Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,090
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Regarding the hole(s) in the ball. So far, I've only seen a single hole. I've stuck a rod into it (some steel wire) and it appears to be maybe an inch deep or so.
Stuck magnet on it, magnet falls off. I talked to a gunsmith guy (to find out about how/where to buy powder) he said it was likely made of lead.
I have no idea.
The cannon doesn't come apart. Let me rephrase that.....the METAL part of the cannon is one piece. It has the stubs that allow it to hinge inside the wooden frame but there is no breech to open up to have access to anything.
The cannon itself appears to have a muzzle that is then, surrounded by another metal (bronze?)
The liner appears to be roughly 1/4" thick. You might be able to see it in the pictures. I'm guessing they take this liner, then cast the cannon around it (but I have no idea). Not a hint of rust on the exterior. The liner in the pictures is what appears to be crusty looking.
I hadn't thought about putting water in. I can put that into the barrel, it will seep behind the ball, then I can use my air. That might be enough to dislodge the ball. It will also push it out but not as easily as the air itself passing by the ball.
Nice idea!!
I have no idea.
Nice idea!!
