How are we gonna fix this
   / How are we gonna fix this #1
orezok
Elite Member
Mojave Desert, CA
Kubota B7800
My grandson had the drain in his shower run slow. He tried rooting it several times withou luck. He hired a rooter service and they could not get past a couple of feet before rejection. He then had them camera it to see what the issue was.
Here is what they saw.
They quoted him $3800 to jack hammer out the floor and then replace the tile.
I said that’s crazy and let me see what I can do. I thought about it for a while and said, I wonder if I can pull it out with my shop vac. Stuck it on the drain and in 2 seconds…
Here’s the result.
   / How are we gonna fix this #2
Dude you just have to let the professionals do their job..... quit showing them the country ways.
   / How are we gonna fix this #3
Wow! Good thinking!
You should go show the owner of the company that trick. I'm sure they could a lot of people a lot of $.
   / How are we gonna fix this #4
View attachment 782852Here is what they saw.
Here’s the result.
Well that sucks.
   / How are we gonna fix this #5
Before i saw the results, i was thinking about a magnet gripper tool. I have a flexable one in shop. That vac idea was great.
   / How are we gonna fix this #7
My neighbor is a retired electrician. He used a shop vac, and a line attached to a foam plug to fish a line through conduit so he could pull wires through. It was about 65 feet from the shop to the stable.
I did the same to my garage. I learned that from an electrician at my previous employer. Works great.
   / How are we gonna fix this #8
We did that all the time. On large jobs, had a pressurized tank of helium gas and special adaptor that shot line thru pipes 100’s of feet away.
   / How are we gonna fix this #9
Why would they use helium which is quite expensive vs using compressed air?
   / How are we gonna fix this #10
It was a tank that looked like a scuba tank. Fully portable, and pressures remained stable thru entire tank. Mind you this was 10+ years ago before gasses became so expensive.
2015 Ford F-150 4x4 Pickup Truck (A48081)
2015 Ford F-150...
2013 CAT 950K WHEEL LOADER (A50854)
2013 CAT 950K...
2019 Ford F-450 4x4 Crew Cab and Chassis Truck (A49461)
2019 Ford F-450...
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
66in Light Material Bucket Skid Steer Connection (A51039)
66in Light...
2015 CAT CT660 T/A Cab and Chassis Truck (A48081)
2015 CAT CT660 T/A...
