1984 Satoh S650G - Is it worth it, and how about a loader?
/ 1984 Satoh S650G - Is it worth it, and how about a loader? #1
dmizesr
1984 Satoh S560G Bison
Hello friends. I'm new here and I have a couple of questions. I just bought 3.5 acres in Missouri and I'm looking at a 1985 Satoh S650G Bison. It has 6166 hours, inline 4, 3 point hitch, runs well according to the seller, and it's $2750. So, 1) is that a good deal? and 2) Is there a list of loaders somewhere that would fit that tractor with little or no modification? Thanks in advance for the help.
/ 1984 Satoh S650G - Is it worth it, and how about a loader? #2
Satoh Bison S650​
Satoh Bison S650 tractor photo
1973 - 1983
Compact Utility tractor
Series:S550Bison S650
Production
Manufacturer:Satoh
Type:Compact Utility tractor
Factory:Japan
Mechanical
Chassis:4x2 2WD
Final drives:spur gear
Steering:manual
Brakes:differential mechanical internal expanding shoe
Cab:Open operator station.
Transmission:6-speed unsynchronized gear
/ 1984 Satoh S650G - Is it worth it, and how about a loader? #3
This is a gas engine tractor. 6,000+ hours is quite a lot of use for a gas engine tractor.
Are you adept at troubleshooting and mechanical repairs? Do you have metric tools?
Parts for 40+ year old orphan-brand tractors are very thin. (($2,750 would be a HIGH price for yard art.))
Can you operate equipment with a traditional clutch and gear transmission? Shop clutch rebuilds are $1,500 in low cost rural Florida.
Manual steering gets old fast.
2-WD tractors often lack the necessary traction to fill a loader bucket with dirt.
Aftermarket Loaders are available for most tractors. I will guess your cost at $5,000 delivered.
LINK: Front-End Loader - Compact Tractor Aftermarket Loader Suppliers
You would likely need a new, higher capacity hydraulic pump, joystick and plumbing, +$2,000.
Plus labor for installation.
CAVEAT EMPTOR​
/ 1984 Satoh S650G - Is it worth it, and how about a loader? #4
Satoh Bison S650​
LINK: TractorData.com Satoh Bison S650 tractor information
T-B-N ARCHIVE THREADS ON ADDING A LOADER:
Add Loader site:tractorbynet.com
/ 1984 Satoh S650G - Is it worth it, and how about a loader? #5
There are alot of S650 tractors running yet. It was the Japanese tractor widely marketed in the US. I have over 10 S650 parts tractor on my lot. I also have a used loader & a powersteering kit. Engine overhaul parts are getting scarce.
/ 1984 Satoh S650G - Is it worth it, and how about a loader? #6
The FEL for my Mitsubishi MT300D was custom made by Schwartz in Long Lake MN, they’re out there hopefully!
/ 1984 Satoh S650G - Is it worth it, and how about a loader? #7
At 40 years old and 6 thousand hours, any tractor is going to have its own individual personality. Might be good, might be worn out. And Len said parts are getting scarce.
$2,750 is a decent price IF its in good condition, ready to run another several years without major drama. Only a very careful inspection can determine if it is this, or will just be a frustration maker.
In any case that is now a rare model so any wait for parts might be lengthy. For hobby use, NBD. If you might have a critical need - remove storm damage or something - you might want to pay a little more for a more common tractor.
I own a couple of 40 year old Yanmars and they are not a problem at all. But YMMV.
/ 1984 Satoh S650G - Is it worth it, and how about a loader? #8
Schwartz is no longer in business.
/ 1984 Satoh S650G - Is it worth it, and how about a loader? #10
They are a good loader. Does yours have a front pump?
2021 John Deere 1025R (A60462)
2021 John Deere...
2004 VOLVO VHD TRI/A CEMENT MIXER TRUCK (A59906)
2004 VOLVO VHD...
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
4'x6' Stack of Sheet Metal (A60463)
4'x6' Stack of...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
