2006 L3940 GST Front/rear axle seep repair estimate
/ 2006 L3940 GST Front/rear axle seep repair estimate #1
okiecraig
Creek County, OKlahoma
1972 MF 135 diesel, Kubota L3940
Bought new, has 2700 hours. Started seeing drips inside right front tire, seems to seep about a 1/2 cup every week. Been going on about 6 months, only takes a a few squirts of 80/90w gear oil to refill when I check it before use. Just noticed a few drops on floor inside rear wheel, right side.
Thinking about having hauled to mechanic/dealer for repair as I am greatly annoyed at fluid leaks - been very careful for 18 years to maintain properly. Anyone had this work or similar done recently that can give me a ballpark estimate for replacing seal on a front wheel or a back wheel?
Hooboy, got some estimates for recommended work. Almost $ 4,000 parts and labor for the following:
Replace front axle pivot seal, bearing,
Replace rear wheel axle seal, bearing, (will lose $250 UDT put in last July and cost $250 or more to refill))
Replace fuel sensor (rusted out?)
Perfrom valve adjustment (diesel engine) just because never done in 2700 hrs/16 years. Say they have to remove heat shield and fuel tank. Engine start perfectly every time and sounds smooth, but I ain't a mechanic.
Your thoughts on any or all of the above?
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
2022 JOHN DEERE 700L LGP CRAWLER DOZER (A60429)
2022 JOHN DEERE...
2008 Volvo XC90 AWD SUV (A59231)
2008 Volvo XC90...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2023 VIRNIG RBV50-72" HYD ROTARY BRUSH (A60429)
2023 VIRNIG...
