Raul-02
- Joined
- Aug 23, 2021
- Messages
- 1,467
- Tractor
- kioti DK4710 SE HST CAB
If I were to put shipping containers on the property My lovely missus would find my guns so fast.MY plan in the next two years is to place TWO sea containers
they will be new, solid grey colour, "pretty" ... I have some convincing to do stillIf I were to put shipping containers on the property My lovely missus would find my guns so fast.
hide your guns.I have some convincing to do still
Ha Ha Ha - Never considered that ---Still laughing. Hayou do realize that this presupposes the use of deodorant n the first place.
Nice idea, except why only 20 ft long, many pickups are longer then 20'.
Also with only 16' in width it will be a bit narrow for two full sized vehicles.
I had a problem with mice around the chicken coop and shed where l store their feed. There are a lot of non-poisonous options, so l decided to try spearmint and peppermint essential oils mixed in a water spray bottle. Have not had a mouse in the shed since l began spraying around entrance. Hasn't stopped the snakes though.Don't know if this is quite the right subforum for this, but...
I am tired of parking my Kubota L3710 and John Deere 430 garden tractor in the rain, so I am considering adding a steel building to my property.
It looks like I will need something that will at least slow mice down, since they have already built nests on top of the garden tractor's battery and inside the truck's hood insulation.
I want to be able to put the tractors, a utility cart, and my pickup in there, along with a few implements. I have a bush hog and a subsoiler, and I am about to turn my chain-on forks into a quick attach implement.
I was thinking of making the building about 1000 square feet in a square shape, to resemble my existing workshop. It doesn't have to be fancy. I just want a couple of power outlets, overhead lights, and a door opener. My other building has 100 amps and all my big tools.
Wonder if anyone here has suggestions on configuring the building. Would a long building make more sense for multiple implements?
Another option is to build a big two-car garage for just the tractors, cart, and pickup and build a cheap pole barn without walls for the implements, which rodents can't really hurt.
There are plenty poisons and traps out there. Why not go that way?Don't know if this is quite the right subforum for this, but...
So far I have found the best protection against rodents under the hood is simply to leave the engine compartment as open as possible. Three weeks after buying my tractor, and carefully covering it with a big tarp, my wiring harness was chewed through in several places. After getting the tractor back from the shop, I moved it into my garage for the rest of the season as a short term fix. Meanwhile, I put up a steel pole barn, open on all sides. Whenever the tractor is not in use it is parked in the pole barn, with the engine compartment wide open. It's been a couple of years now and no further damage. Maybe I've just been lucky, but I don't think so. The critters like closed-in spaces and the open tractor in an open pole barn is simply not appealing. YMMV, of course.Don't know if this is quite the right subforum for this, but...
When i was in engineering school, we were the first class in the brand new Engineering Building. So, new the furniture hadn’t arrived.Don't be above making a set of scale drawings (or blobs) of the individual pieces of equipment you own. Next make a shape for the tool chest or supply cabinet you always wished was in the garage. Also make shapes for the stuff you think you should have nearby like fuel cans. Photocopy a few times and cut out a set. Push them around on various Floorplan outlines. Remember that garage doors can be on 1,2,3,4 sides. Also, if you are looking at a prefab steel building please understand that you cannot ignore the subslab details and expect long life from the structure eve in warm climates. Have fun!
