How are we gonna fix this
   / How are we gonna fix this #1
orezok
Elite Member
Mojave Desert, CA
Kubota B7800
My grandson had the drain in his shower run slow. He tried rooting it several times withou luck. He hired a rooter service and they could not get past a couple of feet before rejection. He then had them camera it to see what the issue was.
Here is what they saw.
They quoted him $3800 to jack hammer out the floor and then replace the tile.
I said that’s crazy and let me see what I can do. I thought about it for a while and said, I wonder if I can pull it out with my shop vac. Stuck it on the drain and in 2 seconds…
Here’s the result.
   / How are we gonna fix this #2
Dude you just have to let the professionals do their job..... quit showing them the country ways.
   / How are we gonna fix this #3
Wow! Good thinking!
You should go show the owner of the company that trick. I'm sure they could a lot of people a lot of $.
   / How are we gonna fix this #4
View attachment 782852Here is what they saw.
Here’s the result.
Well that sucks.
   / How are we gonna fix this #5
Before i saw the results, i was thinking about a magnet gripper tool. I have a flexable one in shop. That vac idea was great.
   / How are we gonna fix this #7
My neighbor is a retired electrician. He used a shop vac, and a line attached to a foam plug to fish a line through conduit so he could pull wires through. It was about 65 feet from the shop to the stable.
I did the same to my garage. I learned that from an electrician at my previous employer. Works great.
   / How are we gonna fix this #8
We did that all the time. On large jobs, had a pressurized tank of helium gas and special adaptor that shot line thru pipes 100’s of feet away.
   / How are we gonna fix this #9
Why would they use helium which is quite expensive vs using compressed air?
   / How are we gonna fix this #10
It was a tank that looked like a scuba tank. Fully portable, and pressures remained stable thru entire tank. Mind you this was 10+ years ago before gasses became so expensive.
2005 Ford Escape XLS SUV (A48082)
2005 Ford Escape...
Three Point Hitch Finish Mower (A48837)
Three Point Hitch...
2011 Honda Pilot EX SUV (A50860)
2011 Honda Pilot...
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2017 PETERBILT 579...
2010 L3 GENERATOR SET (A51222)
2010 L3 GENERATOR...
2013 Ford Taurus SEL Sedan (A48082)
2013 Ford Taurus...
