bar oil test
/ bar oil test #3
Watched it earlier today and I too was amazed. I always use the cheap stuff anyway because I'm inherently cheap. Like Stihl pre mix oil, I've read it makes a lot of carbon not that I would know as all I run is canned gas anyway. I use the 2 finger test with bar oil, always.
/ bar oil test #4
I watched the video and was surprised. I’ve mostly used both the Oregon and Stihl bar oils. I see a lot of loggers using those also. I wonder where the harvest king oil is sold? I’ve never seen it.
/ bar oil test #5
From a search looks like Farm and Home Supply and Atwoods pops up. I was thinking that Rural King use to carry it but doesn't appear to any mower. Did see a reference to BigR which is spinoff from Rural King, but BigR is not all the same company within that name.
/ bar oil test #6
He should have thrown hydraulic fluid in there. My Limb Hog is self oiled from the hydraulics. I've often wondered how that would compare to bar oil.
/ bar oil test #7
i am surprise about the viscosity of the husky oil and it’s colour because that all season oil is basically winter oil it’s so liquid and mine is clear not brown like this one … but it definitely makes me want to change my choice of oil now
/ bar oil test #8
Not gonna lie, there were a lot of shocking results in there. I didn’t figure all the bars would get that hot.
His bar temp test is hokey and flawed - his single test results aren't worth a grain of salt.
"Look at me cutting sawdust ant nests with a cold chainsaw this oil is amazing and the best"
/ bar oil test #9
Agreed. I'd also like to see veggy oils tested.
He should also drink a shot glass of each oil to simulate the oil we are ingesting through breathing in the smoke and oil spray. He can then recommend which oil keeps him more regular.
/ bar oil test #10
After sleeping on it, wonder if that location on the bar is getting a lot of exhaust heat? I’ve had hot chains but the temps he’s getting are pretty much instant burns which is exhaust hot?
/ bar oil test
I've used the petroleum based stihl oil for years which he didn't test but I like his tests and feel he is unbiased. Pulling a tight chain over the bar is steel on steel at high speed will produce lots of heat. His heat numbers are to show the friction amounts each oil gives.
/ bar oil test #12
Harvest King is what I purchased last year at the Glasgow Rural King. Have used it for years since Rural King came to KY.
I think it was on sale for $6 last summer so I bought a few.
Dont know if they have it now.
/ bar oil test #14
I always tell locals buy the cheapest at farm stores local over name brands. Can buy 3-4 compared to 1 for cost.
I never even had proof of anything but my own uses.
Now it confirms it even more. :ROFLMAO:
This, cam2 etc etc etc all in 8.99 9.99 range today at FFH TSC Menards. I even liked the poulan pro in red over husky and others.
Like to see most of the farm store brands done now. One I bet wont do good is that walmart bar oil. Even for 30wt it seems thin. Makes good winter oil if had to buy it.
/ bar oil test #15
Most the time I like Project Farms tests, this time not so much. For example the scar test. Does that really apply to bar oil? It’s more useful on motor oil. The only test I see that really applies is the chain wear test. I realize he has to do some kind of testing and while interesting I’m not sure how useful other than the chain wear. I have a gallon jug of the Husky oil right now, I will probably switch away from it next time I buy.
/ bar oil test #16
I would agree about the Poulan Pro oil being some good stuff. From my own testing couldn't even smoke the stuff while pushing a puddle around with a propane torch. Sold the stuff for years. My Poulan parts distributor stopped carrying the Poulan pro 952030204 oil a few years back and was replaced with the Poulan 952030130 which is still good oil, but not like the other. A few years ago I was seeing issues with the whatever brands bar oil Rural King was selling because it the winter time it would thicken to a consistency similar to partially gelled diesel fuel. And would wipe the plastic gear out of the oil pumps on saws.
/ bar oil test
We swtich to winter oil, in the winter. The stihl oil we use got way to thick but I'm not certain they call it all temperature anyway. Having a winter temp can bar oil is no big deal.
/ bar oil test #18
Which one at RK. 30. They sale like 5 different bar oils and 2 of them in different weights for winter. 10 20
If us men actually read owners manuals in past. They even say during winter can be cut with diesel too. If not running winter weights.
/ bar oil test #19
A lot of bar oil brands have went to a summer weight and a winter weight. It all use to be just all season. years before bar oil people used 30w motor oil and would cut it 50% with kerosene in the winter
/ bar oil test #20
I am sure it was 30w. the stuff would turn into crystal sparkley molasses below about 40 degrees, but nobody has winter blend 10w like now. the poulan pro was thinner at 0 than this stuff was at 40.
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2024 DODGE TRUCK BED (A65643)
2024 DODGE TRUCK...
2023 NISSAN ALTIMA SEDAN (A59914)
2023 NISSAN ALTIMA...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
6' 3Pt Bush Hog Mower (A66408)
6' 3Pt Bush Hog...
2019 HINO 268 4X2 S/A NON CDL BOX TRUCK (A59914)
2019 HINO 268 4X2...
