Hydraulic winch and other general PT usability questions
   / Hydraulic winch and other general PT usability questions
Having dealt with thorns, I would encourage you to preemptively slime your tires before you start.
The great thing about capstan winches is that you can get long rope(s), and use snatch blocks. Have a look at some of the rope rollers and snatch blocks that Yankum ropes sell. Not cheap, but quick ways to change the angle of pull, and if needed multiply your pulling power. There are some nice forestry capstan winches that are specifically designed to be anchored to tree trunks, and are, I think, really useful for pulling over trees, and use in trees.
I think that UHMWPE have really transformed winching; I just wouldn't let them be abraded by ground contact. They are so much safer than wire rope or chains.
All the best,
Peter
I have to thank you for this because I had no idea these even existed.
The PCW4000 portable gas winch has a clutch, line lock, and throttle control assembly that differs from other capstan winches such that the capstan doesn't move until the operator applies tension to the line. IMO, that's a significant safety upgrade. PCW4000 Gas-Powered Winch
Having become more comfortable with this particular capstan winch, I think it may solve my other problems of access, thorns and hillside working conditions that I would face trying to use a tractor or PT in this area. I was able to find a used pcw4000 at a decent price.
What I need is to learn how to most effectively rig it. What I am wondering is whether I should be using traditional metal snatch blocks and double braided polyester line or if I should be looking more at the Yankum rollers matched with synthetic rope?
I plan to fabricate my own tree mount and a log nose cone from a section of plastic 55 gallon drum rolled into a cone shape.
   / Hydraulic winch and other general PT usability questions #52
Yes, I like that winch, though I don't own it. Congratulations on finding a reasonably priced used one! I think August Hinicke uses one a fair amount, https://www.youtube.com/@AugustHunicke I think that they are pretty clever in terms of how they rig trees to pull over, and to trim, as is Eastside Tree Works. https://www.youtube.com/@guiltyoftreesoneastsidetre4792
I think that the pcw4000winch mount system is really nice because the winch is fixed to the tree and won't move on you if the angle of the pull changes for some reason. A series of sufficient strong straps would also work.
While I believe that UHMWPE rope is a big upgrade on polyester, it does cost a lot more. If you think that you will abrade the rope(s) doing what you want, I would go with the polyester and expect to replace it. The strength/diameter does differ and that might put you into different snatch block sizes. The only thing that I would NOT do is swap snatch blocks between wire rope and synthetic ropes. Wire rope tends to emboss texture onto snatch block pulleys that then abrades synthetic ropes.
I personally think that the Yankum snatch blocks are just plain ingenious and appropriate for synthetic lines. However, at the end of the day, it is just a snatch block and an integrated shackle (though you may need more shackles in some configurations).
All the best,
Peter
   / Hydraulic winch and other general PT usability questions #53
With the 7700lb forestry winch on my tractor I use a self-releasing snatch block:
and a nylon lifting strap to attach it to trees.
When the load gets to the block it trips the lever and releases the cable. It's great for redirects from trees that are a clear shot to the tractor, you just keep pulling and the log arrives at the tractor.
I don't know for sure that the rope will work but it seems like it would. I think ball bearing pulleys would be a lot better than pulley-less things, even if they're low friction for what they are.
I found that even with a 3" wide strap its important to keep the strap from moving around on the tree under load or it will wear the bark. The block also works with choker chains but I would not use that except on a tree I was going to take down soon.
I read elsewhere today that synthetic rope will not work on a capstan which requires a certain amount of friction with the rope to operate and the snatch rings appear to be designed for synthetic rope as Peter said.
The advantages of synthetic rope, soft rope shackles and snatch rings appear to be less metal to come flying back if something breaks loose as well as lighter weight.
The PCW4000 is only a 2,200 lb winch so my assumption would be that the less friction, the better, meaning ball bearing pulleys may be the appropriate choice for use with it and to use 10-12mm double braided polyester rope with it as recommended by the manufacturer.
   / Hydraulic winch and other general PT usability questions #55
My tire loss is not from punctures but more from rim / side wall intrusion fin limbs and shirt small stumps.
I had similar issues with my 1850 until filling with gemplers ultra seal. No more issues.
   / Hydraulic winch and other general PT usability questions #56
Look at the portablewinch web site - they carry the appropriate rope, pulleys etc. When I bought mine, their prices were reasonable. It is extremely important that you use low stretch rope.
I ordered one new item from portable winch of that may be of interest. They have a product called the RopewizerTM that takes the place of a splice at the rope end so that no rope strength is lost. RopeWizerTM - The Easy Splice
It's shocking how much pulleys cost.
   / Hydraulic winch and other general PT usability questions #58
I've always been a fan of the figure 8 knot, as it retains most of the rope's strength without added hardware.
How do you carry your chainsaw, gas, chains, and other tree work tools when using a Power Trac?
   / Hydraulic winch and other general PT usability questions #60
It depends on what I'm doing...For tree work only, it all goes in the front bucket, often with a generator gas, and fire extinguisher to run electric chainsaws and pole saws. If I am chipping, some goes in a feed bucket over one FEL arm, and the rest goes in the chipper bucket. I have never needed a tool box, but everyone has slightly, or not so slightly, different use cases.
All the best,
Peter
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2014 Dodge Charger Passenger Car, VIN # 2C3CDXAT8EH223963 (A57453)
2014 Dodge Charger...
Case skid steer wheels and tires (A56435)
Case skid steer...
2021 Ford F-150 (A55973)
2021 Ford F-150...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
