Ideas for cannon ball extraction?
/ Ideas for cannon ball extraction? #62
I'd strongly recommend patience in whatever you choose to do. This problem was decades in the making. Take your time finding the best solution whatever that may be.
I recently had a very stuck PTO shaft that wouldn't even come apart after being chained to a stump and being pulled with a full size tractor. Took me two or three months of repeat applications of Kroil oil (until I ran out) and then a mixture of ATF fluid + paint solvent. Then it decided to free up and came apart pulling it by hand without damage. I really think it just took time for the ATF fluid to work itself into the corrosion to free things up.
You don't want to putting anything in the bore that is going to cause corrosion down the road. I'd also been leery of hard hits on the barrel that could cause something to unexpectedly fracture.
Take your time.....
/ Ideas for cannon ball extraction? #68
IDK, I wondered if he could pull it out with a fishing magnet after the bore has been cleaned and the ball has been loosened with some kind of penetrating fluid if won't fall out on its own? Or ask Buggs67 neighbor what he'd do? Maybe he could make a bore worm if that's the tool needed?
/ Ideas for cannon ball extraction? #69
Rig it to hoist vertically nose down, lift as high as you can, rig to stop just before it hits ground. Drop it.
/ Ideas for cannon ball extraction? #70
To add to those suggestions to let gravity work along with dropping the barrel on its nose or shaking it, etc. Rent or borrow a concrete vibrator and strap it to the barrel and hopefully the shake, rattle, and over time ,,,, will cause a roll. :giggle:
/ Ideas for cannon ball extraction? #71
After cleaning and oiling the bore, how about using an glob of epoxy adhesive, aka, JB Weld, on the end of a dowel pushed onto the cannon ball. Let it cure and see if it will move the ball. Might help to have the cannon sorta pointing at the ground if possible so the "glob" does not fall off the dowel. Block the dowel so it does not move at the muzzle while the epoxy cures. Put some paper, rags or some such up against the ball to capture any epoxy that falls off the dowel or ball. The paper, rags, or some such can help hold up the dowel while the epoxy cures.
Interesting problem that is for sure.
My father in law found a cannon in the Cape Fear river when he was a kid. It had been dredged up from the channel at some point. He got it to shore and eventually it was displayed at a museum in central NC even though he still owns the cannon. We wonder if we can find the cannon and claim it back.... :ROFLMAO:
Later,
Dan
/ Ideas for cannon ball extraction? #73
Youtube of a guy casting his own concrete creations using a reciprocating sawzall (w/o blade) to vibrate air pockets out of the wet concrete. Not 3/4 HP but easy to try first.
Bit of an update.
No hone yet, but I have the bore "cleaner" which is very much like a 2 1/2" "Q-Tip". It's an oak ram with a bolt on the end. The bolt holds on 30-50 circular fabric circles. You put this in there to (I presume) clean the bore between shots.
Well... I put water in the bore. Got the ball moving outward but, not 'out'. Tamped it back in. Used this bore cleaner. Spent maybe an hour doing this and got a LOT of dirt out of the bore. The water at least, now comes out clean verses black.
I'm convinced there was no powder in there for those concerned about that. Even now if there was, it's totally water-logged so I'm not worried at all about any kind of discharge.
Every time I got the ball to move one way or another, I'd see stuff in there, I'll just call it junk or chaff. Not huge amounts but enough to make things stick.
Thinking about someone's comment about using some Coke in there to dissolve things, not knowing if that would work or not, I moved cannon under the overhang, dumped a can of Coke in there and will look at it tomorrow. I have the ball able (with force applied) to move maybe 10 inches back/forth. Mind you, I have to take the ram to push it back and then pressurized water to push it towards the muzzle. The ball does not roll around at all on its own.
Measured the bore and it appears to be 2.20 inches.
/ Ideas for cannon ball extraction? #75
I am guessing that the bore is no longer the issue but rather the ball itself.
How round was it originally and how much gunk has coated it?
I might concentrate on filling the bore so whatever chemical you choose covers the entire ball and eats at the entire surface not just the current contact point at the moment.
Keep us informed and glad it isn't active.
/ Ideas for cannon ball extraction? #76
Like suggested - keep cleaning, hot day, tamping on wood
What's the total bore length? 30"?
Your almost there!
Remember to lubricate after cleaning!
Totally agree. When I was using water, I filled it to the tip....let it seep past the ball and kept filling, then I used the bore cleaner. I had water squirting out the ignition hole, much like a drinking fountain however, I could get it to go maybe 10' in the air. So much of any loose stuff that was behind the ball might also be rinsed out. It washed the sides but I don't think it removed any rough material.
The ball seems to seal at (let's jut say) 15" inside the bore. When the ball gets pushed back to (let's say) 25" down the bore, you can easily see a gap at the top.... so the idea of the ball being deformed has been on my mind the entire time. Either that or the bore is very uneven. Looking down with flashlight, I don't see any obvious deformations of the bore however, that is a very casual comment as I've nothing to really compare it with. Still, going by the seat of the pants, I'm leaning to the ball being deformed.
Looking at the ball down the bore, It has me thinking these are maybe painted. I see some discoloration spots on it but instead of looking discolored, they look shiny like the paint has flaked off.
/ Ideas for cannon ball extraction? #78
I don't recall anyone suggesting a small amount of black powder along with an ignition source to dislodge the ball. I'm not suggesting that scenario, however, just pointing out the fact that no one has, at least to my knowledge. :)
/ Ideas for cannon ball extraction? #79
Use vinegar, coke or anther fluid containing phosphoric acid and completely fill the barrel and let and let sit for a few days. Then drain and scrub out the bore with wire brush or Sandpaper or whatever. Then proceed as you have been Using water pressure.
/ Ideas for cannon ball extraction? #80
Very interesting, indeed.
I am guessing that drilling a round hole (bore) would have been much easier to machine than making a sphere perfectly round which allowed me to keep just a few steps behind you. ;)
Sounds like what you are doing is working and will have it soon enough.
HOSE REEL FOR TORCH (A64276)
HOSE REEL FOR...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
New/Unused Mini Quick Attach Auger with Bit (A65583)
New/Unused Mini...
2019 ISUZU NPR 4X2 S/A 18FT FLATBED (A59912)
2019 ISUZU NPR 4X2...
