trail clearing technique and tools
/ trail clearing technique and tools
Some type of sandstone?
Moss, if you are asking the rock people use here for road and trail base, its nonesuch shale.
The Nonesuch Shale is a Proterozoic geologic formation that outcrops in Michigan and Wisconsin, United States, but has been found by drill holes to extend in the subsurface as far southwest as Iowa.
The Nonesuch is a lacustrine sequence of shale, siltstone, and sandstone, 150 to 210 m thick, that conformably overlies the alluvial Copper Harbor Conglomerate and is conformably overlain by the fluvial Freda Sandstone.[1] Together, the Copper Harbor, Nonesuch, and Freda make up the Oronto Group.[2] The Nonesuch is Middle Proterozoic, with an estimated age of approximately 1.1 billion years. It was deposited in the Midcontinent Rift.[3] The Nonesuch beds contain common organic carbon and pyrite.
/ trail clearing technique and tools #1,004
Arly question for you. I put a new string trimmer head on my Stihl weed eater. It will take either 0.80 string or 0.95 string. 20 feet of the smaller and 16 feet of the bigger. Is it worth going to the larger string for durability.
As a side note I threw out all my other string and bought a new one of 0.80. I found a date code on my old string and it was 2011 and another was 2012. I had been beating my head against the wall using it as it was so brittle.
/ trail clearing technique and tools #1,005
Thanks. Couldn't see any layers in the photos.
Some years ago I had a salesman* tell me that nylon absorbs some water and wetting or soaking string before use makes it last longer. Going to larger string always helps it last longer. If you're not working against buildings or something you hope to not damage, I'd go much larger than 95.
* complete BS?
/ trail clearing technique and tools #1,007
I’ve read keeping it wet helps also. I think it’s on Stihl website. At the Stihl dealer they said put a little water in a zip lock bag and seal the string in it. The old string I just threw out I soaked in water overnight and it didn’t help.
/ trail clearing technique and tools #1,008
I saw this mentioned a few messages up and I was like "pfff right" but reading further on the 'net apparently the nylon the trimmer line is made of is a hygroscopic material (absorbs water from the air or liquid) and it helps keep it plastic.
Given that my tool shed gets very hot in the summer, and dry, this is going to be a game-changer for us here; I think I'll get a bucket with a lid, put water in the bottom + a brick, and keep the spool of trimmer line on top of it.
I did read up on nylon and see it does indeed absorb a micro amount of water. Nonetheless, when we are whacking our way through whatever weeds-n-shoots, green juice gets flung everywhere. So trying to keep them wet in advance was not worth the hassle so we don't do it.
/ trail clearing technique and tools #1,010
Experience is your friend.
/ trail clearing technique and tools #1,011
Be aware that the thicker the trimmer line the quicker your clutch will wear out, and more fuel will be used.
I use 3.0mm Stihl line on my Honda b/c, and wear out clutch shoes. OEM shoes are expensive, aftermarket shoes from evilBay are not and perform just as well if not better. Best to inspect the shoes for wear regularly and replace before the clutch drum gets scored.
/ trail clearing technique and tools #1,012
My problem was I bought two rolls of Oregon trimmer line from Amazon several years ago, something like 400 feet of it. I just don’t go through that much line so it got old. If you go through a lot of line quickly, trying to keep it wet is probably a waste of time.
We buy it in rolls as well and it takes us a 3 or more years to use up.. Maybe it being kept in our basement is helpfull?
/ trail clearing technique and tools #1,014
I believe the intent is to store it wet to keep it from drying out during storage over time, not for it to be wet during use.
We've not worn out a clutch on any of the various machines we've operated over the years, including Honda's All using .155 string in them which is much larger than 3mm. Now I'm jinxed? :ROFLMAO:
/ trail clearing technique and tools #1,017
Have you actually had a look at the shoes? There's no noticeable difference in performance, sound, feel when the friction material is completely worn away, and the drums are very tough but will get scored eventually if it's just metal to metal.
Happened to my Huskys and one of my Hondas (so far), but I really give them a workout with line and metal blades, tackling rough brush and attack ~ 5 cm saplings with a vengeance. And wear down blades on rocks, and cutting weeds down to ground level or below.
Toughest blades I've found are Stihl's BrushCut which fit the Hondas. I sharpen them after every use, they work best when very sharp, but of course they shrink in diameter fairly rapidly - I consider them as consumables.
Have a look on eBay, there's several versions of aftermarket b/c shoes and drums for the different brands, it's not just me wearing them out:)
For Hondas there's aftermarket Heavy Duty shoes available, that's what I've bought.
Easy to check the wear, just undo the screws holding the housing to the motor.
/ trail clearing technique and tools #1,018
yeah it's crazy that the equipment may get worn out doing the *checks notes* things it's not designed to do?
We've not worn out a clutch on any of the various machines we've operated over the years, including Honda's All using .155 string in them and/or steel cutting heads........
2020 CATERPILLAR 320 GC EXCAVATOR (A65056)
2020 CATERPILLAR...
9008SFL (A64556)
9008SFL (A64556)
2007 Freightliner M2 106 T/A 3,150 Gallon Septic Wet Vacuum Truck (A66736)
2007 Freightliner...
2023 Maybridge M79 3 Point Hitch Carrier Chain Harrow Lift Tractor Attachment (A66734)
2023 Maybridge M79...
2023 Monroe-Tufline DS1120T 10ft. Hydraulic Box Scraper Tractor Attachment (A66734)
2023...
Superior Trailer Product 15 Ton Yard Truck Ramp (A66736)
Superior Trailer...
