Coolant on the snow?
/ Coolant on the snow? #1
JME81
New England
Kubota LX2610HSDC
I have a 2020 LX2610 Cab, just took it home from the dealer last week. I ran it for about an hour playing with the settings, etc. I noticed the next day some bring green (almost like smushed grass color) drops on the snow. I checked the coolant and the level is at 25%~. Could it be a leak some where? I am going to talk to the dealer but wanted some tips first.
/ Coolant on the snow? #2
Tighten the hose clamps first.
/ Coolant on the snow? #3
Coolant is green for a reason. Any leak should be easy to spot. Open the hood and take a good look, before you call...
I'll do that when I get home (clamps and inspect closer) but I do need to get some coolant from them before I head home. Thank you so far,
/ Coolant on the snow? #5
What was 25% full - the degas bottle or the radiator?
If it was the degas bottle, as long as it’s between the fill marks, you should be ok.
Shouldn’t have any leaks though, so still make sure everything is tight as explained in the prior posts.
/ Coolant on the snow? #6
I spent all summer last season chasing a coolant leak on my ZD1211 mower. I looked that engine over a dozen times and could NOT find a leak, and I was convinced it was losing it internal (usually a bad sign).
Tightened the lower radiator hose clamp.... Voila. So... Don't just visually check the hose clamps, get a tool on them.
/ Coolant on the snow? #8
I had the same thing happen after our Xmas cold spell to -38F, upper hose clamp was worked lose. Guten tite and problem solved.
/ Coolant on the snow? #9
Check the clamps, but that is the recovery/overflow/reservoir tank. As said, just make sure it stays between the Low and Full marks. The first couple times you run the tractor it can change as you purge the air and any extra fluid, especially if the fluids were added at the dealer before delivery. Dont worry if it doesn't stay 'Full', eventually it'll find it's equilibrium and then that level will be what it stays at.
/ Coolant on the snow? #10
Anywhere’s between those lines is good. It needs room to expand/contract with the temp changes. A leak should be fairly easy to see as already mentioned. Not sure if you have dogs but you’ll also want to clean up the spill if it is coolant because it does horrible things to animal innards and it sitting on snow is about the most concentrated way they could get it outside of a puddle.
/ Coolant on the snow? #11
Sounds like the coolant level is perfect. Not unusual for a few drops or spoonfuls to be thrown out when working. Check clamps. Clean up drops to protect our furry friends - it's sweet tasting poison.
It's raining out right now, but took a quick look. The engine bay is dry, no leaks. I ran it for about 10-15 minutes on idle. The clamps on the small hose near the tank is. how would I tighten that one? The larger hose from the radiator to engine, I did not touch yet.
/ Coolant on the snow? #13
@JME81
There is also a large hose at the bottom of the radiator that I don't see in your pictures.
/ Coolant on the snow? #14
That small hose you circled does not need to be tightened; is good as is.
/ Coolant on the snow? #16
It is common for coolant to leak soon after shutting tractor off after working it. The reason being is there normally is a temp/pressure spike after it is shut off. Try looking for your leak about a half hour after shutting it down.
/ Coolant on the snow? #17
The first thing I would do is look at the type of clamp that is being used, and ask myself if it is right for the application. A surprising number of hoses are poorly clamped. That will work for awhile, but eventually will leak. Maybe not much, but a little. And it's preventable.
Coolant system hoses are always made of some sort of flexible rubbery substance - an elastomer. Those materials are flexible and change dimensions with temperature. They are connected by being pushed over a rigid pipe and clamped in place.
Most any clamp will prevent major leaks, but if the aim is also to prevent minor seepage the clamp is going to have to mantain pressure on that softer hose as the hose changes with age and temperature.
That is the reason why so many radiator hose clamps are the constant spring type.
Worm drive hose clamps like the first two pictures below are great for vibration resistance and high torque, but they can't stretch and shrink to follow the change in hose shape and elasticity as it ages. Eventually they leak. That is why you rarely see them used in hi-end coolant and fuel apps.
Continuing to seal an elastic hose to a pipe or spigot as either one changes shape & ages requires a clamp that keeps on clamping. Those are the constant spring type like the ones in the third and fourth pictures below. There are many ways to make a constant pressure spring clamp, but the main feature is an ability to change shape so as to follow a change in the hose as it ages and shrinks.
rScotty
/ Coolant on the snow? #18
The factory clamps are fine.
If nothing is obviously wet, maybe you should just be sure the radiator is full and add some to the overflow tank, then run it - and watch it more.
/ Coolant on the snow? #19
None of the hoses you showed are leaking, and the level in the bottle is still good. The next step is to run the tractor for a bit while keeping an eye on the temperature and fluid level in the bottle. If the temps stay good and the bottle doesn't over flow, you are good to go - run with no worries. The little bit you saw on the ground was most likely just the engine burping out some air and/or excess fluid added in when the dealer did their pre-delivery checks. It happens.
/ Coolant on the snow? #20
The spring clamps are fine. None of the hoses using them are under pressure.
2018 MACK PINNACLE (A65643)
2018 MACK PINNACLE...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
Carpet Cutting Table (A65579)
Carpet Cutting...
2008 PROGRESSIVE 20' X 7' BUMPER PULL TRAILER (A65643)
2008 PROGRESSIVE...
Landhonor ATS-ME18 Mini Excavator (A66285)
Landhonor ATS-ME18...
2011 Caterpillar 420E Backhoe (A64194)
2011 Caterpillar...
