Useful attachments adapted to PT ?
/ Useful attachments adapted to PT ?
Ran the cutter for a few hours today. The larger front wheels have pretty much cured the issues I was having with scalping plus to me they seem much better at riding over stuff than the smaller diameter OEM wheels. And the laminated rubber wheels don't chatter on my gravel driveway.
Still intend to change out the rear wheels on the deck, too, but that will require some fabrication.
Also thinking I need some tire chains to increase slope traction, but am not knowledgeable about the various options. We don't get much snow for that to be a consideration. Just need something to help reduce tire spinning on slopes.
/ Useful attachments adapted to PT ? #144
None of those. Look for net chains. I believe @SpringHollow may have a source.
Ones like these;
The boron alloy is especially tough.
All the best,
Peter
Wowza. $345.29 per pair.
/ Useful attachments adapted to PT ? #146
I run chains in my 1850 and they make slope performance worse, not better. Traction up and down improves but sideways you slide quicker.
/ Useful attachments adapted to PT ? #147
Yes, unfortunately the price of chains went up by a lot six or seven years ago. I never did find out why. On the bright side, more of the net chains now use the upgraded alloy of boron steel. If you haven't used boron steel, think armor plate.
Unlike @woodlandfarms, my tractor slips a lot less with all four wheels in net chains. (Less sliding in all directions)
I replaced the cutting edge on my 4n1 a while back with a boron steel edge. The hardness is around 500HB, and the 0.2% tensile strength is up around 174,000psi.
All the best,
Peter
I'm already at the point of being uncomfortable going sideways on my slopes. If there were a way to add robotic controls...... Other times, I think about taking a self powered trail mower and winching it up and down the hillsides.
/ Useful attachments adapted to PT ? #149
There's always a way to add robotic controls to anything.
First, how's your wallet? 😳
:ROFLMAO:
A friend of mine was making an RC slope mower for his daughter out of a riding mower, power wheelchair and some other things. Had a good start on it, however, she got divorced and sold the hilly land. :( So he stopped for now.
/ Useful attachments adapted to PT ? #150
:ROFLMAO:
Yes the commercial remote controlled mowers have been pricey; $5k for a lawn mower size mower, and the larger ones seem to be PT-1860 cost, for not a lot of utility. E.g. this one
While this claims up to 50 degree slopes, the Kawasaki FX1000V has a limitation of 25 degrees. There's no claim for an enlarge oil pan or dry sump, or nothing that might help the Kawasaki run well, but perhaps it is a man behind the curtain thing...It lists new for more than an 1860.
All the best,
Peter
/ Useful attachments adapted to PT ? #151
All the best,
Peter
Needs an aerobatic rated radial engine.
/ Useful attachments adapted to PT ? #152
This is why I bought chains. It won't make a 1445 into an 1860, but the chains helps me feel more in control in my opinion. Also, in my opinion, chains plus draft control on the brush mower on the 1445 is actually pretty amazing.
Don't forget just backing up a slope and mowing downhill.
All the best,
Peter
Downhill orientation is the most comfortable for me, but the PT tires are slipping trying to back up the hill.
Would you suggest chains on all 4 wheels? There's enough clearance between the PT body and the tires?
/ Useful attachments adapted to PT ? #155
There is a ton of clearance.
Yes, two pairs of chains for chains on all four wheels. The ones that I have are pretty easy to put on. Lay the chains down with the adjustment side away from the tractor. Drive on a bit, connect the inside ring as short as possible, tucking the extra couple of links inside, then connect and tighten the outside ring. Drive around for a bit, and retighten the outside ring. The first time, you may need to retighten the inside links if it was too short for your chains or wheels. In my book, you can never have chains too tight.
Thistles, more specifically thistle sap, are my nemesis. As a friend says, "it's slicker than snake snot". Chains give me enough grip not to slip sideways (much) while mowing thistles. Before getting chains, I had a couple of incidents of the tractor sliding sideways downhill several feet on the slick sap covered mulch from mowing. Nothing bad happened, but the slide was definitely uncontrolled.
@woodlandfarms Oops. Nice catch. Yes not "1860", 1850... fat fingered typing. (Although I'm sure that you could turbocharge yours. With a muffler wrap and a turbo cover, you might not have much extra heat in the engine area, but then what would you use all the extra ponies for? Curious minds want to know... :unsure: )
All the best,
Peter
/ Useful attachments adapted to PT ? #156
The chains I use the most are my studded net style. When I bought them way back when, they were not too bad, Last time I looked, they were crazy expensive. But I use them the most for use on ice.
Ken
/ Useful attachments adapted to PT ? #157
In regards to the chains. I do use them but they really don’t help with sideways traction. Greatly reduced tire pressure provides the best stiction. Do you see Rock crawlers with chains? Arctic tundra trucks with chains? Heck do any farmers use chains? I honestly ponder if chains aren’t harder on our wheel motors. I have to replace my second one (seals blew). Wonder if the bighting traction doesn’t impact the motors. That said like I said in the winter i chain up and if I forget they ten to ride year round.
/ Useful attachments adapted to PT ? #158
Around here, I find chains are hard to forget, what with a few paved surfaces, and noise.
I've tried lowering the tire pressure on the 1445 that I have, and I don't see any obvious improvement. I do roll the tires off the beads at lower tire pressures. I run mine around 24psi, which is, IIRC, where Carlisle (now Carlstar) suggests the pressure for the loads on the tractor (+/-).
I wonder if the effects of lower tire pressure is different due to the different tires on an 1845 (R1, 4ply) vs 1445 (R4 6 or 8ply).
I don't see too many rock crawlers with standard size or type tires. The tires that I have seen tend to be large diameter, very very soft sidewalls, and often with bead locks. Not that I haven't thought about them for my 1445, but I have my doubts whether those types of tires would survive the sharp stumps from mowing brush around here.
All the best,
Peter
/ Useful attachments adapted to PT ? #159
Yeah Peter. On my machine it’s 4psi max on soft 4 ply tires. Your situation the trains probably due increase your traction.
Current status is I installed the 15" laminated wheels after using a wire wheel brush to knock off the paint on the 1 1/4" yoke.
Next, fabricated new wheel mounts at the rear wide enough to mount 15" laminated wheels. Thought I could use 3/4 axle. Wrong. Not enough metal in the OEM 5/8 to bore out comfortably so I bought hubs with a 5/8 bore.
While I had the mower off the PT, decided to fabricate a debris guard. I meant to use chain, but wasn't comfortable with measuring the clearances needed to make sure the chain could never impact the cutting blade in any position. With the blade being so close to the deck anyway, I made a temporary guard just to see if it made any difference and how it might affect cutting performance.
(4) Texas Built Stand Alone Livestock Panels (A66408)
(4) Texas Built...
2018 Kubota SVL 75-2 Skidsteer (A65579)
2018 Kubota SVL...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
SRECO Flexible Sewer Cleaning System (A65579)
SRECO Flexible...
