Importing and modifying a new mini excavator from China
/ Importing and modifying a new mini excavator from China
What is thickness of the stock used?
My ripper is up on my mountainside, not near me now. The business end
is an inch or more thick.
I suggest that you buy a good commercial tooth ($10-15) for larger excavator or backhoe, then cut/weld steel shank to fit. You can use multiple layers of steel bar if you can't easily cut or weld 1-in + stock.
/ Importing and modifying a new mini excavator from China #342
My ripper for my KX040 is 1” ar400. I’d think 1/2” hard plate would be enough for a small mini.
Here are the two I have had. They were sold by different factories, but made exactly the same way. They were about $50-60, FOB Qingdao.
Very strongly made. Weigh only 50# or so.
/ Importing and modifying a new mini excavator from China #344
Anyone know where the idler wheels are greased on these smaller 1 ton machines?
/ Importing and modifying a new mini excavator from China #345
My XN08 uses 2 idler wheels per side. I see no zerk fittings on them. I suspect they use sealed ball-bearings; one or two of them per wheel. I have not take them out, but they look to be easily repairable using standard bearings and a press. I did not buy any spare idler wheels.
/ Importing and modifying a new mini excavator from China #347
Do all of these imported machines have jumpy hydraulics? If not, is there a way to adjust? Mainly, when I lower the main arm for another scoop the machine bounces, which seems unusual to me. Seems like when I open that valve with the stick the valve opens completely rather than gradually. Maybe, I just need to get used to it? One guy told me all the smaller machines are this way, including the name brand machines.
And I said that, too. Even the K008 and 300.9 have this "feature". There is a Utube vid that compares a Chinese 1-ton to a K008, side-by-side.
I opened up one of the stack valves that come with my mini-X, and the spools do have ramps or bevels that smooth the transition between on and off. For the second 1-ton I got, I ordered a slightly smaller hyd pump, but I have not installed it.
Practice and using 2 valves at once help to make operations smoother.
I have operated a 1-ton that had pilot controls. It was somewhat smoother, as the on-to-off transition was a bit slower, but there was still some jerkiness.
/ Importing and modifying a new mini excavator from China #349
I have a friend with a Komatsu pc09 and if you operate it smooth the hydraulics are smooth. So I don't buy that the all machines run like a 5k-7k chinese unit.
/ Importing and modifying a new mini excavator from China #350
Great Thread lets keep it going!
So I found a JF Industrial JF12 fairly close to my home in Ontario Canada. It was 1 of 3 that the Seller purchased at Auction, transported all 3 to his City and sold 2 of them to cover some costs.
I purchased it mainly for at my Cabin, to clean up after last years Flooding. 13hp B&S 420, no Oil Cooler but Filter.
So far I have changed the Zerks, Routed the Exhaust out of the Shield (as mentioned they get Hot), Moved the Mechanical Thumb to the top hole (it is just way to much in the way as was). Which is why I went back to Alibaba in search of a Hydraulic Cylinder and Hoses to Plumb a Hyd. version.
Last Night was quoted FOB Qingdao TE-12 with EPA Engine $3100US, Roof $80, Packaging $100, Free 400mm Bucket and Free Hyd, Rad. Hyd. Thumb $100 (as an extra) Logistics and China Port Free. So Shipping, Broker, any Tariffs and Canada Port Fee extra.
These machines are selling at auctions all over the US for $6500-$9000CDN ($4500-6500US$$) Landed and at a Auction near you.
So I am still looking for a Cylinder (closed @ 14"s) and Hoses to the Aux which I think are JIC thread. Do I need the Lock Out valve seen on some thumbs?
When making my hyd thumb, I cut off the mechanical thumb brackets cuz they were not in optimal locations for a hydraulic unit.
No special valving or RV is required if you match up the cylinder diameters with the bucket cyl. I just used a spare bkt cyl. You DO need to convert the AUX valve from detented to spring-centered. See above.
Can't live without my hyd thumb.
Well, that is not what was stated.
I have not operated a PC09, but there are lots of Utube vids of that name-brand mini. Operating it can be quite jerky as all light-weight units can be. Experienced operators will discover that they can be smoother if they don't run at max engine speed, they feather multiple levers simultaneously, and they don't let the boom or dipper cyls hit the ends of travel.
The multi-cyl diesel engines are happiest when operated at 2000 RPM or so. The 420cc gasoline single-cyls don't make rated power until 3000RPM or more. 3000 RPM is optimum in that case. The PC09 has a 2-cyl diesel. Most of these diesel 1-tons use 3-cyl 700cc+ engines, which are very smooth and torquey at 2000 RPM. THAT is why a smaller displacement pump is so important for smooth operation of gas-powered units running at 3000RPM.
I also have no doubts that the name-brand units costing $25K+ have high quality valves that can help some with smoothness.
/ Importing and modifying a new mini excavator from China #353
Pick your brain 1 more time?
The Aux Ports, I assume are JIC fittings or are they JIS? Looks like JIS is common in Japan, tough to see 30 vs 37 degrees. If it is JIS, what size? because JIC looks like 3/8"
They are neither. All 3 "brands" of Chinese excavators I have owned or seen up close use metric O-ring fittings, except on the pump.
/ Importing and modifying a new mini excavator from China #355
Just ran into another issue while using it yesterday to prep a driveway extentsion.
Briggs & Stratton EPA Fuel Cap, not venting Amazing the pressure it could hold back, and the gas would actually boil in the tank. These little Hoes get hot in the engine bay.
I have made an exhaust extension to outside, but an incoming airduct might be needed, it is still under 40F here, so operating at 70-90F will be an issue.
Wrapping the Exhaust is next on my list of To Do's
I did wrap my homemade exhaust manifold, and it did make for interesting smells for the next 60-80 hours or so.
I used a generic screw-on muffler, but I am considering a change to a quieter screw-on muffler like you see on the 420cc gas generators. I expect they are much quieter. If I do it, I will post pix here.
/ Importing and modifying a new mini excavator from China #357
Looking into a cooling fan for this mini. Found a small 12v, but it's 6.6amp. I can't imagine this stator running a 6.6 amp cooling fan. Anyone found a better option for cooling these little 13.5 B&S XRs?
My LCT 420cc motor has only one charge coil, so charging current is very limited. I installed a small 12V-1amp chassis fan, which has a small draw, but does not move a lot of air.
The main cooling is done by the flywheel fan, and that was ducted to the outside in the original 1-cyl Koop and ChangChai diesels. I used the same ducting for my gasoline engine conversion. None of the Chinese makers seem to do that with the Briggs. Just as they don't upgrade the electrical system to gas from diesel.
Oh yeah, the B&S 420 and Honda GX390 both have 2 charge coils, according to specs and in the ones I have opened up. Not on all engines, of course. Your B&S may indeed have 2, so may be good for running a 7A fan. You can check with an ammeter.
/ Importing and modifying a new mini excavator from China #359
Aren't there fan motor's that are wound* different and take less amps??
*can't spell the correct word....
12V cooling fans are made for electronics, or automotive use, mostly. The size and amperage of the motors used are all over the map. Electronics use, usually 0.1 to 1A or so. Automotive use is much higher, sometimes over 10A.
I see a lot of good candidates for auto use on eBay. Smaller ones of 6-8" diameter, but they do not always tell you what the amperage is. More amps means more power, and more air flow.
UNUSED RAYTREE RMH680 HYD HAMMER (A62131)
UNUSED RAYTREE...
2018 New Holland C227 Compact Track Loader (A63118)
2018 New Holland...
2020 International MV607 Cab and Chassis Truck (A61568)
2020 International...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A62129)
CATERPILLAR 631E...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
