Ideas for cannon ball extraction?
/ Ideas for cannon ball extraction? #81
After you get most of the heavy debris out (which it sound like you have) a simple idea for cleaning up the bore is a flapper disk with an extension if you can find the right size....
If not a length of threaded rod, 4 nuts, 2 large washers & some 3M Abrasive Pads will work too. Just cut 4 - 6 3M pads in circles so they fit snug in the bore, then place 2 nuts (use one as a Jamb nut) & a washer far enough down on the threaded rod that you can fit the 3M disks you just cut (small holes in the middle of them) on with then another washer & 2 more nuts.... Put the threaded rod in you battery powered drill...
/ Ideas for cannon ball extraction? #82
Get a gallon or two of vinegar, put that in there and then top off with water. Let it sit overnight or two. Try to scrub out again. Rinse and repeat......
/ Ideas for cannon ball extraction? #83
Fill the area behind the ball with plain water, then drop the cannon into a freezer.
The expansion of the ice will move the ball,, even with minor gaps and poor seal of the ball to bore.
I have a novelty ice cube maker, a silicone mold. fill it with water, and a skull shape comes out.
Each time it is used, the two halves of the mold push open, but there is no leaking water.
I think the same would occur with the cannon,, the ball would be moved.
Once the ball were moved a little, it would be easy to move further.
Clever thinking, I like it! The bore cleaner I have would be much like you described however, it's to fit in your hands (even has rope wound around the hand held end to make it easier to grip and look nicer)
Thing is, the cleaner I have has these round 'pads' bolted to the end, much as you describe but, they are cotton or something soft like that, not abrasive. So a box of greenies could replace those. I totally get your description.
Heh, I'm not sure, but I'm going to speculate that you've never picked up a (bronze?) cannon by yourself. It was all I could do to lift it onto the hand truck in the picture. Weight wise, it's doable but it's SO awkward.... no good lifting handles and then, with it intact, it wants to hinge at the pivot point making it even more unwieldly. Then of course, I'd have to cut it into sections to get it to fit inside the freezer at which point, I could simply cut behind the ball and push it out.
/ Ideas for cannon ball extraction? #86
Cylinder brake hone up to 2 3/4"
/ Ideas for cannon ball extraction? #87
I'am not a gambling man but I think Richard will get the cannon ball out quicker than the TBN member on here that cound'nt break loose his oil pan bolt . Can't remember his TBN handle ?
/ Ideas for cannon ball extraction? #88
Mark it so you can easily tell the orientation of the ball, maybe use a sharpie.
Can you maneuver the cannon so you can pick it up with your backhoe and "shake" it?
Or fix up a pully and hang it so you can reorient it easily?
I'm thinking
You've go it rolling
Hang it so it's balanced
point it down, let the ball roll
point it up, let the ball roll
rinse and repeat.
/ Ideas for cannon ball extraction? #89
Yup, seems Richard has dedication and purpose.
/ Ideas for cannon ball extraction? #91
You're close
  1. Hone the bore
  2. Lubricate the bore
  3. Remove the cannon ball
Yep, got one of those. (though mine is not wide enough) anyway, the issue isn't the diameter, it's the length. I'd need one that is say, 30" long (maybe not exact but the point is, most are only say, 10/12 inches so I'd not be able to reach my problem area)
/ Ideas for cannon ball extraction? #93
yep, diy extension?
/ Ideas for cannon ball extraction? #95
My dad had two cannons, a .54 and a 1.75 bore (I still have the .54). I can remember on several occasions with misfires we had to use an extractor (basically a metal rod with a lag screw welded on the end) to remove the ball. We only used lead balls with wads.
Basically just screw the rod into the ball and pull it out (it took a lot of pulling strength to get it out). But we always did this next day, never had a barrel with the kind of corrosion yours has. I think your on the right track since your able to move it a few inches now. Good luck
/ Ideas for cannon ball extraction? #96
PVC pipe glued to the ball, then even add shop vac to the pipe?
/ Ideas for cannon ball extraction? #97
Well shoot, just fill up behind the ball with Mexican food. That always seems to generate a lot of pressure! May have to puree it first, however.
/ Ideas for cannon ball extraction? #98
This is turning into another rounded off drain plug :oops:
/ Ideas for cannon ball extraction? #100
Someone may have already suggested this but how about injecting expanding insulation foam behind the ball?
that's where I was headed with the thought :)
Vermeer RTX 250 Trencher  (A62679)
Vermeer RTX 250...
(15) IH Suitcase Weights (A66408)
(15) IH Suitcase...
7000bu Grain Bin (A66408)
7000bu Grain Bin...
Livestock Catch Chute (A66408)
Livestock Catch...
1992 GMC C7000 Dump Truck, VIN # 1GDM7H1J9NJ522223 (A65563)
1992 GMC C7000...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
