1984 Satoh S650G - Is it worth it, and how about a loader?
   / 1984 Satoh S650G - Is it worth it, and how about a loader? #1
dmizesr
1984 Satoh S560G Bison
Hello friends. I'm new here and I have a couple of questions. I just bought 3.5 acres in Missouri and I'm looking at a 1985 Satoh S650G Bison. It has 6166 hours, inline 4, 3 point hitch, runs well according to the seller, and it's $2750. So, 1) is that a good deal? and 2) Is there a list of loaders somewhere that would fit that tractor with little or no modification? Thanks in advance for the help.
   / 1984 Satoh S650G - Is it worth it, and how about a loader? #2
Satoh Bison S650​
Satoh Bison S650 tractor photo
1973 - 1983
Compact Utility tractor
Series:S550Bison S650
Production
Manufacturer:Satoh
Type:Compact Utility tractor
Factory:Japan
Mechanical
Chassis:4x2 2WD
Final drives:spur gear
Steering:manual
Brakes:differential mechanical internal expanding shoe
Cab:Open operator station.
Transmission:6-speed unsynchronized gear
   / 1984 Satoh S650G - Is it worth it, and how about a loader? #3
This is a gas engine tractor. 6,000+ hours is quite a lot of use for a gas engine tractor.
Are you adept at troubleshooting and mechanical repairs? Do you have metric tools?
Parts for 40+ year old orphan-brand tractors are very thin. (($2,750 would be a HIGH price for yard art.))
Can you operate equipment with a traditional clutch and gear transmission? Shop clutch rebuilds are $1,500 in low cost rural Florida.
Manual steering gets old fast.
2-WD tractors often lack the necessary traction to fill a loader bucket with dirt.
Aftermarket Loaders are available for most tractors. I will guess your cost at $5,000 delivered.
LINK: Front-End Loader - Compact Tractor Aftermarket Loader Suppliers
You would likely need a new, higher capacity hydraulic pump, joystick and plumbing, +$2,000.
Plus labor for installation.
CAVEAT EMPTOR​
   / 1984 Satoh S650G - Is it worth it, and how about a loader? #4
Satoh Bison S650​
LINK: TractorData.com Satoh Bison S650 tractor information
T-B-N ARCHIVE THREADS ON ADDING A LOADER:
Add Loader site:tractorbynet.com
   / 1984 Satoh S650G - Is it worth it, and how about a loader? #5
There are alot of S650 tractors running yet. It was the Japanese tractor widely marketed in the US. I have over 10 S650 parts tractor on my lot. I also have a used loader & a powersteering kit. Engine overhaul parts are getting scarce.
   / 1984 Satoh S650G - Is it worth it, and how about a loader? #6
The FEL for my Mitsubishi MT300D was custom made by Schwartz in Long Lake MN, they’re out there hopefully!
   / 1984 Satoh S650G - Is it worth it, and how about a loader? #7
At 40 years old and 6 thousand hours, any tractor is going to have its own individual personality. Might be good, might be worn out. And Len said parts are getting scarce.
$2,750 is a decent price IF its in good condition, ready to run another several years without major drama. Only a very careful inspection can determine if it is this, or will just be a frustration maker.
In any case that is now a rare model so any wait for parts might be lengthy. For hobby use, NBD. If you might have a critical need - remove storm damage or something - you might want to pay a little more for a more common tractor.
I own a couple of 40 year old Yanmars and they are not a problem at all. But YMMV.
   / 1984 Satoh S650G - Is it worth it, and how about a loader? #8
Schwartz is no longer in business.
   / 1984 Satoh S650G - Is it worth it, and how about a loader? #9
What is your opinion of a Schwartz loader?
   / 1984 Satoh S650G - Is it worth it, and how about a loader? #10
They are a good loader. Does yours have a front pump?
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
1987 Landall 48ft 35 Ton Hydraulic Slide Axle T/A Drop Deck Trailer (A55852)
1987 Landall 48ft...
Electric Forklift (A55851)
Electric Forklift...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2018 Ford F-150...
2021 KENWORTH T270 (A55745)
2021 KENWORTH T270...
