D'oh
Gold Member
- Joined
- Apr 25, 2023
- Messages
- 321
- Location
- N.W.Ontario Canada EH
- Tractor
- FF12 Mini Excavator/SDL380Stand on Skid Steer/Traner TR45 Wheel Loader
420 B&S has a 10A Charge Coil/Alt, so a 80W 12V like found on Amazon will work or an Marine Blower Fan, would ease Ducting.My LCT 420cc motor has only one charge coil, so charging current is very limited. I installed a small 12V-1amp chassis fan, which has a small draw, but does not move a lot of air.
The main cooling is done by the flywheel fan, and that was ducted to the outside in the original 1-cyl Koop and ChangChai diesels. I used the same ducting for my gasoline engine conversion. None of the Chinese makers seem to do that with the Briggs. Just as they don't upgrade the electrical system to gas from diesel.
Oh yeah, the B&S 420 and Honda GX390 both have 2 charge coils, according to specs and in the ones I have opened up. Not on all engines, of course. Your B&S may indeed have 2, so may be good for running a 7A fan. You can check with an ammeter.
not sure on the Honda
