Brand new Kioti rx7320 Dead in the water
/ Brand new Kioti rx7320 Dead in the water #21
Did you test the voltage directly from the terminals or the cable clamp attached to the battery. Every time my Kubota won't start it has something to do with the connection to the battery or the ground point on the frame.
/ Brand new Kioti rx7320 Dead in the water #22
My Kubota has a 3-position switch for the overhead light that is similar to a car. On all the time, On when the door is open, and OFF all the time. Is it possible that you have a similar switch and left it on? Everyone plays with EVERY switch on a new tractor.
Frankly, it's just silly not to jump it or charge the battery and see if it starts. You can gripe all you want and we can hypothesize till the end of time (believe me, we can), but step one to solve your problem is to diagnose the problem. You quoted a voltage so you must have a voltmeter. Jump it or charge it and check the voltage while its running to verify alternator is working. Check it again after it's charged and watch for voltage drop.
Lemon laws for cars kick in only after multiple trips into the dealer's shop to resolve the same problem. Specifics vary, but you don't qualify and tractors aren't included.
What would you do if you bought a new car and left something on to drain the battery? You have to prove that you didn't and try to get the battery charged. You can't ASSUME that it's defective until you eliminate the most likely causes.
I know you’re all right. And maybe overreacting but i am afraid that this is just the tip of the proverbial iceberg.
Most of our fears in life are based on the unknown :-(
Actually tractors are included in the lemon law if they are for personal use.
Also if i wanted to work on a tractor to keep it running I would have spent a lot less and bought a used one
/ Brand new Kioti rx7320 Dead in the water #27
I think Flyinghigh has a legitimate complaint on the TYM for his father under the lemon law. Elderly man wanting to enjoy a new cabbed tractor in later years and No parts available for an obviously defective front axle in the US for weeks on end.
In this case would have already charged the battery (If it will charge) and Gone from there.
I get that a Lot of money has been spent on a brand new machine. That is where the dealer needs to jump on the problem pronto if you do not want to try and charge what could be a bad battery or possibly a painted battery cable connection causing a high resistance.
I think Kioti make a Good tractor , I really wanted the original cabbed DK 55 when it came out.
/ Brand new Kioti rx7320 Dead in the water #28
Does anyone know about applying for the lemon law? Does it apply to tractor purchases?
I am miffed about spending this much and having to deal with this so soon?
Batteries just like anything else can and do go bad, extreme hot and cold weather will take the life out of a failing battery, also there is no telling how old the battery is in your tractor as some new tractors will set for up to 2 years before they are sold. I think you are jumping the gun with the whole lemon law thing, give your dealer a chance and as others have mentioned jump the tractor off and see if it's something as simple as the battery( Man Stuff 101 ). Good luck.
/ Brand new Kioti rx7320 Dead in the water #29
I purchase anout 80-90 batteries a year for generators. Every year I find at least 1 that won’t hold a charge. If a battery is undercharged, instead of preventing a frozen battery to -80F, they can freeze at 30°F.
have battery load tested.
man, I had a few problems with my tractor when brand new, and Kioti took care of them all. Now about 12 years later, best tractor I’ve ever owned. Very reliable.
ive been operating tractors for nearly 50 years now
/ Brand new Kioti rx7320 Dead in the water #30
The first battery in my Kioti failed at 6 months. Turn on key go through preheat sequence turn to start and lose all dash lights. Turn off key and back on and repeat sequence. Connect charger cables and turn on and then off charger, you didn't have to charge the battery and it would start for a week and would even pass load testing. Had another case of were I had been mowing and shutoff the tractor to do something and went to restart and battery had failed. I think that tractor ate 4 batteries within the first 9 years. have used Napa batteries the last 10 years. The first lasted 6 years and the current battery has been in use for 4. It happens.
Dump cylinders on the bush hog loader leaked and had to be replaced 3 times under warranty before found a set that didn't start leaking with the first 5 hours of use. Rear remote valve had to be replaced under warranty when it decided it was no longer going to come out of detent.
/ Brand new Kioti rx7320 Dead in the water #31
Charging the battery will not void the warranty.
If you read my post you will see that I wasn't referring to charging the battery.
To the OP; there are a lot of happy Kioti owners out there. Many of them even post on this very forum. ;) They are as good or better than any other brand out there. (Except Kubota, of course. :D) While I understand you may be frustrated, sometimes new vehicles come with gremlins which need to be fixed. Hopefully your dealer is on the ball and gets you running soon.
/ Brand new Kioti rx7320 Dead in the water #32
I guess the only option you have is to sell it off if you can't hook up a battery charger. Maybe it's time to start looking at nursing homes instead of tractors?
That was my thought exactly.
/ Brand new Kioti rx7320 Dead in the water #33
I bet that dealer of yours regrets not hiding in the bathroom the day you showed up. I suspect all you have to do is call them and they will dispatch someone to get you going, regardless of the issue. But I can tell you one thing for sure, if you throw the Lemon Law at them are give them heck about it, you might not get so lucky.
/ Brand new Kioti rx7320 Dead in the water #34
Check the battery water level. If it's all boiled out, that explains the low voltage. A defective alternator putting out A/C (Ba or shorted diode) will boil off a battery.
/ Brand new Kioti rx7320 Dead in the water #35
Everybody likes to throw around the lemon law, but have absolutely no clue how it works or what it entails. Like for instance Il lemon law requires 4 repair attempts of the same failed component within a 12 month period.
Well you will all laugh at this (Maybe :))
I cant remember who posted about an interior Cab light left on. Well I decided to try and jump with my truck. After I connected the cables and got inside the tractor i noticed the overhead light on. I dont remember turning it on but I am sure I did. And since I only run it during daylight i never noticed it as it is not a very bright light.
Well long story short i left the truck run for about 1minute and the tractor fired right up.
I guess I have been shafted so many times in life i am skidish. I admit i went off the deep end here :)
On a separate note It interesting how ever since the internet has been around it has turned ordinarliy polite people into rude ones. I am older and have worked on all kinds of machinery over the years not always been a fun experience. Working on equipment in sub freezing temps while it is snowing is not my cup of tea.
Anyway thanks to all for the replies even the not so kind ones :)
I hope to have the same long term experience of all those that have had great luck with their Kioti tractor and their dealer.
Take care and be safe :)
/ Brand new Kioti rx7320 Dead in the water #37
Glad it was simple and thanks for telling us you figured it out.
/ Brand new Kioti rx7320 Dead in the water #38
Thanks for the update, and glad to hear you're up and running. I killed the battery in my Kubota last year the same way.
/ Brand new Kioti rx7320 Dead in the water #39
I would think that almost everyone has at one time or another killed a battery so an engine wouldn't start. Either a light or a radio or something similar.
/ Brand new Kioti rx7320 Dead in the water #40
Glad you got it figured out and kudo's to you for coming back and saying what the problem was, that's not always easy to do. I'm just glad you figured it out before you chewed out your dealer. :LOL:
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
KUBOTA BX2380 TRACTOR (A62130)
KUBOTA BX2380...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A60352)
2004 International...
2019 GALYEAN...
2013 PETERBILT 389 SLEEPER (INOPERABLE) (A60736)
2013 PETERBILT 389...
2025 Pabreak 74in. Hydraulic Dual Cylinder 4-in-1 Bucket Skid Steer Attachment (A61567)
2025 Pabreak 74in...
