Kubota L2800 tires
/ Kubota L2800 tires
Yes i do have a loader
/ Kubota L2800 tires #12
Not sure what the one pic of a tire warning is supposed to show.
But put them at 35-40psi if you have a loader.
20psi.....yea no surprise you are rolling them off the rim.
That is all the writing that is on the tire.I will air them to 35,thanks
/ Kubota L2800 tires #14
I looked up your tire, it is 6 ply and the pressure should be 36 psi (35 it totally fine). Air gauges are at best "rough" estimates!!!
I put them at 35.Its a waiting game to see if it works.Thanks for the help.Will holler back in about 3 weeks if it helped.
Thanks.I got them at 35 now.We will see if it gets less fkats.I hope it works.Tired of
/ Kubota L2800 tires #17
Should be fine at suggested pressure. Being smaller, yet handling quite a load, the front tires require more pressure. Mine are to be at 28 lbs, 14 at the rear. Turf tires, and smaller R-4s or Ag tires would be even higher.
Thanks,thats what i am doing now and tires dont look like they are rolling
/ Kubota L2800 tires #20
Silly question, but it's happened to me - Any possibility there could be mesquite thorns or similar in the tires?
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
2018 John Deere Z997R (A53317)
2018 John Deere...
2021 FORD F-150 STX CREW CAB TRUCK (A59823)
2021 FORD F-150...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2016 PETERBILT PB320 GARBAGE/SANITATION TRUCK (A59823)
2016 PETERBILT...
SKIDDED FRAC TANK (A60736)
SKIDDED FRAC TANK...
