Forks for a 60HP Kioti DK6010SE?
/ Forks for a 60HP Kioti DK6010SE? #1
future_vision
Gold Member
New England
DK6010SE HSA
I've been filling up the forum here with a bunch of questions and I apologize because I know there are fork conversation here but I could not find them. At least not for a tractor my size. Then again, I have only a limited amount of time in my day to search and read. That being said what would be a good set of reasonable priced pallet forks for my future tractor (Kioti DK6010SE)? Seems like 42" and 48" are the most popular. I would also want adjustable ones that move side to side. And of course strong and light would be preferred. Thoughts on the ones you would chose or have chosen?
/ Forks for a 60HP Kioti DK6010SE? #2
I've got 48" Titan clamp on forks for my BX2200 and they are excellent. I actually used it yesterday to relocate some palatized firewood.
Forks are sooooo useful!
But remember! Tractors are NOT forklifts! If you need to consistently and safely move pallets around, get a forklift or a material handler.
I don't think I want to take chances with clamp on forks TBH. I know Titan has 10% off on orders over $799. Looking at these in particular. Anyone own these or can give me some feedback on Titan Attachments in general?
/ Forks for a 60HP Kioti DK6010SE? #4
Kioti RX6010 Attachments​
Kioti KL601 Loader
Loader weight:1369 lbs
620 kg
Height (to pin):114.2 inches
290 cm
Clearance, dumped bucket:85.4 inches
216 cm
Dump reach:22.2 inches
56 cm
Dump angle:71°
Reach at ground:73.5 inches
186 cm
Rollback angle:44°
Breakout force (at pin):3916 lbs
1776 kg
Lift to full height (at pin):2506 lbs
1136 kg
Bucket width:80 inches
203 cm
Raise time to height:4.3 s
Bucket dump time:3.1 s
Lowering time:2.9 s
Rollback time:2.0 s
/ Forks for a 60HP Kioti DK6010SE? #5
Can we assume your FEL will include an SSQA (Skid Steer Quick Attach) coupler?
48" length Pallet Forks are fine if your primary use will be moving pallets. However, if moving one ton pallets is your primary application, a tractor is the wrong tool.
When picking up brush, 48" length Pallet Forks are cumbersome.
I mostly move brush and tree trunks. My Pallet Fork are 36" length. My FEL lift capacity is 1,800 pounds.
I like the ample operator guard on the forks you linked to.
An operator guard is very important moving tree sections.
It is so easy to roll a tree trunk over the Loader and onto the tractor hood.
Kioti KL601 Loader
620 kg
290 cm
216 cm
56 cm
Dump angle:71°
186 cm
Rollback angle:44°
1776 kg
1136 kg
203 cm
Lowering time:2.9 s
Rollback time:2.0 s
Didn't know there was an RX6010. Mine will be a DK6010SE HSA
I think I might just go for the ones I linked. Seems like I might be able to throw some chains on it too if I needed them. Might be able to weld a D ring on them? I'm pretty sure I also saw a pair with a hitch mount too but I am not sure why you would want to pull that way and not from the 3pt.
/ Forks for a 60HP Kioti DK6010SE? #9
Those are similar to the vrning brand forks I use on my MX (similar sized machine). It’s perfect, and I do like the 46-48” forks. It works well for reaching deeper into a truck bed to move a pallet.
/ Forks for a 60HP Kioti DK6010SE? #10
DK6010SE HST
KL5520 LOADER
checkmark
Maximum Lift Height to Pivot Pin107.7 in. (2,735 mm)
Clearance w/ Bucket Level 96.3 in. (2,446 mm)
Clearance w/ Bucket Dumped 78.8 in. (2,001 mm)
Reach at Maximum Height (45º)22.7 in. (576 mm)
Maximum Dump Angle 46º
Reach w/ Bucket on Ground 71.1 in. (1806 mm)
Maximum Rollback Angle 41º
Digging Depth Below Grade 8.6 in. (218 mm)
Overall Height in Carry Position 54 in. (1371 mm)
Bucket Depth (Inner Shell) 18.5 in. (470 mm)
Bucket Height22 in. (560 mm)
Bucket Length (Pivot Pin)26 in. (660 mm)
Lift Capacity to Full Height at Pivot Pins 2,474 lbs. (1,122 kg)
Breakout Force at Pivot Pins3,895 lbs. (1,767 kg)
Bucket Rollback Force at Ground Line3,148 lbs. (1,428 kg)
Relief Valve Setting (Loader Control Valve) 2,774 psi (195 kg/cm²)
Rated Flow (Tractor System) 9.62 gpm (36.4 L/min)
Bucket Size(s) Available66" QA / 72" QA
Bucket Capacity (Heaped)66 in.: 14.5 cu. ft. / 72 in.: 16.0 cu. ft.
Approximate Weight (With Bucket)66 in.: 1,361 lbs. (617 kg) / 72 in.: 1,389 lbs. (630 kg)
I keep wondering if I am going to regret getting a Titan Attachment. Seems like a lot of people like them but then there are some that just get poorly constructed attachments and have to make adjustments to them which usually involved drilling or welding.
/ Forks for a 60HP Kioti DK6010SE? #13
i got my forks from Quick Attach. super well made.
mine has complete backing.
How much are they? I know QuickAttach tends to run expensive although they seem to be pretty high quality,.
/ Forks for a 60HP Kioti DK6010SE? #15
no idea about current costs.....when i got mine, they were FREE.
i ordered a hydraulic snowblower and a plow, they threw in 42" forks for free.
all their stuff is quality build. made in their factory. free shipping
you can ask for current price on their website. problem i see now is steel costs SUCK...ive never seen it so high.
I'll probably just go for it. They have a one year warranty and I'm likely to give them a good test in that first year for sure.
/ Forks for a 60HP Kioti DK6010SE? #17
i believe mine are rated at 4,000....but my tractor can only lift 2,700, so im not too worried.
Ended up with some forks from Titan. Pretty decent although I went with the made in the US version and that didn't really mean much. Cheap paint job but otherwise adequate.
Question about lubing these things up so they slide. What should I use? The grease i use in the zerks is probably not a good idea since dirt really sticks. Tractor Mike advocates using WD-40 Spray and Stay gel but then again he is sponsored by them. I'm sure it is probably a good product but I am wondering what other options there are.
/ Forks for a 60HP Kioti DK6010SE? #19
Grease will pick up too much crap. I use wd40. But it doesnt matter..
they suck anyways when you have to adjust them.
/ Forks for a 60HP Kioti DK6010SE? #20
There are many other brands that you can buy directly from the US manufacturer and are cheaper or the same price as places like pallet fork or EA.
For instance
expressateelinc.com and MTL along with tomahawlk.
I wouldnt get anything less than a 48in fork for pallets.
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
2007 MACK CHN613 DAY CAB (A60736)
2007 MACK CHN613...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
1999 Jaguar XK8 Convertible (A61569)
1999 Jaguar XK8...
1998 Ferguson 46B Compactor / Roller (A62613)
1998 Ferguson 46B...
