Forks for a 60HP Kioti DK6010SE?
   / Forks for a 60HP Kioti DK6010SE? #1
future_vision
New England
DK6010SE HSA
I've been filling up the forum here with a bunch of questions and I apologize because I know there are fork conversation here but I could not find them. At least not for a tractor my size. Then again, I have only a limited amount of time in my day to search and read. That being said what would be a good set of reasonable priced pallet forks for my future tractor (Kioti DK6010SE)? Seems like 42" and 48" are the most popular. I would also want adjustable ones that move side to side. And of course strong and light would be preferred. Thoughts on the ones you would chose or have chosen?
   / Forks for a 60HP Kioti DK6010SE? #2
I've got 48" Titan clamp on forks for my BX2200 and they are excellent. I actually used it yesterday to relocate some palatized firewood.
Forks are sooooo useful!
But remember! Tractors are NOT forklifts! If you need to consistently and safely move pallets around, get a forklift or a material handler.
I don't think I want to take chances with clamp on forks TBH. I know Titan has 10% off on orders over $799. Looking at these in particular. Anyone own these or can give me some feedback on Titan Attachments in general?
   / Forks for a 60HP Kioti DK6010SE? #4
Kioti RX6010 Attachments​
Kioti KL601 Loader
Loader weight:1369 lbs
620 kg
Height (to pin):114.2 inches
290 cm
Clearance, dumped bucket:85.4 inches
216 cm
Dump reach:22.2 inches
56 cm
Dump angle:71°
Reach at ground:73.5 inches
186 cm
Rollback angle:44°
Breakout force (at pin):3916 lbs
1776 kg
Lift to full height (at pin):2506 lbs
1136 kg
Bucket width:80 inches
203 cm
Raise time to height:4.3 s
Bucket dump time:3.1 s
Lowering time:2.9 s
Rollback time:2.0 s
   / Forks for a 60HP Kioti DK6010SE? #5
Can we assume your FEL will include an SSQA (Skid Steer Quick Attach) coupler?
48" length Pallet Forks are fine if your primary use will be moving pallets. However, if moving one ton pallets is your primary application, a tractor is the wrong tool.
When picking up brush, 48" length Pallet Forks are cumbersome.
I mostly move brush and tree trunks. My Pallet Fork are 36" length. My FEL lift capacity is 1,800 pounds.
I like the ample operator guard on the forks you linked to.
An operator guard is very important moving tree sections.
It is so easy to roll a tree trunk over the Loader and onto the tractor hood.
Kioti KL601 Loader
620 kg
290 cm
216 cm
56 cm
Dump angle:71°
186 cm
Rollback angle:44°
1776 kg
1136 kg
203 cm
Lowering time:2.9 s
Rollback time:2.0 s
Didn't know there was an RX6010. Mine will be a DK6010SE HSA
I think I might just go for the ones I linked. Seems like I might be able to throw some chains on it too if I needed them. Might be able to weld a D ring on them? I'm pretty sure I also saw a pair with a hitch mount too but I am not sure why you would want to pull that way and not from the 3pt.
   / Forks for a 60HP Kioti DK6010SE? #9
Those are similar to the vrning brand forks I use on my MX (similar sized machine). It’s perfect, and I do like the 46-48” forks. It works well for reaching deeper into a truck bed to move a pallet.
   / Forks for a 60HP Kioti DK6010SE? #10
DK6010SE HST
KL5520 LOADER
checkmark
Maximum Lift Height to Pivot Pin107.7 in. (2,735 mm)
Clearance w/ Bucket Level 96.3 in. (2,446 mm)
Clearance w/ Bucket Dumped 78.8 in. (2,001 mm)
Reach at Maximum Height (45º)22.7 in. (576 mm)
Maximum Dump Angle 46º
Reach w/ Bucket on Ground 71.1 in. (1806 mm)
Maximum Rollback Angle 41º
Digging Depth Below Grade 8.6 in. (218 mm)
Overall Height in Carry Position 54 in. (1371 mm)
Bucket Depth (Inner Shell) 18.5 in. (470 mm)
Bucket Height22 in. (560 mm)
Bucket Length (Pivot Pin)26 in. (660 mm)
Lift Capacity to Full Height at Pivot Pins 2,474 lbs. (1,122 kg)
Breakout Force at Pivot Pins3,895 lbs. (1,767 kg)
Bucket Rollback Force at Ground Line3,148 lbs. (1,428 kg)
Relief Valve Setting (Loader Control Valve) 2,774 psi (195 kg/cm²)
Rated Flow (Tractor System) 9.62 gpm (36.4 L/min)
Bucket Size(s) Available66" QA / 72" QA
Bucket Capacity (Heaped)66 in.: 14.5 cu. ft. / 72 in.: 16.0 cu. ft.
Approximate Weight (With Bucket)66 in.: 1,361 lbs. (617 kg) / 72 in.: 1,389 lbs. (630 kg)
INOP/NON- RUNNING 2013 Ford F-250 Pickup Truck, VIN # 1FT7W2A61DEA38762 (A51572)
INOP/NON- RUNNING...
2022 ATLAS XAS188 AIR COMPRESSOR (A52472)
2022 ATLAS XAS188...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
2019 Ford F-450 Utility Truck, VIN # 1FT8W4DT8KEF27612 (A51572)
2019 Ford F-450...
(2) Drums of Car Wash Brush Soap (A51573)
(2) Drums of Car...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
