MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,185
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Some type of sandstone?
Moss, if you are asking the rock people use here for road and trail base, its nonesuch shale.Some type of sandstone?
Thanks. Couldn't see any layers in the photos.Moss, if you are asking the rock people use here for road and trail base, its nonesuch shale.
The Nonesuch Shale is a Proterozoic geologic formation that outcrops in Michigan and Wisconsin, United States, but has been found by drill holes to extend in the subsurface as far southwest as Iowa.
The Nonesuch is a lacustrine sequence of shale, siltstone, and sandstone, 150 to 210 m thick, that conformably overlies the alluvial Copper Harbor Conglomerate and is conformably overlain by the fluvial Freda Sandstone.[1] Together, the Copper Harbor, Nonesuch, and Freda make up the Oronto Group.[2] The Nonesuch is Middle Proterozoic, with an estimated age of approximately 1.1 billion years. It was deposited in the Midcontinent Rift.[3] The Nonesuch beds contain common organic carbon and pyrite.
Some years ago I had a salesman* tell me that nylon absorbs some water and wetting or soaking string before use makes it last longer. Going to larger string always helps it last longer. If you're not working against buildings or something you hope to not damage, I'd go much larger than 95.Arly question for you. I put a new string trimmer head on my Stihl weed eater. It will take either 0.80 string or 0.95 string. 20 feet of the smaller and 16 feet of the bigger. Is it worth going to the larger string for durability.
As a side note I threw out all my other string and bought a new one of 0.80. I found a date code on my old string and it was 2011 and another was 2012. I had been beating my head against the wall using it as it was so brittle.
Experience is your friend.I did read up on nylon and see it does indeed absorb a micro amount of water. Nonetheless, when we are whacking our way through whatever weeds-n-shoots, green juice gets flung everywhere. So trying to keep them wet in advance was not worth the hassle so we don't do it.
Be aware that the thicker the trimmer line the quicker your clutch will wear out, and more fuel will be used.Experience is your friend.
We buy it in rolls as well and it takes us a 3 or more years to use up.. Maybe it being kept in our basement is helpfull?My problem was I bought two rolls of Oregon trimmer line from Amazon several years ago, something like 400 feet of it. I just don’t go through that much line so it got old. If you go through a lot of line quickly, trying to keep it wet is probably a waste of time.
I believe the intent is to store it wet to keep it from drying out during storage over time, not for it to be wet during use.I did read up on nylon and see it does indeed absorb a micro amount of water. Nonetheless, when we are whacking our way through whatever weeds-n-shoots, green juice gets flung everywhere. So trying to keep them wet in advance was not worth the hassle so we don't do it.
We've not worn out a clutch on any of the various machines we've operated over the years, including Honda's All using .155 string in them which is much larger than 3mm. Now I'm jinxed?Be aware that the thicker the trimmer line the quicker your clutch will wear out, and more fuel will be used.
I use 3.0mm Stihl line on my Honda b/c, and wear out clutch shoes. OEM shoes are expensive, aftermarket shoes from evilBay are not and perform just as well if not better. Best to inspect the shoes for wear regularly and replace before the clutch drum gets scored.
We've used .155 for 20 years, no clutch issues either?We've not worn out a clutch on any of the various machines we've operated over the years, including Honda's All using .155 string in them which is much larger than 3mm. Now I'm jinxed?![]()
Happened to my Huskys and one of my Hondas (so far), but I really give them a workout with line and metal blades, tackling rough brush and attack ~ 5 cm saplings with a vengeance. And wear down blades on rocks, and cutting weeds down to ground level or below.
We've not worn out a clutch on any of the various machines we've operated over the years, including Honda's All using .155 string in them and/or steel cutting heads........yeah it's crazy that the equipment may get worn out doing the *checks notes* things it's not designed to do?
