Oil & Fuel fuel injection pump
/ fuel injection pump #1
sheldon1968
2022 Kioti CX2510
Anyone tell me where the FUEL INJECTION PUMP is located on a 2022 Kioti CX2510........I think I may have a problem as it will not start...turns over but will not start
the dealer is sending me a new Solenoid so hopefully that works
/ fuel injection pump #2
Fuel injection pump is major (only for a qualified tech to touch)and the last thing to check after everything else. Wait for the solenoid or switch similar relays around….one at a time.
ps. make sure there’s fuel in the tank 🥴
Will do...thank you Sir
/ fuel injection pump #5
The injection pump is the last thing to check….incase you missed that!!!
Maybe start by telling us how many hours are on the tractor? Is there any warranty on it? Has it had a complete service….ever, which includes all engine and transmission oil fluids with filters? At a dealer or by you? Have you run it out of fuel? If so then the fuel system needs to be purged of air. How long since the fuel filter was changed? Do you buy diesel at a popular/ busy station? Have you filled it with gasoline by accident? Is it stored inside?
With your very apparent ignorance of how a diesel engine runs/operates, I dare you to touch it and find out how deep your pockets are. Which now makes me wonder how it’s been looked after…
/ fuel injection pump #6
Is the tractor still under warranty? If so, let the dealer diagnose for you.
I would suspect a voltage problem. A fuse or corroded connection possibly. To find out one would start by measuring voltage at the solenoid and work backwards through the circuit.
Forgive the harshness of some on this site. They forget they once did not understand mechanical things. There is still plenty of folks willing and capable of helping.
/ fuel injection pump #7
A diesel that cranks, but won't start is almost always fuel related. Sometimes secondary to an electric problem like the fuel shutoff solenoid.
The important points being made, are that there are a long list of things to check before looking at the injection pump.
The fuel shutoff solenoid could have been tested rather than seemingly blindly replacing it. That was a real stab in the dark by the dealer, but perhaps there is more to the OP's situation.
I personally would begin by checking for proper fuel flow at all points from the tank out. Messing with a potentially operating injection pump is likely to get very costly for the average owner, even if mechanically inclined.
/ fuel injection pump #8
If my yelling keeps him from poking and prodding when he doesn’t have a clue…it’s served my purpose. The op asked a second time how to remove the injection pump, after being told to not touch it, even though he can’t find it. He needs to slowdown and let his dealer direct him. Although like RjC suggests, maybe there’s more to the story?
it has 107 hours on it. It had 97 when I bought it. Prior to delivery the tractor was fully serviced by the dealer. It has a full tank of gas. When I start her there is no clicking sound...just the engine turning over. The dealer called me yesterday evening and stated they will ship to me a new solenoid which I can replace myself. Yes its fully under warranty. Because the dealer is 4 hours from me, the option of me delivering it back to them for service is not an option.
DONT WORRY GUYS.......I am definitely not a mechanic and therefore I shall not be messing with anything....that's the dealers job and responsibility. There is another place 20 minutes from me. The dealer will pay for any warranty work and I would just have to pay for the mechanics travel t my house if ever required.
No worries Robin....I spent 30 years in the Military Police here in Canada so I always welcome criticism at any level....and I welcome any advice and suggestions you have
/ fuel injection pump #11
Awesome brother, meant no disrespect. Just didn’t want you to go tearing into stuff willy nilly.
ps. You say “full tank of gas”? You mean diesel right!!
And we are brothers….I’m retired OPP. 😉
/ fuel injection pump #12
Damn it's not rocket science;
I must read things a bit different. Seems to me the OP is asking were the injection pump is located, not how to remove the pump.
The pump should be located on the side of the engine towards the front of it, and were it can be driven from the timing gears.
The most common fuel solenoid for compact tractors will be mounted to the injection pump with a couple of screws or small bolts.
Many of them will look like this;
Normally some trouble shooting is done prior to just swapping parts out.
Most of these types of fuel shutoff solenoids will have a high current pull in winding and a low current hold winding. The high current initial shoot can be a wire straight from the key or stater, while the hold coil usually is fed from a relay.
/ fuel injection pump #13
There's whats wrong with it guys, it was delivered with GAS in it!!
SR
yes diesel
your name sounds very familiar Robin.....you have any dealings with the MP's from Ottawa say in the late 90's early 2000's??
Hey everyone...Just an update of what I've been going thru with my 2022 Kioto CX2510.
1. I installed a new solenoid - NO START
2. Checked fuel flow from the fuel filter and the air filter is new - NO START
3. Checked all the fuses - ALL GOOD
4. Bypassed the Seat Safety Control - NO START
5. Cannot find any of the relays as they could very well be in a location that I just cannot see under the hood.
6. Mechanic from BRANDT (John Deere) hopefully coming Monday afternoon to diagnose and possibly detect the cause of the problem.
If anyone has had similar problems with the SAME tractor (KIOTI CX2510) please send me all the help you can and I shall try any recommendations you have, keeping in mind that I know absolutely nothing about tractors as this was my first so I'm learning as I go everyday
My gut feeling tells me that its a fuel issue as I am not getting any smoke or diesel smell which she turns over.
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A65057)
2001...
2011 MERTZ BLENDER TRAILER (A67714)
2011 MERTZ BLENDER...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
2019 Ford F-550 4x4 Venturo HT40K-X 6,000 lb. Crane Service Truck (A66736)
2019 Ford F-550...
2014 Ford F-150 Ext. Cab Pickup Truck (A66736)
2014 Ford F-150...
2016 Chevrolet Tahoe SUV (A66738)
2016 Chevrolet...
