Doorman’s next big adventure
/ Doorman’s next big adventure #101
Does the foam need to be covered for fire reasons? Is the paint a suitable covering? Jon
Flammable-yes
All electric appliances so we should be fine
We painted the ceiling because that’s gonna be its finish
The “barn” side I painted just to keep it bright. The walls will ultimately be covered with something
/ Doorman’s next big adventure #103
Inspector probably doesn't care about flammability since it is not a residential building. Mine didn't care about much anything on the shop. But in the house I had spray foam exposed in the unfinished utility room and that caused trouble. We ended up settling on a special coating that the foams guys sprayed on top of it that jet flammability requirements. That satisfied the inspector
My main caution to you would be if you do any welding, grinding, or cutting of metal in there. That foam is very flammable and really will need to be covered especially down low. Perhaps you already are planning for that.
Plywood at least 4’ up.
Probably 8’
Waste water project complete.
Water line ran from new building to water line inside current barn.
The water line hook up is my job.
Pics….
2FDA73AF-EA55-476B-A8F4-DA6E2397C1A3.jpeg1D9122AB-01F3-4E99-986D-2F270B9463EC.jpegF5B6B162-FE18-41AA-8E65-D782A7B3E6A6.jpeg694EAAE8-6714-4578-BE8F-CAFD5319C6FC.jpeg7830DE0F-3685-4643-8A39-8415841723BE.jpeg
Not much progress on the barn today according to my father in law.
He did go to Menards and pick up my lumber order for this weekends projects……he did get pics of that!
I will be down there tomorrow by 6pm central.
Excited to see some more progress!!
Damn it’s toasty today!!
Driveway in
Need a few passes with the tractor to smooth it out.
2BCEE6B6-28A7-45F1-B678-ADB863183A40.jpeg8190863F-B17A-4069-8A4B-4D038DF5119B.jpegF07AB50D-6CE5-491C-8B1E-4767ABD42E52.jpeg
Electric company is coming out Monday to verify driveway install and pound a stake in the ground. Pole/porch light/meter socket and 200 amp disconnect should be in within 2 weeks. That’s the last “contractor”. The rest is on me!
/ Doorman’s next big adventure #113
The issue with that is the snooping around zoning officials. You get caught, you'll wish you had complied and the 'Land of Lincoln' is noted for strict zoning codes among other unsavory stuff.
Yep they have seen everything except leprosy and problem have seen a couple of cases of that and just didn’t know what they were looking at.
/ Doorman’s next big adventure #114
We’ve paid our 1/3 deposit and signed our contract for the shell/slab.
Slab work is supposed to start in February sometime.
5.5” slab with wet set post bases.
Plan is to have contractor excavate, set forms, I come in and do under slab plumbing and electric. He will then pour slab and set post anchors.
His time frame from start-finish is approx 3 weeks work time from excavation to finishing the shell. His quote does include a stone base for the slab. When he did a site visit we don’t expect more stone to be needed but IF it is he will pass cost directly to us and spread stone no charge.
Wife picked out the sectional door for the barn. Of course we know who will be doing the install!
Be careful when handling installing the top panel with those glass windows. Don’t ask me how I know they are expensive and hard to get.
/ Doorman’s next big adventure #115
I don't like the windows in the top section, I want them at a level that I can see out when I'm in the garage.
/ Doorman’s next big adventure #116
If mine did not have what they call the Star Burst Design they would probably be as you say. Nothing like having to drag a step ladder over to be able to look out.
Kind sir……doorman is in my username.
I train people to hang garage doors!
The top is unusually heavy though
1/2” insulated glass is heavy.
Wife and I had that chat……I was all for a full view (gas station style) door with insulated glass. White powder coated frame. I got shot down. We don’t live on-site full time and too much glass can be bad.
/ Doorman’s next big adventure #119
Us amateurs first timers didn’t have training. We learned the hard way.
The school of hard knock is also a expensive way to learn.
:LOL:
/ Doorman’s next big adventure #120
My windows are high, using the same header height as the 10ft garage door header. Didn't want outsiders seeing into my workshop. But still get natural light into the shop. Jon
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
2013 Kubota RTV1140 4x4 Diesel Utility Cart (A61567)
2013 Kubota...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2001 John Deere 6210 (A60462)
2001 John Deere...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
2007 Volvo C70 Coupe (A61569)
2007 Volvo C70...
