Importing and modifying a new mini excavator from China
/ Importing and modifying a new mini excavator from China #921
The georgia diggums went 6 and 64. With fees that's right around import price delivered. Hope ya got one bro! The agt's all going around 4k imo is high when you can buy from dealer sales delivered for similar $.
There are four more soon auctioned in WI or MI and some on west coast. There aren't many at all compared to agt past or present.
Apparently new various pilot dbl pump machines will become a little more available but no guarantee the non-auction price will be sub 9-10k i don't think.
In case you missed it Josh, you can by that machine from leking machinery (leking.net) also on alibaba. about 4200 and somewhere between 6 and 7k total price delivered. Buy attachments at the same time, very economical.
/ Importing and modifying a new mini excavator from China #922
Did not get any of them. That would have been 7200-7600 for the Diggits after the 20% markup. There's one on FBMP for 9k (could probably offer 8k) and there will be other auction opportunities, so not worth rushing into the purchase at that price. While I like the layout of those better than the AGTs, I've never used either style and not sure that alone is worth the price difference. Or if I learn the ropes on the import thing and am willing to wait I can probably get more for less.
The AGTs were just too high IMO. One sold for 3900, the rest were 4-5k plus the 20% markup. Like you said, at the prices they went for, I could buy a new one direct from AgroTK with free shipping.
Thanks for the Leking info. Was trying to find that style on the import stuff but there are so many its easy to get lost digging through them. Still not sure that I want to tackle importing though. Will take time and study it some more. I was mostly rushing in hopes that I might score a deal at auction, but we don't have a problem waiting. Though 6 months for an import might be an issue, that's put us right in summer when it would be too hot to work much in this part of the country. Maybe that calls for an enclosed unit with AC?
...probably not
/ Importing and modifying a new mini excavator from China #923
I have minimal experience to compare but think the pilot models (all?) come with the double acting load sensing pumps. I think they work together allowing for somewhat finer control (while faster/more flow ~ 9gpm vs 5gpm iirc?), and also the ability of >2 functions simultaneously. I've not run a single pump to compare though!
I can confirm the parts alone to create pilot joystick (and double pump) cost about 1500 china price not shipped. (best parts price I could find for the pump, hoses, sticks, enclosures, valve block assemblies, etc)
Which makes sense. . . china price of standard 1ton machine is around 2400, vs about 4200 for pilot/double, and also the kv13plus (friggit) runs (I think) about 15% longer and wider track footprint.
Dfk and others can confirm, import is like 90 days max usually. Port to port often about 45 days.
I operated the Diggit EM15, as I noted in this thread, and I could not feel that the pump (duel chamber with load-sensing) changed flow rate. That setup used a single output pump with flow divider on the stack valve to dedicate some of the volume for the pilot controls. It seemed a bit smoother than the 3 brands of direct-acting setups I have operated. Not faster, and a little less jerky, and the lower jerkiness may have been due to the higher weight. The EM15 could be as much as 50% heavier than my XN08.
I have not operated the setup that features a 2-chamber pump with no load sensing, but 2 independent OUT hoses. Pix of that setup have been posted.
As for shipping times from Xingdao to ports in the US, current conditions may indicate that you can prob get a load in under 45 days. There seem to be fewer container issues, and lower customer demand from this side of the pond. But Christmas season is here. Someone who has done it recently would have better information.
/ Importing and modifying a new mini excavator from China #925
I got an AGT L12 direct from AGT via a eBay sale and it was shipped to me for $5900 plus tax about 2 months ago. Originally I had a QH12 on order but changed to an L12 because the L has a hydraulic oil cooler and stronger canopy. Also the engine is more accessible from what I can see. It was the same price.
15 hours in and so far I’m happy. No leaks or major issues. The controls for the tracks keep wiggling loose. I want to find some better handles for them. I haven’t looked into where to order those.
I was surprised to get a call from AGT a week back. They sent me a part for free that extends the pump inlet into the hydraulic tank. It’s supposed to solve a “manufacturing defect” where the hydraulic system stops working when the machine is at a steep angle.
I’ll probably replace the hydraulic fluid when I add this part as I have to drain it anyway. Anyone have a recommendation for fluid? Should I use synthetic?
Many have added a proper filter but I’m hesitant to take that on right now.
/ Importing and modifying a new mini excavator from China #926
That simple fix they sent you is great. My Kat-12 has a lot of trouble on inclines. Be careful on really steep terrain and keep you cg as far forward as possible. Use the hoe to throw cg forward or to one side.
Concerning fluid; AW-32 can be bought at any auto supply and is cheap.
/ Importing and modifying a new mini excavator from China #927
@diabeticpilot - Unless you want to put a lot of work into draining virtually everything, stick with mineral oil. . Synthetic and mineral do not play well in hydraulic system
/ Importing and modifying a new mini excavator from China #928
Oh so they put mineral oil in it? Where do you get that from? I see Amazon stocks food grade mineral oil for pretty cheap.
/ Importing and modifying a new mini excavator from China #929
I'm still learning about these and don;t own one yet, but that doesn't sound right.
Instead of mineral oil, did you possibly mean traditional, non-synthetic hydraulic oil?
/ Importing and modifying a new mini excavator from China #930
Yea, traditional hydraulic oil….
/ Importing and modifying a new mini excavator from China #931
No I think our typical hydro oils are fine. I used 46.
They'd have no reason to redesign the entire systems to use mineral oil.
Some high end racing brakes yes. Inexpensive chinese excavators no.
________________
dfkrug said "and I could not feel that the pump (duel chamber with load-sensing) changed flow rate"
Yes isn't actually very obvious like you'd think. But I just meant the double acting gear pumps supposedly have more flow when I mentioned 5gpm vs 9gpm. I think that may mean faster travel function also.
On weight- the manufacturer (still never weighed mine) is listing kv13plus (em15) as 1t weight (not 'operating weight') so I assume they are about 2200lb. There is no additional counterweight as you also saw, but there does have to be more weight in the 10-15% longer and wider base, which is actually where you want it anyway.
That's why I was hesitant to add the 250lbs of lead to rear of house, but have been impressed with the added balance.
/ Importing and modifying a new mini excavator from China #932
Is it just me or aren't these things all over the place for about for $5K, or less, delivered?
Looked that way last week when I Googled "mini excavator".
Most hydraulic oils could be called "mineral oils" in that they are derived from non-plant-based sources. Petroleum usually. Vegetable oils are not recommended for use here. In braking systems, the hydraulic oil is more like an alcohol (glycol ether).
Any common hyd fluid like ISO 46 is fine for our gear-pump excavators. Or ATF, or even motor oil. Tractor-hyd-fluid is better, but optimized to also work well with wet brakes and HST drives. It is nice to use an oil that does not foam readily and will emulsify the water you will inevitably get in there.
/ Importing and modifying a new mini excavator from China #934
Yes you're right. I'm only familiar with 'mineral oil' by name in brake applications.
I then conflated dot fluid into my assumption about miner oil VS.
So oil is oil. I think the 32 and 46 numbers specify some added cleaning agents.
_____________________
I FINALLY (after days taking pictures and measuring multiple times) received this pic for my machine. Shows precise measurements and which have zerks.
They DO have proper drawings for probably all of machine. . . . they just don't like to share!
Sorry for different sizes/fonts, I used translate
/ Importing and modifying a new mini excavator from China #935
Yes sir!
/ Importing and modifying a new mini excavator from China #937
Thanks guys. Autozone had free shipping so I have 5 gallons of AWS 46 coming to me so I can put new fluid in the machine when I add the extender inside the hydraulic tank.
Let's talk accessories!
Has anyone ordered or considered a plate compactor? I saw this on Leking's site:
They have a smaller version for the 1ton minis with specs that will fit my L12. They are asking $900 for it. I guess that is $100 cheaper than a brand new jumping jack stype compactor. I am doing a lot of slope work and gravel paths, so compaction is important. I'm considering putting an in order with Leking for that plus the ripper, narrow bucket, 500mm plane bucket and the mechanical quick hitch. They want $260 for shipping to the port of Los Angeles, $750 for "door to door" shipping.
Does anyone know how the plate compactor would connect to the L12? There is one accessory lever control that goes up and down. Seems like for the plate compactor you would more want an on/off switch and preferably a way to rig it so that you could have both hands free while it is on. I guess the auger would be a similar setup.
I looked at the rotary quick hitch:
They quoted me $800 for that and I am not sure what use I'd get out of it. I was thinking it could be useful with the plane bucket to help with paths on slopes.
/ Importing and modifying a new mini excavator from China #938
If you haven't installed the extension for hydro tank, could you possibly get the dimensions for me? I bought an AGT L12 last week delivered in Ohio. A few days later I lost all hydraulic pressure when going down the ramp on my trailer. Hyd fluid was full, so I looked at the suction line on the tank. It is on the end at the lowest point possible. looks like a design flaw, and your post confirmed it. Thanks.
/ Importing and modifying a new mini excavator from China #939
one of the utubers was playing with a 360 spin bucket - those are pretty interesting for backwards scoop and grading imo.
Unless having a 2nd aux plumbed (to use along with vibrator, hammer, mower etc) I wouldn't get much use with the tilt hitch. Would just get the cheaper tilt bucket setup or I really like the 360 bucket.
Already spending a couple K this go round so am waiting for now on the more expensive things that I'd use less of.
Vibrator/compactor? Pretty cool but I thought that was more for helping settle new road or constr site before concrete/paving. A trail or path I doubt I'd use it on? And of course- same as a hammer it would expedite wear on machine alot. If really needed one I'd prob be looking at a roller. Yep you could mod aux circuit for detent on/off but a bungee/strap/etc also works
I'd check weights of anything you're getting to test extra combined weight at end of boom, to make sure you're still happy with the balance.
That shipping is decent but must not include duty. If they're doing literally all other fees assoc with import I will insist they do full DDP. Can still pick up at warehouse to save that last delivery cost to door which is often a couple bills.
And something under a couple hundred lbs might as well check air freight too.
/ Importing and modifying a new mini excavator from China #940
The extra length on the boom will really reduce the force that you can apply on the cutting edge of your bucket.
GMC 2500HD 4wd Service Truck (A63118)
GMC 2500HD 4wd...
Wooden Wagon Wheel Rocker (A61569)
Wooden Wagon Wheel...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
UNUSED RAYTREE RMSG29 - 29" HYD STUMP GRINDER (A62131)
UNUSED RAYTREE...
LAND PRIDE CAT. 1 QUICK HITCH (A62130)
LAND PRIDE CAT. 1...
2011 John Deere X540 Lawn Mower (A63116)
2011 John Deere...
