Importing and modifying a new mini excavator from China
   / Importing and modifying a new mini excavator from China #511
Found on FaceB in Merrill WI. Is this kinda the same machine?
2022 Shalka XG13 Mini excavator. 5 hours on the ticker. Nice little machine. 8500.00 FIRM Possible delivery.
Essentially the same machine, yes.
I can see slightly different boom brackets, swing-boom, cyl protection plates, Rhino-style plastic console cover. The name implies slightly heavier unit, but it looks like the usual 36-37" dozer blade. Same standard crappy bucket.
   / Importing and modifying a new mini excavator from China #513
What do these little units weigh? They just look far too small and light to actually dig a bucket that big into the ground without just pulling the unit itself all over the place.
Most are 2000-2200 pounds. There are bigger units as well.
For as light at they are, starting a hole is easiest (greatest downforce) with dozer blade down and behind you. Once your hole is started, blade down in front anchors the machine best (resists pulling).
   / Importing and modifying a new mini excavator from China #515
Heavier than I expected for as small of footprint as they have. They look like half the size of my JD x758 garden tractor which is less than 1500#. Must be a lot of steel hidden in there.
   / Importing and modifying a new mini excavator from China #516
Agt,Cgf and Fj Industrial all sell a similar machine. The swing boom is a real bonus in my opinion. All seem to come out of Shang Dong.
Quoted weight is 946Kg.
   / Importing and modifying a new mini excavator from China #517
Has anyone attempted an Oil Temp Gauge? I was thinking to tap the Tank for the sensor.
See post #41 above. That's a capillary style temp gauge, which works fine on my machine.
   / Importing and modifying a new mini excavator from China #519
I am not getting the Capillary Tube idea. If it would fit through the Fitting?
So the Return Hose to the Tank has an exit port? Or did you add a TEE, and leave the Sending Unit in the bottom of the tank?
Yes, I used the tee fitting so I could put a capillary tube in the tank. The other drain on the tee is the case drain from the distribution valve. I doubt much oil goes thru that hose, and it was simpler than teeing it into the return line upstream of the added hyd filter.
Note that I disconnected the original return line from this tee, and fabricated a new larger return line next to the new hyd filter.
2012 SHOP MADE DUETZ MARATHON 60KW GENERATOR TRAILER (A58216)
2012 SHOP MADE...
UNUSED 250 GALLON FUEL TANK (A58375)
UNUSED 250 GALLON...
Giyi Excavator 44" Rake (A57149)
Giyi Excavator 44"...
UNUSED SDLANCH 12' X 20' STEEL CARPORT (A58376)
UNUSED SDLANCH 12'...
2006 FRAC TANK 500BBL WHEELED (A58216)
2006 FRAC TANK...
KBH 25T Tender (A56438)
KBH 25T Tender...
