Kubota L2800 tires
/ Kubota L2800 tires #1
racer86y
2010 Kubota L2800
I have owned the tractor for less than a year and have replaced tire because of rolling the tires.Tire guy said to put tubes in front tires.I have bought 4 tubes for front tires in 5 months or so.What can be the issue?I have checked tires for size and they are right.Tubes are right size.I give up.Any ideas?
/ Kubota L2800 tires #2
What pressure do you run in them? I keep them around 40 PSI... I only roll them off when they are low (Have a tube in one and need to put a tube in the one that loses air!!!)
/ Kubota L2800 tires #3
Type of tire?
I got tubes in both at 20 lbs
/ Kubota L2800 tires #5
If you have a loader on your tractor I don't think that is high enough. I run mine at the max cold pressure written on the tire but mine are R4
/ Kubota L2800 tires #8
The tire information you gave means they are Ag / R1
Also, what Ply tires? (written on the tire) I guessing you might have the 4 ply vs. 6 or 8.
What does your tire say (on the side wall) about what PSI to run them at?
20 PSI does seem low...
With 4x4 and AG; are the tire sizes: Front: 7-16. and the Rear: 11.2-24
Sorry,tractor is on property a ways away.I will find out later today
Yes i do have a loader
/ Kubota L2800 tires #12
Not sure what the one pic of a tire warning is supposed to show.
But put them at 35-40psi if you have a loader.
20psi.....yea no surprise you are rolling them off the rim.
That is all the writing that is on the tire.I will air them to 35,thanks
/ Kubota L2800 tires #14
I looked up your tire, it is 6 ply and the pressure should be 36 psi (35 it totally fine). Air gauges are at best "rough" estimates!!!
I put them at 35.Its a waiting game to see if it works.Thanks for the help.Will holler back in about 3 weeks if it helped.
Thanks.I got them at 35 now.We will see if it gets less fkats.I hope it works.Tired of
/ Kubota L2800 tires #17
Should be fine at suggested pressure. Being smaller, yet handling quite a load, the front tires require more pressure. Mine are to be at 28 lbs, 14 at the rear. Turf tires, and smaller R-4s or Ag tires would be even higher.
Thanks,thats what i am doing now and tires dont look like they are rolling
/ Kubota L2800 tires #20
Silly question, but it's happened to me - Any possibility there could be mesquite thorns or similar in the tires?
2024 Linx EQ07018RS (A60463)
2024 Linx...
36"x10' Stacks of Sheet Metal (A60463)
36"x10' Stacks of...
CFG Industrial MX12RX (A60463)
CFG Industrial...
Massey Ferguson 1759 (A60462)
Massey Ferguson...
2026 Kearney 102" x 32' Gooseneck (A60462)
2026 Kearney 102"...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
