Solder question (on household copper pipe)
/ Solder question (on household copper pipe) #21
Flushing the toilet with hot water would be a whole different thing though. LOL (Glad you're almost to the end of the saga ;) )
/ Solder question (on household copper pipe) #22
many people use a tempering valve on their toilets, so they get warm water in it. it's more comfortable and prevents the toilet from sweating, especially in the summer..
/ Solder question (on household copper pipe) #23
I don’t see how that is going to work unless you have a small water heater directly under the toilet. The water isn’t going to warm up in the gallon the toilet uses.
/ Solder question (on household copper pipe) #24
Sorry to hear about your issues, but it is consistent with the plumbing experiences I have had. Don't get me wrong; I have worked with great plumbers in the past, but right now, locally, I can't seem to find any, well for lack of a better term, talented ones.
I am in the process of converting bad (thin) copper to PEX. I think it is the way to go, especially if you use the Upnor / ProPEX band clamp system, where you get full flow. The only problem is you need a really expensive tool to install it.
Off topic a little: I'm kinda curious. You say your well is 100gpm. Do you actually pump it out at that rate? If so, what do use that much water for?
Don't get me wrong, I'd love to have a 100gpm well.
All the best,
Peter
/ Solder question (on household copper pipe) #25
I am surprised you use solder. All plumbers I know here use silver solder. Stronger I guess.
No one I know uses Silver solder. It doesn't flow like 95/5 does. and requires more heat
You have to use oxy/ acetylene to melt 15% silver .
The only time I would braze with silver solder is HVAC, or Gas lines which is required by code
I have used stay bright #8 on water lines, which has a higher silver content than normal solder, for a little stronger joint. And can be easily melted with map gas
But to use 15% silver rod and braze every water line joint. Naw..
/ Solder question (on household copper pipe) #26
All the best,
Peter
I think it would take a 10HP. pump to do that!!.. 100GPM??..
/ Solder question (on household copper pipe) #27
/ Solder question (on household copper pipe) #29
I use silver solder using propane torches with hi-heat nozzles and it works better and flows better than 95/5 solder. It takes about the same amount of heat as 95/5. I forget the exact name and percentage of silver.
/ Solder question (on household copper pipe) #30
90% of the time, we used 95-5 which is 95% tin and 5% antimony.
I found that nothing flows around copper pipes better than 95/5
There is a product called stay bright #8 that that contains 94% tin and 6% silver. But in my opinion, doesn't flow to copper better than 95-5, and it does have a higher melting point due to the 6% silver content.
we used stay bright 8 from time to time
/ Solder question (on household copper pipe) #31
I believe lead solder was banned some time back due to the 'lead poisonings' issue as was all lead piping.
(Not that toilet water would consumed.)
/ Solder question (on household copper pipe) #32
All the best,
Peter
Regarding the well.... when it was drilled, his paperwork (certification??) has it at either 103 or 107 GPM. Seems we are near or direct hit in an underground spring (that my wife and locals know about as it used to dump to a waterwheel to a creek but now, has been dammed down stream and is a full blown lake)
Anyway, I tried once to measure my actual flow INSIDE and to be blunt, it was a fail. I was trying to fill a bucket for 30 seconds...and I think I had to back it off to 15 seconds.... but according to my chalkboard math, my flow in the house at the pressure tank (then via hose to outdoors) was something like 20-30 gallons/minute. It's probably been 15 years since I've done that so I might be way off target.... but our source is good.
The wife was very eco-friendly in the beginning, trying to put water savers everywhere.... I told her to look at it this way....."We're on a well. It provides over 100 gallons/minute. At MOST we can only use (let's just say) 30 gallons a minute......so for every minute that we are NOT maximizing our use, we are letting 70 or more gallons go by (and get dumped into the lake ultimately)
When they hit our well, he said it was like the old movies when they hit an oil well and the oil just blows into the sky creating a geyser. (perhaps dramatic but that's what he said)
Given all that, I DO wish they'd let me know more options and maybe put in a larger supply line as I'd love to do an irrigation for my yard. I've already done an irrigation system for the wife's flower gardens.
Three houses here on the farm. My wife's (both now deceased) fathers house and her uncle's house. I don't know their flow rates....I think fathers is something like 8-15 gallons/minute and her uncle (who is closer to us) is something like 3-6 gallons/minute. I don't know how accurate these are BUT, her uncle's house HAS in fact gone dry more than once, losing its prime. So I feel fortunate that we found the main artery with ours.
/ Solder question (on household copper pipe) #34
You are very lucky! Sounds amazing.
My grandfather had an artesian well like that. Wonderful water and lots of it.
Thanks for filling in the details.
All the best,
Peter
2013 Ford Escape SUV (A59231)
2013 Ford Escape...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
Bobcat S740 (A57148)
Yanmar YT359 (A53317)
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
