OP
2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 9,480
Having dealt with thorns, I would encourage you to preemptively slime your tires before you start.
The great thing about capstan winches is that you can get long rope(s), and use snatch blocks. Have a look at some of the rope rollers and snatch blocks that Yankum ropes sell. Not cheap, but quick ways to change the angle of pull, and if needed multiply your pulling power. There are some nice forestry capstan winches that are specifically designed to be anchored to tree trunks, and are, I think, really useful for pulling over trees, and use in trees.
Offset Winch Snatch Ring
Order Quantity 1 = 1 Ring For use with synthetic HMPE winch line ONLY WARNING: When performing a winch recovery, start with a single line pull (1:1), and work up to other configurations, ie 2:1 ---> 3:1, etc. The risk of overloading your tow/connection points increases with each additional...yankum.com
I think that UHMWPE have really transformed winching; I just wouldn't let them be abraded by ground contact. They are so much safer than wire rope or chains.
All the best,
Peter
I have to thank you for this because I had no idea these even existed.
The PCW4000 portable gas winch has a clutch, line lock, and throttle control assembly that differs from other capstan winches such that the capstan doesn't move until the operator applies tension to the line. IMO, that's a significant safety upgrade. PCW4000 Gas-Powered Winch
Having become more comfortable with this particular capstan winch, I think it may solve my other problems of access, thorns and hillside working conditions that I would face trying to use a tractor or PT in this area. I was able to find a used pcw4000 at a decent price.
What I need is to learn how to most effectively rig it. What I am wondering is whether I should be using traditional metal snatch blocks and double braided polyester line or if I should be looking more at the Yankum rollers matched with synthetic rope?
I plan to fabricate my own tree mount and a log nose cone from a section of plastic 55 gallon drum rolled into a cone shape.
