Oil & Fuel fuel injection pump
   / fuel injection pump #1
sheldon1968
2022 Kioti CX2510
Anyone tell me where the FUEL INJECTION PUMP is located on a 2022 Kioti CX2510........I think I may have a problem as it will not start...turns over but will not start
the dealer is sending me a new Solenoid so hopefully that works
   / fuel injection pump #2
Fuel injection pump is major (only for a qualified tech to touch)and the last thing to check after everything else. Wait for the solenoid or switch similar relays around….one at a time.
ps. make sure there’s fuel in the tank 🥴
Will do...thank you Sir
Is it difficult to remove the old one and replace it?? this is my first tractor and I'm definitely no mechanic
   / fuel injection pump #5
The injection pump is the last thing to check….incase you missed that!!!
Maybe start by telling us how many hours are on the tractor? Is there any warranty on it? Has it had a complete service….ever, which includes all engine and transmission oil fluids with filters? At a dealer or by you? Have you run it out of fuel? If so then the fuel system needs to be purged of air. How long since the fuel filter was changed? Do you buy diesel at a popular/ busy station? Have you filled it with gasoline by accident? Is it stored inside?
With your very apparent ignorance of how a diesel engine runs/operates, I dare you to touch it and find out how deep your pockets are. Which now makes me wonder how it’s been looked after…
   / fuel injection pump #6
Is the tractor still under warranty? If so, let the dealer diagnose for you.
I would suspect a voltage problem. A fuse or corroded connection possibly. To find out one would start by measuring voltage at the solenoid and work backwards through the circuit.
Forgive the harshness of some on this site. They forget they once did not understand mechanical things. There is still plenty of folks willing and capable of helping.
   / fuel injection pump #7
A diesel that cranks, but won't start is almost always fuel related. Sometimes secondary to an electric problem like the fuel shutoff solenoid.
The important points being made, are that there are a long list of things to check before looking at the injection pump.
The fuel shutoff solenoid could have been tested rather than seemingly blindly replacing it. That was a real stab in the dark by the dealer, but perhaps there is more to the OP's situation.
I personally would begin by checking for proper fuel flow at all points from the tank out. Messing with a potentially operating injection pump is likely to get very costly for the average owner, even if mechanically inclined.
   / fuel injection pump #8
If my yelling keeps him from poking and prodding when he doesn’t have a clue…it’s served my purpose. The op asked a second time how to remove the injection pump, after being told to not touch it, even though he can’t find it. He needs to slowdown and let his dealer direct him. Although like RjC suggests, maybe there’s more to the story?
it has 107 hours on it. It had 97 when I bought it. Prior to delivery the tractor was fully serviced by the dealer. It has a full tank of gas. When I start her there is no clicking sound...just the engine turning over. The dealer called me yesterday evening and stated they will ship to me a new solenoid which I can replace myself. Yes its fully under warranty. Because the dealer is 4 hours from me, the option of me delivering it back to them for service is not an option.
DONT WORRY GUYS.......I am definitely not a mechanic and therefore I shall not be messing with anything....that's the dealers job and responsibility. There is another place 20 minutes from me. The dealer will pay for any warranty work and I would just have to pay for the mechanics travel t my house if ever required.
No worries Robin....I spent 30 years in the Military Police here in Canada so I always welcome criticism at any level....and I welcome any advice and suggestions you have
2007 Anderson 25ft T/A Flatbed Equipment Trailer (A55852)
2007 Anderson 25ft...
LADDER W/WHEELS (A55745)
LADDER W/WHEELS...
70pc 12ft.x 3ft. White Metal Roof Panels (A53424)
70pc 12ft.x 3ft...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
