.
Be well all...
/ mowers #51
congrats on the new mower
Great question Duds13--I have always been particular about how my lawn looks. When I double cut the lawn the second cut is at a different angle. When finished it gives my lawn a look that I call plaid, some call it diamonds. For the record I don't have to double cut, it looks great with a single cut too, but as stated earlier I like the look that I get when I double cut the yard!! My saying is "I'm so glad it's plaid!!"
/ mowers #52
Makes total sense! I get that plaid look as well even after waiting a couple days in between mowing. love the plaid look!
/ mowers #53
If I were only cutting once per week in May, I’d have to double cut, too. Sometimes weather restrictions force that, but I normally try to mow every 3-4 days in spring. By late June, that slows way down, and I can often go July 4 - August 15 with just two or three mowings over a six week stretch, but our grass grows more than a half inch per day in spring.
Figure 4” cut height, half inch per day, you’re cutting 6” down to 4” after four days. That’s the recommended 1/3 maximum recommended.
If I let my lawn go more than four days in normal spring weather, it looks like I’m preparing to bale hay, after cutting.
/ mowers #54
I use the "mow high, mow often" theory. Spring and fall grass is crazy though, and like you said it's starting to slow down and it's been a bit dry here recently.
/ mowers #56
lookking to buy a zero turn , what should i get , what should i stay away from
There are others of course and most like the one they have. Just stay clear of big box stores, buy commericial, and U should be good for a long time.
/ mowers #57
IS Ferris the only one offering this good suspension I'm reading about here? what about Imark, JD or others.
/ mowers #58
The Stihl mowers are made by Ferris and have the same suspension. I used mine all afternoon today on some bumpy ground and it was comfortable on my back.
36in AIM Tooth Excavator Bucket (A64194)
36in AIM Tooth...
2021 BOBCAT T62 R-SERIES SKID STEER (A64279)
2021 BOBCAT T62...
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2016 Ford F-250 4x4 Pickup Truck (A61573)
2016 Ford F-250...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
