4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 19,194
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
4570man,
Your spot on regarding the SSQA trencher run from PTO hydraulic system and is sole reason my longer term project is finding method to route existing very suitable pump flow capacity to the FEL via a mechanical valve. I foolishly did not buy the 3 point hitch PTO driven 48" six wide trencher in late 2020 when it was in stock and $7K. Now they are 9-11K for Bradco or Virnig and 6 months delivery. I don't buy stuff when price is ludicrous. We will respecfully agree to disagree on some of the other points.
The skid steer and mini of the same weight class will outperform the M59 by a noticeable margin in brute force not even considering productivity. My M59 would lift a 3600 pound bundle of plywood on the forks but it was absolutely done with that. It wouldn’t even consider lifting a 4400 pound bundle of shingles. And when you were pushing it to the limit like that you could tell it really wasn’t built to endure that everyday. My SVL75 will lift the 4400 pound of shingles. I have less factual information to support the mini x being stronger than the backhoe but when you’re digging side by side with a 3ft bucket you can tell a noticeable difference. The mini and skid steer have much heavier duty booms boom mounts and cylinders mounts than the M59 does.
