Picking up lots of big-ish rocks
/ Picking up lots of big-ish rocks #41
We are in upstate NY and have far too many rocks to deal with. With a JD 1050, we use the FEL most of the time, but often use the boom on the 3-point hitch, and use two webbing straps. This has worked really well when working on stone walls, as you can twist and position carefully. We also use a stone boat rock to drag the really big ones around. But the boom and straps works great.
/ Picking up lots of big-ish rocks #42
Another vote for a grapple bucket, along with lots of counterweight on the 3PH for the largest rocks. I have dug, moved and placed many tons using this method at my home site. With practice, one can get pretty accurate with placement, along with a narrow stump bucket for adjustments once in place as needed.
/ Picking up lots of big-ish rocks #43
I have many many medium to large rocks, ranging from "I can pick this up possibly without getting a hernia" to "I can't possibly budge this", as in 100-500# (I did say "rocks" not "boulders", though some of these may be boulders depending on the definition), that I need to move, and then later place nicely.
Basically, I'm excavating a small pond near our garden, and after I'm done excavating and setting up the pond just right (shaping, then placing a liner) I'd like to arrange these rocks which I've already dug up nicely around the rim of the pond.
Don't have a backhoe. We've moved many rocks around that size over the years to get them off the fields for planting seems like two or three new ones turn up every year. All we do is move them off the field into a hedgerow where they are out of the way - precision placement isn't a priority.
We scoop them up with a bucket on our JD 4600 these days, carry them off, and dump them. Some can be tricky to get, needing another person to help guide them into the bucket. Before the bucket we wrapped chains around them and drew them off with our Case SC, just as my father and grandfather did before us. It works, but does leave a rut.
My Father used to use an old car hood as a sled, with a chain to draw it where we wanted it to go. We gave up on that a while back. Car hoods just ain't what they used to be...
/ Picking up lots of big-ish rocks #44
I want to add one piece of advice. I skimmed the 5 pages of replies and didn't see this mentioned, and I don't know how experienced you are, so I hope I don't come off sounding condescending. I moved some large rocks/boulders when I was new to using my tractor (Kioti CX2510). The one lesson I learned quickly, and thankfully without any injury, it to make sure I have rear ballast if I'm lifting with a front implement. There is a pretty long thread that I started when this happened a couple of years ago. Scared the bejeezus out of me; it's an easy way to get killed. And you mentioned that your ground is not very level and stable. Make sure your ROPS is up and seatbelt is on. Have fun.
Thanks - I know it, but I need to live it more, if you know what I mean; it can't be said enough.
These threads are amusing as after a while you realize that not even 50% of the respondents bother reading the initial question. Still a lot to learn from the responses, one way or another.
To recap: I expect to move some large-to-me (100-500#) rocks a small distance away from the edge of a to-be-made pond. I'll likely be doing that with my backhoe, just pulling them 5-8' back. The thrust of my initial question was how to pick them up and place them accurately. I'm going to try tongs from my backhoe first. Given what I see on the market, I may just build my own.
Pictures will follow when I actually do it (likely later in the summer; I'll be pulling the rocks in the next couple of weeks likely, digging out while the ground is reasonably soft but not as muddy as it is now, and then I can do the rock placement later in the summer when my digging jobs are too tough from ground-bake.
/ Picking up lots of big-ish rocks #46
"My rocks are all almost where I want them now; I actually just need to drag them away from a work space, do more work, but then carefully place them."
This is your best answer. Initially moving the rocks with your tractor to a staging area, then once you're ready, rent the excavator to place 'em... Easy Peasy Mate!
/ Picking up lots of big-ish rocks #47
I have moved or learned to live with most all the big rocks on my 80. However - there is one I'm still working on. It's bigger than a normal car and located smack dab in the middle of my 20 acre high meadow.
It's come down to this. I WILL chip away and finally move it OR I will croak and my son probably won't care much about this rock.
/ Picking up lots of big-ish rocks #48
I had to mow around a similar sized boulder in the middle of a well groomed field for more years than I can remember. It was partially embedded so I couldn't roll it with any of my machines. I thought of renting a dozer but that would destroy the grass.
My wife's father, an old time farmer, suggested I build a bon fire around it. Let it burn for a couple of days and then douse it with water. I thought he was nuts at first but after some research, I found that was the way they did it back then. What the heck. I had cut down some diseased pine a couple of years ago so I cut up the well seasoned trunks and piled them around the rock. If nothing else, I figured it was a way to get rid of the downed trees.
I have several friends on the local VFD so I invited them over for a party. We lit 'er off and spent the afternoon and well into the night drinking beer & toasting hot dogs and getting pretty toasted ourselves.😁 I kept the fire going for the next day and night. On the third day, the guys brought one of the fire trucks up and put out the fire. They emptied most of a thousand gallon tanker on the rock.
Sure enough, it fractured into hundreds of smaller chunks which I managed to move with the FEL on my Kubota MX5800. Yeah, it left a burn spot about 25' in diameter but after 2 years and some seed, you can hardly tell where is was. It was an interesting experiment made possible by a couple of cases of beer, a wood supply and some friends on the VFW.
/ Picking up lots of big-ish rocks #49
All the land around me - for miles - was originally given by the government as a form of "homestead". The original idea was - build some form of homestead house and a sustainable garden. THEN - some how or other - explore for oil and minerals.
Well - I think everybody learned - real quick - no oil here folks. The only "minerals" of any value - gravel.
So the story goes - the homesteader to my immediate north had five sons. They had mules and rock sleds. Fields far and wide were cleared of rocks and low, wide rock wall are everywhere. They had cattle, sheep and goats.
A couple of the rock walls - on land just north of mine.
/ Picking up lots of big-ish rocks #50
Id use forks on the loader.
That's what I did when setting about 30 tons of rocks from 500-800 lbs. Built bridge abutments. Final positioning with backhoe. Didn't have to modify the machine. Keep it simple.
/ Picking up lots of big-ish rocks #51
I've used my pallet forks for hundreds of rocks, big and small, just that way, slide them together and go to work.
Adding a matching grapple just makes them even better!
SR
agree forks are handy for moving logs & rocks, but i certainly would avoid using them as a pry bar excavating stubborn large rocks. moving, fine, i avoid excavating tho
/ Picking up lots of big-ish rocks #52
When I get a rock that I can't get it into the bucket I
get a tie down strap and use it to pull the rock into the
bucket. I have only had two of them so this works for
me. I use the thumb on the back hoe to move smaller
rocks and I don't have very many of them.
If you have a rock that is as big as your tractor you can
drill holes in it and get some dexpan to put in the holes
and it will split your rock.
willy
/ Picking up lots of big-ish rocks #53
Depends on if you have cheapo forks or well-made HD forks.
SR
/ Picking up lots of big-ish rocks #55
I think if one wants to dig/pry with forks (which i think is fine if you know the risk) then you should plan on getting some that are highly overrated for your machine and just eat the lift capacity loss that will get you. But if you read far enough into fork ratings to figure out what they can support way out past 24", on only one fork, and possibly with the weight of your tractor pushing DOWN on the heel of it using it as a fulcrum against the ground.. i think you will find almost any pair of forks that would normally be considered 'matched' to the machine it's on, could easily be bent during digging. I think you need to go 'overkill' compared to the machine itself, to get forks that are safe to dig with on that machine. My .02.
/ Picking up lots of big-ish rocks #56
My wife use to tell me -picking up rocks is good for my waistline. But - my back would become very sore - long before any noticeable changes in my waistline.
And if you notice - pick a field clean. Next year the snow melts - a brand new crop has hatched in the field.
2004 International 4400 Flatbed-Dump (A62613)
2004 International...
2016 Ford Escape SUV (A61569)
2016 Ford Escape...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
2010 New Holland Boomer 8N (A62613)
2010 New Holland...
2019 FREIGHTLINER M2 4X2 S/A NON 26FT NON CDL BOX TRUCK (A59914)
2019 FREIGHTLINER...
