Kubota L2800 tires
/ Kubota L2800 tires #1
racer86y
2010 Kubota L2800
I have owned the tractor for less than a year and have replaced tire because of rolling the tires.Tire guy said to put tubes in front tires.I have bought 4 tubes for front tires in 5 months or so.What can be the issue?I have checked tires for size and they are right.Tubes are right size.I give up.Any ideas?
/ Kubota L2800 tires #2
What pressure do you run in them? I keep them around 40 PSI... I only roll them off when they are low (Have a tube in one and need to put a tube in the one that loses air!!!)
/ Kubota L2800 tires #3
Type of tire?
I got tubes in both at 20 lbs
/ Kubota L2800 tires #5
If you have a loader on your tractor I don't think that is high enough. I run mine at the max cold pressure written on the tire but mine are R4
/ Kubota L2800 tires #8
The tire information you gave means they are Ag / R1
Also, what Ply tires? (written on the tire) I guessing you might have the 4 ply vs. 6 or 8.
What does your tire say (on the side wall) about what PSI to run them at?
20 PSI does seem low...
With 4x4 and AG; are the tire sizes: Front: 7-16. and the Rear: 11.2-24
Sorry,tractor is on property a ways away.I will find out later today
2017 FORD EXPLORER (A59823)
2017 FORD EXPLORER...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
Deere 350G LC (A53317)
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
