Full figured 25hp Tractors
/ Full figured 25hp Tractors #1
paulsharvey
Super Member
Hawthorne, Fl
Kioti CK2610 HST
So, I've been wanting to upgrade my Kubota L285 2wd gear tractor for a while. Wasn't too serious about it till maybe last 18 months. Kinda talked my self into the idea a sub compact would do, but really wanted something bigger. Then caught a look at the Rural King RK25. Now, what should I be comparing it too? Mahindra Max, TYM T26?, Massey 1526, Mahindra 1626; Kubota L2501?
When I "Build Your Own" on Mahindra and TYM, I end at like $25k for a 25Hp Compact with a loader. Massey Ferguson doesn't seem to have a build your own option, but seems $22,500 is the price. When the RK seems to be around $17,000. Seems like a RK37 is about the price of some of the 25hp in-between sized machines.
Obviously, if price wasn't an issue; I would prefer a Massey 4x4 in the 40 hp range; but money is always an issue, and I don't need it, I'm not farming.
My L285 is 28.5 PTO HP, use a 4 ft flail mower, 6 ft box blade, and a home made single bottom plow. It's 2wd, strong arm steering, have to guess what's wrong each time you go to use it, ect. Ag tires on back, car tire on front.
Idea is I mow with an older JD riding mower, hydrostatic, with a deck that as more holes then metal; and have the old Kubota; and replace both. I dont 'need' it; but I told wife, when time comes, I see no reason to pay $2k for a mower, when that would make 8 months of payments. Would finance anything new. Want 4x4, I'm 90% sure I want hydrostatic, Ag, Industrial, or R14 tires, and a loader. At this point, I'm pretty sure I don't want (or don't want to pay for) a back hoe, for money reasons, and the fact that I would 99% want it off. Might either keep using old Ford 48" flail or maybe a 60" rear finish mower. Would consider getting rid of 6 ft frontier box blade (it's frankly too big for the L285, but it was like $200). I have considered the idea of a 54"-60" mid mount mower, but at this point, I think I've decided against it.
I do all my own repairs, but don't really enjoy it, and frankly, want something that when you turn the key, starts and runs, without messing around.
Would definitely like to go to a 30-40 hp 4x4, just can't justify. Mow, move dirt (sand), spread millings, move dead trees, ect; maybe get a tiller or disc at some point.
Rural King doesn't do trades; 1 dealer sells TYM, Branson, Bad Boy, and Kioti, that would probably take my Kubota on trade, but its not worth much.
Also, got to convince a wife that really thinks it's a toy; but when she saw the RK 7 year 0%, 0 down with payments of around $299; "That's really not bad, we pay more then that for cell phones each month".
Would Not do a tractor/trailer package; got a 7000lbs, 6'4"×16' (from the dealer discussed above).
Correction, $17,999 for the RK25 ($299/month).
/ Full figured 25hp Tractors #3
I read it all once but did not see any questions - is it jut me?
Personally I would buy a used tractor and no way would I have any monthly payments.
It looks like you are looking mostly at the bottom of the flood chain brands.
/ Full figured 25hp Tractors #4
7 years 0% down IS NOT 0% interest. If you do the math you are paying an extra $6500 over that $18k sticker just for financing (if the payment is $297/month for 7 years). That's a complete rip off in my book.
/ Full figured 25hp Tractors #5
Not sure where you are getting your prices, but my new TYM T574H was $29k for the tractor and loader. Probably a little bigger than your target, but pricing for 2515H is under $23k for a package with a mower and box blade...should be less than $21k for just the tractor.
Maybe TYM didn't list price on the configuration tool; Mahindra did; want to say base was $20k; plus $5,500 with loader and bucket.
Edit: Looks like a TYM 264 is around $18k; not 100% if that's the clone of the RK25, or if its the smaller model
What makes/models are in that bigger/heavier/more capabable then a sub compact, and still in the cheap, small range. I assume the 25hp emissions stuff is the reason for a significant price jump right at that border line. With an actually decent lifting capacity, decent travel speed, ect. It seems like the MF GC series; Kubota BX, JD 1025; whatever are all giving up a lot of weight, lifting, ground clearance and other capabilities.
/ Full figured 25hp Tractors #8
If you have a good Branson dealer I would go with the 2515H . I compared all the features you get to other brands and it came out way on top . Good luck with your search. Searching and research is half the fun. It will be so fun to use. Your wife will love it . Mine is learning!
I will also add; if anyone bought one of these size machines; any regrets on size power? Especially if you moved down in size from an 1970s vintage larger tractor, to something more modern and smaller.
Edit: Also; anyone absolutely hate 2 speed hydro; as in does it have 1 speed too slow to out run a rock and a 2nd speed useful only for road running it? I'm used to 1-8 w/ 1-2 reverse speed; and do most work in 2nd or 3rd. (Not saying I do or would dislike; this is an actual question, not a statement)
/ Full figured 25hp Tractors #10
No regrets at all on my 25 hp Branson . I did have to learn what gear to be in when working with different implements but it has done everything I’ve asked of it . They say after your warranty is up you can turn the HP up to around 35 hp. Not sure I’ll do it when the time comes . This project alone saved me over 5K. I got 7 quad axle loads spread in one weekend.
/ Full figured 25hp Tractors #11
The RK37 is a clone of the T374, I believe. The RK25 is a clone of the T25. (24.7 HP)
/ Full figured 25hp Tractors #12
That probably includes "Insurance". KATAC was almost $200/month for my M4, no freaking way.
/ Full figured 25hp Tractors #13
Tractor capability is more closely correlated to tractor weight than any other single (1) specification.
The most efficient way to shop for tractors is to first identify potential tractor applications, then, through consulataton, establish bare tractor weight necessary to safely accomplish your applications. Tractor dealers, experienced tractor owners and TractorByNet.com are sources for weight recommendations.
Sufficient tractor weight is more important for most tractor applications than increased tractor horsepower. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
RK25H is a Subcompact tractor. Bare tractor weight: 1,881 pounds.
Ground Clearance: 7.7 inches.
Five reasons owner/operators trade up from a Subcompact Tractor:
More tractor weight.
More FEL lift capacity.
Greater ground clearance
Three-range (3) HST rather than two-range (2) HST.​
(Lower LOW, Higher, HIGH) (Higher ground speed.)​
More tractor engine horsepower to operate wider PTO powered implements.
Near me; we have 2 RK stores that sell tractors; TYM; Kioti; LS; Mahindra (seems it's a diffent dealer every few years, but consistently have one within 1 hour); Yanmar (sells mostly trailers and mowers); John Deer(mostly geared towards Ag tractors); Kubota (mix of small, ag, and construction); Massey Feguson. There is also one dealer that has some Bobcats too; but I think he's 90% Mahindra.
The used market; its primarily cash only; and 25-50hp good condition, 4x4, hydro, w/ loaders seem to be asking atleast full price as brand new.
/ Full figured 25hp Tractors #17
If wanting to stay at 25hp, I would be considering the Kubota L2502, they finally upgraded the l2501 a bit.
A note on kubota tractors
I’ve owned several, have sold several
Every one I sold, I sold it for more than I paid for it.
RK25H is a subcompact tractor. Bare tractor weight: 1,881 pounds.
Current L285 'should' weigh around 2230 lbs; plus water filled rears. Seems like it runs out of traction before it runs out of power with 6 ft box blade pushing; and runs out of front weight before it will stop pulling.
/ Full figured 25hp Tractors #19
I have to go slow with a 6’ blower on the back
That's a pretty big blower for that sized tractor. But hey! If it works it works! 👍
I read the OP's questions and comments; but anything I had to add has already been covered.
The only brand I didn't see listed, but might warrant a look is LS. All of the brands mentioned are worth buying.
/ Full figured 25hp Tractors #20
So, here is an LS subcompact tractor for info:
And a 25 hp 'compact' size:
IMHO, you definitely need to go see, sit on, and possibly try out multiple tractor brands. Right now, prices are still higher than they were just a couple years ago.
Don't fall for the "0% interest".... it's just added to the 'base' cost. If you wanted to pay it off early, you don't save anything on interest. Conventional financing, sure, you pay interest..... but, if you pay it off early or pay some additional, you definitely save on the interest.
Good luck with your search!
2011 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64556)
2011 Chevrolet...
1999 International 5000 SFA Day Cab Truck, VIN # 1HTTWADR6XJ004085 (A65563)
1999 International...
Landhonor Skid Steer 3Pt Hitch Adapter (A62679)
Landhonor Skid...
2001 Mack CH613 Water Truck, VIN # 1M1AA18Y21W144276 (A65563)
2001 Mack CH613...
2009 International 4300 Bucket Truck 55' (A62613)
2009 International...
2018 Chevrolet Impala Sedan (A64557)
2018 Chevrolet...
