Importing and modifying a new mini excavator from China
/ Importing and modifying a new mini excavator from China #501
That company in TX that imported all the AgroTK machines is a good candidate for a US-based source of parts, accessories, and advice. No importer that I have heard of has stepped up so far. Service will have to be local, and mostly DIY. I think that with a good knowledge base and simple construction, repairs will not be difficult.
Not for me. I am old and not interested in any job or business any more. The
technical side still interests me...that is why I started this thread. I still have a lot of spares here.....
Yes Stick With It. I think that they are easy enough to keep Patched Together with Locally Sourced Parts. Agro TK or Ground Hog seem to have some Off stuff like Tracks and Rollers available.
And truly, What will wear out using it 100 hours/year like most candidates.
Together we can sort out Hydraulic Fitting Sizes and Adaptors when needed, Gas Cap Issues, Exhaust extensions and the little stuff we have come across.
Kinda why I signed up to this Thread. And you seem to have the most knowledge having run one longer, and brought it over personally.
I have been watching to see if the Power DUmpers hit the Auction soon, or I might be asking more about the Importing Process.
/ Importing and modifying a new mini excavator from China #502
Hopefully the toaster is finished. The last of the new grates are put in.
/ Importing and modifying a new mini excavator from China #503
My mini has about 6 hours on it now.
While motoring down to the pond I'm cleaning out , the left track started walking off.
I caught it in time to get it back on with a digging bar .
Crawled it slowly back to the shop and realized there was no way any wrenches would fit into the access hole for the adjuster.
Don't know if any one else has had this problem but heres what i did .
/ Importing and modifying a new mini excavator from China #504
Access was tiny. So out comes the cut off wheels.
/ Importing and modifying a new mini excavator from China #505
New access works great, nice and big . Im now wondering what the proper tension should be . Any one have a clue.
Access I felt needed needed a cover to keep out bebris.
/ Importing and modifying a new mini excavator from China #507
Thanks Timber. It's first off the reservation job is next Wednesday. If everything goes according to plan, It will be halfway paid for after 2 days. French drain job and downspout trenches. Very tight spot to get into. Right tool for the job.
As you found out, it is very easy to have the tracks come off, both inboard and outboard. The adjuster uses only spring pressure, and I keep mine at max. The threaded rod is not hard to turn after loosening the locknut. I just use a box wrench.
In making the access hole bigger, you may want to go back and recut those square corners to have a radius. This is a structural member and you are inviting stress cracks at the corners. If you start with drilling a hole before cutting the sides out, you will have your radiused corners.
To minimize track problems, I am extra careful driving over rocks, esp when turning. And I will often turn by lifting with the boom and driving only one track.
/ Importing and modifying a new mini excavator from China #509
The Beach Sand Soil the Cabin is on is full of Golf Ball size and smaller, rocks, and have jammed and jumped my tracks often. I have been able to lift and reverse clean them so far, but yes I have been very careful while traveling. I also turn by Boom mostly to reduce the stresses.
I haven't yet got to a point where a track wouldn't walk itself back on while off the ground.
/ Importing and modifying a new mini excavator from China #510
ALL good points , duly noted.
For the record my excavation work is a retired and bored mans hobby. My mini will likely see less than 100 hours a year. It is a great additional tool so far.
/ Importing and modifying a new mini excavator from China #511
Found on FaceB in Merrill WI. Is this kinda the same machine?
2022 Shalka XG13 Mini excavator. 5 hours on the ticker. Nice little machine. 8500.00 FIRM Possible delivery.
Essentially the same machine, yes.
I can see slightly different boom brackets, swing-boom, cyl protection plates, Rhino-style plastic console cover. The name implies slightly heavier unit, but it looks like the usual 36-37" dozer blade. Same standard crappy bucket.
/ Importing and modifying a new mini excavator from China #513
What do these little units weigh? They just look far too small and light to actually dig a bucket that big into the ground without just pulling the unit itself all over the place.
Most are 2000-2200 pounds. There are bigger units as well.
For as light at they are, starting a hole is easiest (greatest downforce) with dozer blade down and behind you. Once your hole is started, blade down in front anchors the machine best (resists pulling).
/ Importing and modifying a new mini excavator from China #515
Heavier than I expected for as small of footprint as they have. They look like half the size of my JD x758 garden tractor which is less than 1500#. Must be a lot of steel hidden in there.
/ Importing and modifying a new mini excavator from China #516
Agt,Cgf and Fj Industrial all sell a similar machine. The swing boom is a real bonus in my opinion. All seem to come out of Shang Dong.
Quoted weight is 946Kg.
/ Importing and modifying a new mini excavator from China #517
Has anyone attempted an Oil Temp Gauge? I was thinking to tap the Tank for the sensor.
See post #41 above. That's a capillary style temp gauge, which works fine on my machine.
/ Importing and modifying a new mini excavator from China #519
I am not getting the Capillary Tube idea. If it would fit through the Fitting?
So the Return Hose to the Tank has an exit port? Or did you add a TEE, and leave the Sending Unit in the bottom of the tank?
Yes, I used the tee fitting so I could put a capillary tube in the tank. The other drain on the tee is the case drain from the distribution valve. I doubt much oil goes thru that hose, and it was simpler than teeing it into the return line upstream of the added hyd filter.
Note that I disconnected the original return line from this tee, and fabricated a new larger return line next to the new hyd filter.
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A63118)
2022 Schulte...
New/Unused 2025 CFG QK18R Mini Excavator (A61166)
New/Unused 2025...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A63118)
BOSS 990 Fuel...
JOHN DEERE 850J WH CRAWLER DOZER (A62129)
JOHN DEERE 850J WH...
40ft 10-Door Shipping Container (A61567)
40ft 10-Door...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
