Oil & Fuel GC1715 Blowing hydraulic fluid
/ GC1715 Blowing hydraulic fluid #42
What is the white crystal-like or foam at the top of the fill tube?
Those are air bubbles. When the fluid enters the return area pressure is released. This depressurization of the fluid can cause small air bubbles to form. Especially if the fluid is cold
/ GC1715 Blowing hydraulic fluid #43
Wow, pictures explain your issue better than any description. An inspection camera down the fill tube might help out here. Something might have gotten dropped in during the fluid change. Don't be afraid of removing the tube for better access. I'm sure someone can provide insights.
I put the old fluid back in the tractor today. Grasping at straws now.
The fluid wasn't cold tractor had been running for a hour or better.
/ GC1715 Blowing hydraulic fluid #47
I can understand your frustration. This is not a typical problem. As hube2 says, the issue seem to be a blockage not allowing the oil to drain back into the sump. The return line from the FEL drains back into the hydraulic lift cover. If it cannot drain, it will continue to fill until it starts coming out of the fill tube, which is actually a good thing as it stops any pressure build up that could blow out seals. The fill tube is only attached by a bolt on its side, and an o-ring in the base. If you remove it, it may allow the drain hole to be visible. Just going by the pictures, my GC2300 is very similar, but not identical.
/ GC1715 Blowing hydraulic fluid #48
Psst. Is it possible that the lever to the rear remotes has been switched on, and if no hydraulic implements are hooked up, the hydraulics are now dead-heading or flowing through a relief valve?
/ GC1715 Blowing hydraulic fluid #49
Your going to have to pull the hydraulic strainer and see if it's plugged up.
/ GC1715 Blowing hydraulic fluid #50
Doesn't explain the pics posted by the OP with a visible level on the gauge for the oil sump, yet fluid coming out of the fill tube at a higher location.
/ GC1715 Blowing hydraulic fluid #51
to me. it looks like you have some air in your sump which is giving you a misleading level in the glass level indicator. How many quarts did you add? I would try removing at least a half a quart...then purge the air by raising and lowering the loader and curling the bucket 10 times, same with the BH if its on. Check the level again...remove more if necessary.
/ GC1715 Blowing hydraulic fluid #52
I found another picture of the return area in my maintenance book. It appears that there are two ports. I could be wrong but I still think the ports are blocked. I have no idea what could be blocking them or how it could have happened during a fluid change, but that is still where I would start because the ports being blocked, or partially blocked is the only thing that makes sense to me.
/ GC1715 Blowing hydraulic fluid #53
I am assuming the pictures were taken at the same time as well.
/ GC1715 Blowing hydraulic fluid #54
no idea when the pictures were taken. The maintenance manual is for GC1725/23 but there are references throughout the book to 1710/1715/2300. I assume that it's the same book for all with updates made for changes and places where they missed updating the model references. Here is the image, the side where the fill tube is cut off at the top of the image
This tractor dosen't have a backhoe and i don't have the front end loader on it. I removed the pickup screen and it was clean. The picture of the glass was taken while the fluid was coming out it was part of a video . Asked the mechanic at local MF dealer he said it shouldn't need to be on. I slowed the RPM and it went down.
If putting old fluid back in doesn't work. I'm going to try putting the bucket on and running it some. I usually leave the bucket off when I mow grass much easier. I put 2.9 gal in it.
/ GC1715 Blowing hydraulic fluid #57
So if the loader is off the tractor (I do the same in the summer) is the loader lever in the neutral position? I’m still thinking that there’s a lever that’s in the on position somewheres, that shouldn’t be…🤷
/ GC1715 Blowing hydraulic fluid #59
Is it possible a rag or something got pushed into the fill tube when you did the original fluid change?
Mowed with old fluid back in tractor for 3 hrs. this weekend worked just fine so it looks like fluid is the problem guess time will tell.
Question what fluid you guys running in your MF tractors I will have to change it sometime.
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
1990 TRAIL MASTER  TRANSPORT TRAILER (A60736)
1990 TRAIL MASTER...
2019 F150 (A61306)
2019 F150 (A61306)
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
DEUTZ MARATHON...
IGERSOLL-RAND AIR COMPRESOR (A60736)
IGERSOLL-RAND AIR...
