mowers
/ mowers #41
good point...my automotive instructor in my youth said, "1st, look under the hood in the dark for ign problems", often overlooked
/ mowers #42
Ive loved my commercial Hustler for the past 5 years 👍
I have a 2005 Hustler Super Z that I bought new and it is still going strong, I cut about 4 acres weekly and usually double cut the lawn. Takes about 3 hours to double cut everything. Hustler gets my vote for quality of cut and reliability...
/ mowers #43
Exmark
Deere
Hustler
Observe what the pros in your area are running, you’ll never go wrong copying them.
/ mowers #44
I think Exmark is the most popular-probably for good reason. Skag is another top commercial mower. I cut a hundred lawns a week for years. I am well pleased with the Hustler brand and would buy again if the need arises...
/ mowers #45
2010 Gravely Pro Turn HD 160. Still going strong. I think Gravely make a great mower. If I were to buy new though, I would strongly consider the Ferris with suspension. My back is not in the best shape and I would like to take some of the jolts off it.
/ mowers #46
Where's the OP, with the info requested??? 43 reply posts, and only a "thanks" - so far... :mad:
/ mowers
bought a toro , titan thanks , thanks thank you for your valuable time
mowed last nite , first time no bumps or bruises on the mower hope it stays that way , that kawasaki has some power , now my Jd lx 280 is going down the road
/ mowers #49
If the quality of cut is so good, why do you have to double cut? Not trying to be a wise a$$, just curious
/ mowers #50
So quick scan did not reveal details of what little I have learned so here it goes.
I bought a Gravely 48", wish I didn't overthink it and got the 52".
Why a Gravely? Because my local tractor dealer in Shiner and treats me well.
Having said all that here is what I learned. The first time it slung a belt, wow what a deal.
Once in the barn, saw how accessible the two belts really are.
A rope with a good handle to remove tension spring and reinstall belt and done!
Now, over time have tried to help a guy with same issue on a scag. The undercarriage on many others are so packed that field re-installs can be really difficult!
So will you be taking it in for service or are you a DIY guy?
Look at you own weight, slops on property and then look at the lb-ft of the Hydros on the mowers.
The ZT2800 would not have the torque to haul me back up a slopes we have on our property.
Mine has the ZT3200 and I service them, easy peasy to do.
Hope this tidbit helps.
Be well all...
/ mowers #51
congrats on the new mower
Great question Duds13--I have always been particular about how my lawn looks. When I double cut the lawn the second cut is at a different angle. When finished it gives my lawn a look that I call plaid, some call it diamonds. For the record I don't have to double cut, it looks great with a single cut too, but as stated earlier I like the look that I get when I double cut the yard!! My saying is "I'm so glad it's plaid!!"
/ mowers #52
Makes total sense! I get that plaid look as well even after waiting a couple days in between mowing. love the plaid look!
/ mowers #53
If I were only cutting once per week in May, I’d have to double cut, too. Sometimes weather restrictions force that, but I normally try to mow every 3-4 days in spring. By late June, that slows way down, and I can often go July 4 - August 15 with just two or three mowings over a six week stretch, but our grass grows more than a half inch per day in spring.
Figure 4” cut height, half inch per day, you’re cutting 6” down to 4” after four days. That’s the recommended 1/3 maximum recommended.
If I let my lawn go more than four days in normal spring weather, it looks like I’m preparing to bale hay, after cutting.
/ mowers #54
I use the "mow high, mow often" theory. Spring and fall grass is crazy though, and like you said it's starting to slow down and it's been a bit dry here recently.
/ mowers #56
lookking to buy a zero turn , what should i get , what should i stay away from
There are others of course and most like the one they have. Just stay clear of big box stores, buy commericial, and U should be good for a long time.
/ mowers #57
IS Ferris the only one offering this good suspension I'm reading about here? what about Imark, JD or others.
/ mowers #58
The Stihl mowers are made by Ferris and have the same suspension. I used mine all afternoon today on some bumpy ground and it was comfortable on my back.
2007 Toyota Camry Sedan (A61574)
2007 Toyota Camry...
2019 VOLVO L90H WHEEL LOADER (A65053)
2019 VOLVO L90H...
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
Caterpillar 613C Wheel Tractor Scraper Service and Parts Manuals (A63117)
Caterpillar 613C...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A61572)
2023 Caterpillar...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
