Full figured 25hp Tractors
/ Full figured 25hp Tractors #21
How do you like the R-14 or whatever tires? I've always used ag tires on tractors, and industrial on construction equipment.
Now keeping in mind I have little experience with ags, the R14 tires are far and above industrials in snow and mud, and are easier on grass. Though not as easy as turf tires, but I suppose that's a given.
/ Full figured 25hp Tractors #22
You're definitely in the fun stage of shopping, so enjoy it, try out everything you can think to.
/ Full figured 25hp Tractors #23
I paid about $22,000 for a L2501 HST 4x4 r1 tires with loader a year ago using the equine discount. The equine discount has been reduced since then and it was my understanding at the time that Kubota was about to raise prices, too. Can't say what prices are today.
The 4x4 makes a decided improvement in traction compared to my 2wd tractors. My advice is buy 4x4.
HST is great for varying ground speed to ground conditions and loader work. I understand it eats some power when it comes to running a mower, but I've never used it to mow so I can't offer any personal experience about that. If you don't mind going a little slower if you have thick vegetation, I would suppose its workable.
With the 4x4 and low range, I can drag some pretty decent sized trees, but I have to watch what I pickup with the loader when it comes to tree trunks. I mostly use low and medium range. The high range is only good for the highway in my personal opinion.
If you plan on moving a bunch of heavy trees with the loader, you may want a bigger tractor. I suggest looking at this weight estimator and comparing it against the loader lift capacity of the tractors you are considering. Green Log Weight Charts & Calculator | Sherrilltree
I'm a little surprised at the prices you posted. This dealer has their TYM prices on their website: All Inventory | Tri-County Equipment Parts & Equipment They show a t264 (25hp hydro) with loader for $16,900. A T474 48hp shuttle shift model with loader is $27,500.
/ Full figured 25hp Tractors #25
Current L285 'should' weigh around 2230 lbs; plus water filled rears. Seems like it runs out of traction before it runs out of power with 6 ft box blade pushing; and runs out of front weight before it will stop pulling.
If pulling a Box Blade to distribute dirt is important to you the dinky wheels/tires on a Subcompact tractor will be a major performance disappointment.
  • Larger wheels and tires provide more tractive power pulling ground contact implements and logs, pushing a loader bucket into dirt and pushing snow. Larger wheels and tires permit heavier tractors to bridge holes, ruts and tree debris yielding higher operating speed with less implement bounce and operator perturbation.
  • The dinky tires on Subcompact tractors effect the geometry of the Three Point Hitch. Even though some Subcompact tractors specify they have a Category I Three Point Hitch, that does NOT mean implements from tractors with larger diameter wheels and tires will connect. Subcompact tractors often require implements sized specifically for the Subcompact tractor category.
When considering a tractor purchase bare tractor weight first, tractor horsepower second, rear axle width third, rear wheel/tire ballast fourth.
/ Full figured 25hp Tractors #26
What makes/models are in that bigger/heavier/more capabable than a sub compact, and still in the cheap, small range? I assume the 25hp emissions stuff is the reason for a significant price jump right at that border line.
Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
Every tractor brand includes Compact tractor models weighing from 2,700 to 2,900 pounds bare weight with a less than 26 horsepower engine.
Yes.
Stricter Tier IV off-road diesel engine emission reduction standards phased in dealer tractor inventory during 2009 - 2012, impacting tractor prices.
Tier IV emission standards require tractor manufacturers to add or revise pollution reduction technology on new tractors generating over 19 kW power = 25.4794 horsepower.
DPF is used by the majority of tractor manufactures for emissions control on OVER 25.4794 horsepower tractors.
Tier IV technology complicates the engine and exhaust package and is a significant cost factor. However, the pollutants emitted by a Tier IV technology tractor are about 1% of the pollutants emitted by a non Tier IV tractor.
Diesel Particulate Filter (DPF) captures exhaust particulates (soot) in a ceramic matrix. When tractor engine runs sufficiently hot, accumulated particulates burn off periodically without operator intervention. If engine is not run continuously hot long enough to burn off particulates, diesel soot accumulates in the matrix. Once heavy soot accumulates in DPF the tractor forces soot clearance with the tractor parked and throttle open to about 2,200 rpm for about sixteen minutes, which makes the DPF REALLY HOT to burn off all accumulated soot. Burning off accumulated soot, either during operation or parked is called REGENERATION.
If there is no DPF there is an alternative incendiary technology to burn off very fine particulates (soot). Sometimes exhaust heat is elevated all the time, sometimes periodically.
Diesel particulates must be burned. THERE IS NO FREE LUNCH.
/ Full figured 25hp Tractors #27
That probably includes "Insurance". KATAC was almost $200/month for my M4, no freaking way.
KTAC is $275 a year for my $21k RTV. I can't imagine it being that much for a SCUT but maybe!
/ Full figured 25hp Tractors #28
OP Branson as a Brand is going away. They were purchased by TYM a few years ago and now the Brand is phasing out. Right now they are still making the previous models under the TYM name, but with TYM also having very similar models I doubt they will continue making them both in the coming years. Something to think about. Personally I would just buy a TYM made/branded machine.
I would also recommend the same for RK. RK isn't a tractor servicing company. Yes they might have a mechanic at one of the sites...but they aren't going to be as good as a true tractor dealer/service location such as Kioti, Deere, TYM, etc. Personally I would stay away from them and just get a TYM.
/ Full figured 25hp Tractors #29
I put Mickey Thompson Baja Truck tires on my JD, when it was time to replace the turf tires. R14 wasn't out yet. I like them a bunch. Go with the R14's.
/ Full figured 25hp Tractors #30
Unfortunate if not extremely common with old Kubota L-whatevers.. if it was the 4wd version you'd probably just keep going!
I looked at the l2501 to l2502 improvements.. moved brakes to the left side, ok that's an actual upgrade. Rest of the list: LEDs bruh, rubber floor mats, arm rests.. seems to me there is not much difference on the tractor itself. Apparently there is a new loader with it, didn't look into that.
But in general the concept of hooking a bigger tractor to the same size engine is a good idea if you intend to push/pull against things or lift heavy objects. If you are just dragging a bush hog around and that's it, then the ride quality and ground clearance would be your only real benefits.
But i expect a tractor to be the vehicle equivalent of a leatherman so i'd want the weight (AND 4WD non-negotiable) even if i didn't plan to need it right away.
/ Full figured 25hp Tractors #31
Tires to me a terrain and use case dependent. We have R-1s on the farm tractor and I have R-4s on my L6060 which is a forestry management machine in the Rocky Mountains. I would never run R-1s in the mountainous, rocky terrain. R-4 is much wider, more stable on hills, and thicker ply so more puncture resistant. That's why they are usually more expensive.
That said R-1 if you really need traction (plowing, muddy areas, etc). I would not run R-4s in a field for farming activities if given a choice.
I am not sure of the thickness/ply rating on the R-14s but for me that would be the most useful info to decide.
/ Full figured 25hp Tractors #32
/ Full figured 25hp Tractors #33
There is a TYM dealer in my area who has recently begun promoting the Branson 2515H heavily. I don't think he was selling Branson before the merger, but he's really promoting 2515s now. I don't have any inside information whether TYM is trying to clear our Branson models or if they really intend to keep selling this particular model. But it looks like the TYM dealer has jumped in with both feet to sell them.
As for the 2515H, my impression is that it has really good loader capacity and hydraulics, but it's still a 25hp tractor when it comes to operating a rotary cutter. If the OP primarily needs loader capacity and not HP for mowing, then certainly the OP should consider that model.
/ Full figured 25hp Tractors #34
TYM didn't have an equivalent in it's lineup, so I imagine the dealers are happy to have them.
I love that OP used the term 'full figured.'
/ Full figured 25hp Tractors #35
So, I've been wanting to upgrade my Kubota L285 2wd gear tractor for a while.
Kubota L285
Dimensions
Wheelbase67 inches
170 cm
Length118.5 inches
300 cm
Width62.625 inches
159 cm
Height55.25 inches
140 cm
Weight2230 lbs
1011 kg
Ground clearance13.325 inches
33 cm
Engine Detail
Kubota V1500-A
diesel
4-cylinder
liquid-cooled
Displacement90.7 ci
1.5 L
Bore/Stroke3.000x3.234 inches
76 x 82 mm
Power30 hp
22.4 kW
Pre-heatingglow plugs
Rated RPM2400
Starter volts12
Oil capacity9.4 qts
8.9 L
PTO (claimed)
26.5 hp
19.8 kW
/ Full figured 25hp Tractors #36
This video tells the real story of the Merger. You might see TYM on some decals but Branson is still building them .
So, that TYM/Branson 2515H seems like it is worth looking at. Also been watching/reading about MF 1526 and MF 1826E; gonna take a look at the L2501 on the Kubota pricing site, and see if that's in the ball park. I will say "scale" doesn't translate well in pictures/spec sheets. Weight and tire sizes do, though.
Of coarse I will also keep an eye out for used.
What is the equivalent size for LS and, I guess I should atleast check prices on JD.
/ Full figured 25hp Tractors #38
This gives you a good scale of a 2515H . It’s not huge and not small either . It turns on a dime and works well in the woods . I did load the tires and have not had much trouble picking anything up.
/ Full figured 25hp Tractors #39
It would be interesting if we could figure out a way to do a practical comparison of your 2515H and my L2501 from the viewpoint of actually owning and using them.
Comparison chart posted by a dealer: https://www.kenotractors.com/wp-content/uploads/2020/03/2515R-2515H-Comparison-Chart.pdf According to the chart, the 2515 has a loader lift capacity of 2,200 lbs vs 1131 for the L2501. That is a substantial difference.
Also looks like the 2515 has a suspension seat and a fuel tank located at the foot rest area so no lifting 5 gallon cans up to the hood like my L2501.
/ Full figured 25hp Tractors #40
The equivalent LS is the MT225E; there is the smaller MT225S, that's a nice machine too. John Deere's offering in this market is the 3025E and 3025D; they're actually separate machines despite seeming so similar.
Also, still got to fly the flag here, the Kioti CK2620 (or CK2610 if you can find one) is worth a look.
Really, they're all respectable tractors, and it really comes down to which one you feel the most comfortable with. Be it physical comfort, or the comfort that comes with a good dealer.
2016 PETERBILT 567 TRI AXLE ROLLOFF TRUCK (A65643)
2016 PETERBILT 567...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A65643)
2015 VANTAGE...
Minneapolis-Moline U Tractor (A66285)
Minneapolis-Moline...
Skid Steer Trailer Mover (A65640)
Skid Steer Trailer...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
