Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,085
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Simple question first, details after: How many times can you solder, reheat it to take apart, put back and take apart before you have any copper issues (if any?)
Scenario:
Imagine you're framing in a bathroom shower. Hire a plumber and he plumbs everything (BUT swaps the hot/cold sides such that the hot is also supplying the toilet... )
He installs pipes for the shower head, handles and a remote hand held. He puts some 1x6's between the studs to support the copper pipes as they move from one vertical stud to another. On the hand held, instead of putting a female fitting with ears (not sure what it's called) that you can screw a nipple into.... he sweats a copper pipe extension and on that he sweats a male nipple. "ok" on the surface..... until the tile guy comes and doesn't catch it.... turns out by the time the backer board and tile are installed, the tile guy calls me in to let me know that there's an issue.... the threads to mount the base for the hand held are now FLUSH with his tile.
(why the moron didn't see this sooner in his process is beyond me.....but then I admit that I also didn't notice/catch the mounting that the plumber installed)
Well....this might not be a huge issue.... as it turns out I can cut a 12x12 piece of drywall out on the other side and get "some" access to these parts. (I have a knee wall in the way and a toilet in the way so I'm leaning over near 45 degree angle to investigate this BUT it's too late to fix it correctly on the tile side....
So now I'm leaning over & reaching out....working through a 12x12...oh, I've got studs on the left, stud on the right and then I have that confounded 1x6 blocking things. The copper pipe comes up from floor and pulls a 90 to go to the OTHER side of the stud (which is mostly covered by drywall but I can stretch my fingers in there to manipulate things.
Point being, this is like doing surgery on the wall from the BACK side with visual and physical obstructions in the way.
I finally got the original pipe out of the wall and replaced it with the correct parts however, something isn't aligned perfectly.... when you screw the base onto the nipple it goes on at an angle so part of it is going to dig into the tile and the other part has maybe 1/4" gap.
So I need to take it apart.
Yesterday, I (using MAP gas) heated it with wife in shower hoping she could wiggle it a bit to change angle. Didn't work. I now think (but haven't looked as it was hot) anyway, I now think the parts are not fully soldered together.... which is fine. I need to take it apart and try again. I MIGHT slightly enlarge the hole via tile so I can insert a screwdriver to screw the ears to the stud (something he also didn't do) under the hope that it will hold it straight.....but then....I don't know that the relation of the stud to the tile is parallel.....
I've used an auto mechanic mirror (about 2x3 inches) for some of this so I told the wife I now know how a dentist feels when looking at their mirror....it's all backwards!
This is like doing surgery through a belly button, using a mirror so it's all backwards AND you have wood obstructions in the way.
Sigh.
I ultimately am wondering how many times can the copper pipe be heated/reheated before I might have any issues with it? Normally I'm once & done when I'm soldering and if not, I get it the second time when I adjust it.
I fear this is going to be a bigger project than "simply" soldering the parts back in.
Scenario:
Sigh.
