Kubota L2800 tires
/ Kubota L2800 tires
Yes i do have a loader
/ Kubota L2800 tires #12
Not sure what the one pic of a tire warning is supposed to show.
But put them at 35-40psi if you have a loader.
20psi.....yea no surprise you are rolling them off the rim.
That is all the writing that is on the tire.I will air them to 35,thanks
/ Kubota L2800 tires #14
I looked up your tire, it is 6 ply and the pressure should be 36 psi (35 it totally fine). Air gauges are at best "rough" estimates!!!
I put them at 35.Its a waiting game to see if it works.Thanks for the help.Will holler back in about 3 weeks if it helped.
Thanks.I got them at 35 now.We will see if it gets less fkats.I hope it works.Tired of
/ Kubota L2800 tires #17
Should be fine at suggested pressure. Being smaller, yet handling quite a load, the front tires require more pressure. Mine are to be at 28 lbs, 14 at the rear. Turf tires, and smaller R-4s or Ag tires would be even higher.
Thanks,thats what i am doing now and tires dont look like they are rolling
/ Kubota L2800 tires #20
Silly question, but it's happened to me - Any possibility there could be mesquite thorns or similar in the tires?
2011 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR3BJ325816 (A61165)
2011 International...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
